Skippiemanz wrote:
In the mean time, does anyone have the problem that the valve script wont turn on the CH_switch?
Skippiemanz / all, Hi, Firstly Great work all, i have been watching this develop and love all the work you guys have been putting in, my system is not fully working yet (not getting temp or setpoint readings form MAX to Domoticz, script is reading them but domoticz not updating. Valves are fine) but its certainly getting there.
i noticed the same problem and have manged to fix it in my version of the script, NOTE: i am running the script via the Events LUA (Time) page not in a file in the LUA folder (not sure if it makes a difference).
The 2 problems i noticed were,
1. around line 26- TempMin = 100, should be TempMin = 10 (or whatever you want for your lowest temp?)
2. loads of instances of hard coded device names instead of variable name I.E. 'BoilerSwitch' instead of BoilerSwitch,
Here is my adjusted code if you want to try it,
-- script_time_Heating Valves.lua
-- Version 1.9 27/10/16
-- Script to read the % open of radiator valves
-- All radiator valves are labelled "<room name>-Rad"
-- search is made for "-Rad" to indicate a radiator valve
-- If found it will be interrogated for % open value
-- Thermostat are named <room name>-Stat so a search is made for "-Stat" to indicate thermostats
-- If found it will be interrogated for temperature value
-- If demand is greater than BoilerOnPercent value then fire up boiler
-- If demand is less than BoilerOnPercent minus HysterysisOffPercent then switch off boiler
-- Preset Values
BoilerOnPercent = 30 -- percentage valve open at which the boiler will be turned on
HysterysisOffPercent = 20 -- percentage below BoilerOnPercent to switch off the boiler
MinValves = 2 -- Number of Valves that need to be open before boiler is turned on
ValvePercentOveride = 75 -- Percentage value of valve open required to override MinValves value (one room is very cold)
HolidayMinTemp = 10 -- Minimum room temperature before boiler is turned on during holiday period
HolidayHysterysisTemp = 2 -- Value to increase house temperature by while in holiday mode if boiler is turned on due to low temperatures
MissingDevicesTime = 86400 -- Value in seconds to allow before reporting a device has not been updated
email = "[email protected]" -- email address for warnings
-- Script Variables
PercentMax = 0
TempMin = 10
ValveCount = 0
MissingDeviceCount = 0
SendAnEmail = false
HeatingSwitch = "Heating"
BoilerSwitch = "CH_Switch"
HolidaySwitch = "Holiday"
-- Set printing to log options (true / false)
printData = true
printDebug = false
-- Get current date & time
t1 = os.time()
local currentDate = os.date("*t"); -- sets up currentDate.[table]
-- (currentDate.year [full], .month [1-12], .day [1-31], .hour [0-23], .min [0-59], .sec [0-59], .wday [0-6 {Sun-Sat}])
sCurrentTime = currentDate.year .. "-" .. currentDate.month .. "-" .. currentDate.day .. " " .. currentDate.hour .. ":" .. currentDate.min .. ":" .. currentDate.sec
function TimeElapsed(s) -- expects date & time in the form of 2010-01-23 12:34:56
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = os.difftime (t1, t2)
return difference -- in seconds
-- print blank line in log
if printData == true then
print (" ")
print (" *** Heating Script Output ***")
print (" ")
-- Get Data from Radiator Valves
for i, v in pairs(otherdevices) do -- Get all devices in the database
v = i:sub(-4,-1) -- Grab the last four characters of the device name
if (v == '-Rad') then -- are the last four characters "-Rad"? If so we have a Radiator Valve
RoomName = i:sub(1,-5) -- Get the rest of the name, which will be the room name
sSetTempValue = otherdevices_svalues[RoomName..'-Stat']
sValvePercentOpen = otherdevices_svalues[i]
sLastUpdateTime = otherdevices_lastupdate[i]
sElapsedTime = TimeElapsed(otherdevices_lastupdate[i])
message = RoomName .. " valve is open " .. sValvePercentOpen .. " percent " .. " Setpoint temperature is " .. sSetTempValue .. "C" -- for debug
message2 = RoomName .. " last seen " .. sLastUpdateTime .. " Elapsed time " .. sElapsedTime
print (message)
print (message2)
-- check for missing devices
if sElapsedTime > MissingDevicesTime then
SendAnEmail = false
MissingDeviceCount = MissingDeviceCount + 1
-- get the % value of the most open Radiator Valve
if tonumber(sValvePercentOpen) > PercentMax then
PercentMax = tonumber(sValvePercentOpen)
-- Count the number of valves that are open more than BoilerOnPercent
if tonumber(sValvePercentOpen) >= BoilerOnPercent then
ValveCount = ValveCount + 1
print (" ")
-- Get Data from Thermostats
v = i:sub(-5,-1) -- Grab the last five characters of the device name
if (v == '-Stat') then -- are the last five characters "-Stat "? If so we have an EQ-3 Thermostat
RoomName = i:sub(1,-6) -- Get the rest of the name, which will be the room name
sTemp = otherdevices_svalues[i] -- get the temperature
message = RoomName.." temperature is " .. sTemp .. " Centigrade " -- for debug
print(message)
print(message2)
-- get the lowest temperature of the thermostats
if tonumber(sTemp) < TempMin then
TempMin = tonumber(sTemp)
SendAnEmail = true -- change this to false if you do not require emails to be sent
print (" ")
print ("Number of valves open more than " .. BoilerOnPercent .. "% is " .. ValveCount .." valves")
print("Highest valve open value is " .. PercentMax .." percent ")
print("Lowest thermostat reading is " .. TempMin .." Centigrade ")
print (" ")
if (otherdevices[BoilerSwitch] == 'On')then
print ("Current state - Boiler is ON ")
print ("Current state - Boiler is OFF ")
-- Check the elapsed time and email if overdue
if (SendAnEmail == true) then
print (" ")
print("Heating Script: missing device email sent to " .. (email) );
notifyString = os.date("Domoticz Alert # The current time is %X on %A Lost contact with " .. MissingDeviceCount .. " Heating script devices, check if Max!Buddy is running. #") .. (email)
commandArray['SendEmail'] = notifyString
-- Perform logic
if printDebug == true then
-- view the settings to understand logic performance
print ("PercentMax (" .. PercentMax .. "%) " .. "Boiler On value (" .. BoilerOnPercent .. "%) " .. "Boiler Off value (" .. (BoilerOnPercent - HysterysisOffPercent) .. ")% ")
print ("Number of valves open more than " .. BoilerOnPercent .. "% is " .. ValveCount .." valves. Minimum valves setting " .. MinValves )
print ("Maximum open value " .. PercentMax .. "%" .. " Override value " .. ValvePercentOveride .."%")
print (" ")
if (otherdevices[HolidaySwitch] == 'Off')then -- Not on holiday
if (otherdevices[HeatingSwitch] == 'On')then -- It's time to heat the house
if (otherdevices[BoilerSwitch] == 'Off') then --If a minimum of 'MinValves' valves are on by more that pre-set value BoilerOnPercent
print ("Test passed - Boiler is OFF ")
if (PercentMax > BoilerOnPercent) then
print ("Test passed - Radiators are open beyond the threshold ")
if (ValveCount >= MinValves) or (BoilerOnPercent >= ValvePercentOveride) then
print ("Test passed - Either multiple valves are open or override count is reached ")
commandArray[BoilerSwitch]='On' -- turn on boiler
print ("Command sent - Turn ON Boiler ")
if (PercentMax < (BoilerOnPercent - HysterysisOffPercent) or (ValveCount < MinValves)) and (otherdevices[BoilerSwitch] == 'On') then -- If the number of valves open more than BoilerOnPercent minus HysterysisOffPercent
commandArray[BoilerSwitch]='Off' -- turn off boiler
print ("Command sent - Turn OFF Boiler ")
else -- on holiday
if (TempMin <= HolidayMinTemp) and (otherdevices[BoilerSwitch] == 'Off') then -- house is very cold
if (TempMin >= (HolidayMinTemp + HolidayHysterysisTemp)) and (otherdevices[BoilerSwitch] == 'On') then -- house is warm enough
commandArray[BoilerSwitch]='Off' -- turn on boiler
print (" ")
