RFX on RPi3 with SD card image don't react on switch pairing. Topic is solved
KroontjesPen
Domoticz version: 4.10717
Post by KroontjesPen »
Because there are more items involved, I don't no where to put this problem then here for the moment.
On my RPi3 there is the SD card image form Domoticz with version 3.5837.
There is hooked on the RFXtrx433E form RFXCOM
By installing the "RFXCOM-RFXtrx shared over LAN interface" the poort became 6144.
When I want to add a switch, then nothing happens. (In a short test in Windows it worked well.)
The RFXtrx receiving led is reacting normally.
If there is more information needed for you to help me out, please ask. Then I can enjoy Domoticz also. ;)
Bear with me, English is not my native language.
KroontjesPen
Re: RFX on RPi3 with SD card image don't react on switch pairing.
Sometimes you mix things up. That in combination of the English language and you go wrong.
This "RFXCOM-RFXtrx shared over LAN interface" was not the right one.
It had to be the same as for Windows: "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver"
Now I could see the USB poort.
Now can I finely go ahead with Domoticz. :D
