Events not working after update to 3.5837
RichardBokker
Domoticz version: 3.9317
Post by RichardBokker »
I updated my domoticz to 3.5837, and from that point on all my events (blockly and lua) are not working anymore!
The scripts are running (log file is saying script active) but the outputs are not set when the IF conditions are correct.
Anyone an idea how this happenend?
In example, the next simple script is running but commandarray is not executed somehow?
    print ("TV hoek actief script");
if (otherdevices['Hulp_TvAan'] == 'Off' and (otherdevices['St_TVWoonkamer'] == 'On' or  otherdevices['St_MediaplayerMinix'] == 'On')) then
    commandArray['Hulp_TvAan'] = 'On'
    print ("TV of Mediaplayer is actief");
elseif (otherdevices['Hulp_TvAan'] == 'On' and (otherdevices['St_TVWoonkamer'] == 'Off' or  otherdevices['St_MediaplayerMinix'] == 'Off')) then
    commandArray['Hulp_TvAan'] = 'Off'
    print ("TV of Mediaplayer is inactief");
marco.bag
Re: Events not working after update to 3.5837
Post by marco.bag »
same here
matthijsberg
Post by matthijsberg »
Same here. When I reboot my PI events work for an hour, maybe 2, then they stop working again. Manual tuning on / off devices still works. Script gets run (I see some troubleshoot prints in my log), but it looks like the command is not send to the device.
marco.bag
Post by marco.bag »
This morning, after a reboot seams working but it's strange... never happened, i do expect that it's going to block again.
As debug the CPU was over 30% (intel i5) when was not working so i think can be some process that can hang after a while.
RichardBokker
i also rebooted my PI, it seems to work now. Actions are performed.
Lets see how long it will be.
four2six
Post by four2six »
i can confirm this happening, too
python scripts seem to be unaffected
RichardBokker
Scripts outside event editor domoticz itself, are working indeed.
i have some lua en python scripts not located in de event editor, and they seems to be working.
THe problem is especially in the event editor of domoticz.
RichardBokker
problem is back, just a couple of hours after the reboot.
Kouseri
Post by Kouseri »
The latest beta fixed lua related issues I encountered with the 3.5837 release.
marco.bag
Post by marco.bag »
Me too... using Beta V3.5868 looks that solved the problem... we will see in the next few days.
four2six
Post by four2six »
the latest beta made my blockly scripts worse. none of them aren't triggered anymore. before it was just half of them.
matthijsberg
I find that the z-wave signals are now send, but the user variables in my scripts are no longer read, so comparing to the user var fails and thus my logic fails. Saw a new beta this morning, let's see what happens!
Edit; fixed. Script error.
Last edited by matthijsberg on Monday 07 November 2016 15:53, edited 1 time in total.
matthijsberg
Does anyone know if it's possible to downgrade, and if so, where to get the previous stable? thanks.
elmortero
Domoticz version: 3.9639
Post by elmortero »
matthijsberg wrote:Does anyone know if it's possible to downgrade, and if so, where to get the previous stable? thanks.
There is an article on the Wiki page that covers that:
http://www.domoticz.com/wiki/Going_back ... us_version
matthijsberg
Thanks elmortero. After reading this;
"But, it is not recommended to revert back to a stable version!
Best to post the problem on the forum, and ge
Going back to a previous version can make your current database tables/content corrupt, it is strongly advised NOT to do this"
and the fact that I would like to go back to not the latest but the previous stable release, I guess I'll pass on this one.
RichardBokker
I will go to newest beta too then, just to fix these event issues. That seems to be the solution for now. Lets try it out.
wwismans
Post by wwismans »
Same here. All of my commandArray[v] commands are not working anymore..
Tried updating to beta, but still no luck... Grrrrr :oops:
wwismans
Post by wwismans »
Fixed in stable release 5877, thanks guys!
martjah
Post by martjah »
I updated from the last stable version to the latest beta version (3.6265). I updated because i bought a Logitech Harmony Hub and it was not working with the latest stable. After updating the Harmony Hub started working perfectly.
But now none of my events work anymore. All the switches are turning on/off perfectly and the status of the switches are correct. But the events are not triggered anymore.
I do not use LUA scripting, just blockly's. Are more people having this problem?
**update**: i reverted back to the latest stable (3.5877) and the events are working again. I disabled the Harmony Hub in Domoticz because it's not working but that is not a priority.
simon_rb
Post by simon_rb »
I'm on the most recent stable version (updated a couple of weeks ago) and this has just started happening to me. Even restarting Domoticz doesn't help - I have to reboot my Pi to get events working again.. Anyone else still having this issue or found a fix - all I have done is upgrade my rtx433e firmware to the latest - don't think that would effect things
Cheers
