I have configured domoticz with the Secure Nginx Proxy Setup, but I want to turn to the Native HTTPS / SSL support. I need a bit of help for this, because I'm not familiar with this part of linux.
Can anyone guide me through this process?
My setup is a Raspberry Pi B+ with latest domoticz version installed (Version: 3.4834, Build Hash: 8398125).
Turn from Secure Nginx Proxy Setup to Native
nitpicker
- Domoticz version: 2022.2
Re: Turn from Secure Nginx Proxy Setup to Native
No one with decent Linux knowledge who can help me out?
jmleglise
- Domoticz version: 2022.1
I don't know what you have done with the nginx proxy and how to revert it. But for the native SSL support, It's really native. You have nothing to do , except what I have written in the wiki. https://www.domoticz.com/wiki/Native_HT ... SL_support
If you want to go a bit further , I advise you to choose a non official port for SSL (not the 443) and disable the HTTP port to be sure to force the SSL.
Here is my config defined in /etc/init.d/domoticz.sh
#DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -loglevel=1"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 2222"
So to connect to domoticz you will type : https://IP:2222/
You want to access to your domoticz from outside ? => NAT ( port translation) this port to the IP of your domoticz in your Provider router. Ex : UDP and TCP port 2222 => port 2222 ip domoticz (often something like 192.168.0.x)
and of course , active the authentification !
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
KMTronic USB relay
