Domoticz on synology for evohome
Re: Domoticz on synology for evohome
Seems like the script expects some input or so (the specific location). Sorry, cannot help you with that but I hope someone can explain because in the future i might like to use more locations also
- Target OS: -
And do you know which files I have to edit? All of them?gordonb3 wrote:You can replace _get_single_heating_system() with locations[0]._gateways[0]._control_systems[0]
To access the second system you'll have to toggle one of the zero values to one. Which one will depend on your setup.
Update:
I edited the file settemp.sh and tried three times (each time a 0 to 1):
import evoconfig
from evohomeclient2 import EvohomeClient
import sys
import dateutil.parser
if len(sys.argv)<5:
until = None
elif sys.argv[4][:1] == '0':
until = None
else:
until = dateutil.parser.parse(sys.argv[4]).strftime('%Y-%m-%dT%H:%M:%SZ')
#connect to evohome web portal @ http://www.mytotalconnect.com
client = EvohomeClient(evoconfig.usr,evoconfig.pw)
client._locations[0]._gateways[0]._control_systems[1].zones_by_id[sys.argv[1]]._set_heat_setpoint({"HeatSetpointValue":0.0 if len(sys.argv)<4 else float(sys.argv[3]),"SetpointMode":int(sys.argv[2]),"TimeUntil":until})
open ("/var/tmp/evo-noup.tmp","w")
client# ./evo-settemp.sh
File "./evo-settemp.sh", line 28, in <module>
AttributeError: 'EvohomeClient' object has no attribute '_locations'
- Target OS: -
Then I get following error:
client.locations[0]._gateways[1]._control_systems[0].zones_by_id[sys.argv[1]]._set_heat_setpoint({"HeatSetpointValue":0.0 if len(sys.argv)<4 else float(sys.argv[3]),"SetpointMode":int(sys.argv[2]),"TimeUntil":until})
IndexError: list index out of range
- Target OS: -
Ok, perhaps I should first understand what the different options mean?
Locations => number of locations on my mytotalconnectcomfort account?
Gateway => ?
Control system => evohome basestation?
on my account I have 2 locations because I have 2 evohome stations that connect with 2 opentherm modules.
evohome WiFi Controller x 2
No gateway installed
Always trying with evo-settemp.sh via ssh.
gives error:
Gateway => ?
gives error:
gives error:client.locations[2]._gateways[0]._control_systems[0].zones_by_id[sys.argv[1]]._set_heat_setpoint({"HeatSetpointValue":0.0 if len(sys.argv)<4 else float(sys.argv[3]),"SetpointMode":int(sys.argv[2]),"TimeUntil":until})
gives error:client.locations[2]._gateways[0]._control_systems[2].zones_by_id[sys.argv[1]]._set_heat_setpoint({"HeatSetpointValue":0.0 if len(sys.argv)<4 else float(sys.argv[3]),"SetpointMode":int(sys.argv[2]),"TimeUntil":until})
Error from example 2:client.locations[1]._gateways[0]._control_systems[2].zones_by_id[sys.argv[1]]._set_heat_setpoint({"HeatSetpointValue":0.0 if len(sys.argv)<4 else float(sys.argv[3]),"SetpointMode":int(sys.argv[2]),"TimeUntil":until})
- Target OS: -
That's pretty weird... Even with all 0's it gives me the same error. Should I change another file besides the evo-settemp.sh?
- Target OS: -
So I created a test.sh with following config:
and this works perfectly... I also used locations 0 which worked. But when I use a name with '' or without'' it gives an error. Not really a big deal but it shows your code is correct but how would I have to implement it in the settemp.sh...
#!/usr/bin/python
# Copyright 2015 - fullTalgoRythm
# Licensed under GNU General Public License 3.0 or later.
# Some rights reserved. See COPYING, AUTHORS.
# @license GPL-3.0+ <http://spdx.org/licenses/GPL-3.0+>
# see http://www.domoticz.com/wiki/Evohome
# see http://evohome-client.readthedocs.org/en/latest/index.html
import evoconfig
zone=client.locations[1]._gateways[0]._control_systems[0]._zones[1]
schedule=zone.schedule()
print schedule
- Domoticz version: 3.5877
Hi Alle,
I've just read your walkthrough about the evohome Domoticz connection.
I a linux novice and got stuck on the run: /var/packages/debian-chroot/scripts/start-stop-status chroot commend.
I get sh: run:: command not found
Is there any change of setting up a teamviewer session and help me out for a couple of minutes please?
Kind regards
Kind regards
- Target OS: -
don't use the run before the command. just use "/var/packages/debian-chroot/scripts/start-stop-status chroot"
Hi Soulplayer,
Thank you for your help, I got a bit further now,
Now I'm stuk at the point where I have to create the own evohome-config.py file.
https://www.domoticz.com/wiki/Evohome#S ... _or_RFG100
Should I do this in notepad or via the shell, as I cannot find the evohome-client folder on my NAS.
I tried also via the VI command, although I'm struggling editing the pasted text and cannot save it.
- Target OS: -
I use winscp to make the files, i do not like the vi editor...
To use winscp as root, follow these steps:
https://forum.synology.com/enu/viewtopi ... 95#p425367Log in with SSH, be root, "sudo -i"
Enter, "vi etc/sudoers"
comment out the line #%administrators ALL=(ALL) ALL
insert a new line as: %administrators ALL=NOPASSWD: ALL
[esc] :w!
enter password.
I was able to set up everything, although 2parts are not acting as should be.
1 the task schedule runs as long as I'm logged in to DSM and then jumps to 1 time per day instead of per minute.
2 setting temperature towards te system does not work. Guess I'm missing a script as I have seen in the Domoticz log.
- Target OS: -
1: Make sure you select the right "first execution time" (bad translation probably): if you set the task at 17 make sure you set it at 17. It will then default back to one time a day so you need to change it back. Then put the end time at 23:59.
2: What is the log error?
I have set my task to start at 00:00 end end time at 23:59 so I think it will run OK now.
For the second item, this is the error code:
2016-11-16 10:12:18.447 Error: evohome: Error script not found '/home/evohome-client/evo-settemp.sh'
Update1: I think it cannot find the evo-settemp.sh because the update script runs inside the chroot environment, and the domoticz runs outside the chroot environment.
Update2: I have changed the evoconfig file to following.
GNU nano 2.2.6 File: evoconfig.py Modified
Now I get 2016-11-16 20:04:01.776 Error: Error executing script command (/volume2/@appstore/debian-chroot/var/chroottarget/home/evohome-client/evohomeclient2/evo-settemp.sh). returned: 256
Update3: after trying to run the evo-update.sh I get following error.
looks quite the same as what soulplayer got, with the only difference is that I only have 1 system.
Update4:
Just tried to figure out where it goes wrong.
when debugging the value sys.Avrg I get next results:
#If the length of this is less than 5 then the timeuntil value is None
if len(sys.argv)<5:
until = None
#Else if the value is ??? return none
until = None
#else return me the date and time
else:
When debugging this part it says that the lenth is smaller than 5 and thus return None, which is not a date or time format.
also this part "dateutil.parser.parse(sys.argv[4]).strftime('%Y-%m-%dT%H:%M:%SZ')" returns the listindex out of range error
Is it possible that something goes wrong over here?
#fill in username
usr=*********
#fill in pw
pw=***********
#fill in Domoticz URL
url='192.168.**********'
#fill in Domoticz port
port='8084'
#fill in script root e.g. script:///home/<user>/evohome-client script::///usr/local/bin etc
srt='script:///volume2/@appstore/debian-chroot/var/chroottarget/home/evohome-client/evohomeclient2'
I also made the test file, which works just fine.Traceback (most recent call last):
client._get_single_heating_system().zones_by_id[sys.argv[1]]._set_heat_setpo int({"HeatSetpointValue":0.0 if len(sys.argv)<4 else float(sys.argv[3]),"Setpoin tMode":int(sys.argv[2]),"TimeUntil":until})
Update4:
this value sys.avrg must go through an If function which must return the "Timeuntil" value.Number or arguments 1 arguments
Argument list: ['./evo-settemp_test.sh']
if len(sys.argv)<5:
until = None
until = None
else:
Last edited by fantilator on Wednesday 16 November 2016 22:06, edited 6 times in total.
New strage acting part,
When I run the code from SSH, the values update, although the task sheduler runs, but does not update the values.
Update: After restart of NAS it works again, we'll see how long it takes.
Update2: It keeps running now, problem solved.
chroot /volume2/@appstore/debian-chroot/var/chroottarget /home/evohome-client/evohomeclient2/evo-update.sh
I'm almost done... but I receive an error message see below...thanks for your support..!
~/evohome-client# ./evo-update.sh
File "./evo-update.sh", line 26
sys.exit(1)
IndentationError: unexpected indent
sys.exit(1)
remove any spaces before your line 26.
Yess...stupid mistake thanks
After ./evo-update.sh I don't receive any errors, looks like everything is fine, but the temps doesn't show up in Domoticz.
For the script location (evoconfig.py) I use the following: srt='script:///home/evohome-client' is this correct? I see also some examples where there referring to script:///volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client
My (evohome) scripts are in home/evohome-client (@root)
Thanks for your support!
when using the chroot, your files are being stored inside the chroot part, so you must link to chroot locations.
srt='script:///volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client'
Thanks will change the location... but when I check the location /volume1/@appstore/debian-chroot/var/chroottarget/home/evohome-client it doesn't show the evo files.... I see only the files when login as root to my NAS /evohome-client/
I have selected within Domoticz Hardware --> Evohome via script and included the controller etc. But unfortunately the data is not updated (no temperature is shown...any suggestions?
Thanks again for your support
