Thanks for jumping in here (and big thanks for your earlier work) as I'm out of my depth wth coding.
Do you have any clues about the
attempt to concatenate field '?' (a nil value)
Sean
Thanks for the help!Westcott wrote:Hi Skippiemanz,
Con you post the Lua file that You use, please?
I'll mod it for you.
--./script_time_max.lua
-- Script parameters
package.loadlib("core.so", "*")
local Socket = require "socket"
local Basexx = require "basexx"
local Rooms = {}
local Devices = {}
local Room_nums = {}
local MaxIP = "192.168.2.123"
local MaxPort = 62910
local useWMT = false --# Set to true if there is a wall mounted thermostat in every room, then this one will be used for setpoint getting/setting
Debug = "YES" --# Turn debugging on ("YES") or off ("NO")
-- Script functions
function age(timestring)
t = {}
t.year = string.sub(timestring,1,4)
t.month = string.sub(timestring,6,7)
t.day = string.sub(timestring,9,10)
t.hour = string.sub(timestring,12,13)
t.min = string.sub(timestring,15,16)
t.sec = string.sub(timestring,18,19)
return os.difftime(os.time(),os.time(t))
function maxCmd_H(data)
--if Debug=="YES" then print('H='..data) end
function maxCmd_M(data)
i = 0
j = 0
while true do --find next comma
i = string.find(data, ",", i+1)
if not i then break end
j = i
s = data:sub(j+1)
dec = Basexx.from_base64(s)
num_rooms = string.byte(dec,3)
pos=4
for i=1, num_rooms do
room_num = string.byte(dec, pos)
name_len = string.byte(dec, pos+1)
pos = pos+2
name = dec:sub(pos, pos+name_len-1)
pos = pos+name_len
adr = Basexx.to_hex(dec:sub(pos, pos+2))
Rooms[room_num] = name
pos = pos+3
num_devs = string.byte(dec, pos)
for i=1, num_devs do
dtype = string.byte(dec, pos+1)
adr = Basexx.to_hex(dec:sub(pos+2, pos+4))
snum = dec:sub(pos+5, pos+14)
name_len = string.byte(dec, pos+15)
pos = pos+16
pos = pos+name_len
Room_nums[adr] = room_num
Devices[adr] = name
function maxCmd_C(data)
--if Debug=="YES" then print('C='..data) end
function maxCmd_L(data)
pos = 1
dec = Basexx.from_base64(data)
L_hex = Basexx.to_hex(dec)
L_len = string.len(L_hex)
while (pos < L_len) do
s = L_hex:sub(pos,(pos+1))
data_len = tonumber(s,16) + 1
hex = L_hex:sub(pos,pos+(data_len*2))
adr = hex:sub(3,8)
room_num = string.format("%02X", Room_nums[adr])
room = Rooms[Room_nums[adr]]
name = Devices[adr]
if not name then name=adr end
valve_info = tonumber(hex:sub(13,14),16)
batt = bit32.extract(valve_info,7,1)
bst = bit32.extract(valve_info,3,1)
mode = bit32.extract(valve_info,0,2)
if (batt==0) then sbat="OK" else sbat="Low" end
if (mode==0) then
smode="Auto"
elseif (mode==1) then
smode="Manual"
elseif (mode==2) then
smode="Holiday"
elseif (mode==3) then
smode="Boost"
if (data_len == 13) then -- WallMountedThermostat (dev_type 3)
valve_pos = -1
s = hex:sub(17,18)
setpoint = tonumber(s,16) / 2
s = hex:sub(23,26)
temp = tonumber(s,16) / 10
dtype = "Thermostat"
elseif (data_len == 12) then -- HeatingThermostat (dev_type 1 or 2)
s = hex:sub(15,16)
valve_pos = tonumber(s,16)
s = hex:sub(17,18)
if (mode ~= 2) then
s = hex:sub(19,22)
temp = 0
dtype = "Valve"
--Temperaturdevices den Status aktualisieren
if temp ~= 0 and dtype == "Valve" then
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name.." (Valve)"]..'|0|'..temp..';'..valve_pos..';0'})
elseif temp ~= 0 and dtype == "Thermostat" then
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[room]..'|0|'..temp})
if smode=="Manual" then
--Update virtual devices in Domoticz and update MAX! setpoints if necessary
if Debug=="YES" then print(dtype.." "..name.." Setpoint="..setpoint.." Temp="..temp.." Valve pos="..valve_pos) end
if dtype == "Valve" then
--table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name.." (Valve)"]..'|0|'..temp..';'..valve_pos..';0'})
if not useWMT and tonumber(otherdevices_svalues[name])~=nil then --Use valve to check setpoint mismatch
setpoint_Domoticz = tonumber(otherdevices_svalues[name])
---if name ~= "EcoTaster" and name ~= "Switch-SZ" and name ~= "Switch-WZ" then
if setpoint_Domoticz ~= setpoint then
print(otherdevices_lastupdate[name])
print(age(otherdevices_lastupdate[name]))
if otherdevices_lastupdate[name]~=nil and age(otherdevices_lastupdate[name]) > 120 then --Domoticz thermostat value must be updated
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name]..'|0|'..setpoint})
if Debug=="YES" then print("Domoticz setpoint updated") end
else --Max! setpoint must be updated
MaxCmdSend(adr, room_num, "manual", setpoint_Domoticz)
if Debug=="YES" then print("MAX!Valve setpoint updated") end
---end
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name]..'|0|'..valve_pos})
elseif dtype == "Thermostat" then
--table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[room]..'|0|'..temp})
if Debug=="YES" then print("MAX!WMT setpoint updated") end
dtype=""
name=""
setpoint=""
temp=""
valve_pos=""
pos = pos + (data_len*2)
function MaxCmdSend(id, room, mode, setpoint)
bits = setpoint * 2
smode = string.upper(mode)
if smode == 'MANUAL' then
bits = 64 + bits
elseif smode == 'BOOST' then
bits = 192 + bits
elseif smode == 'VACATION' then
bits = 128 + bits
hex = "000440000000"..id..room..string.format("%x",bits)
sendStr = Basexx.to_base64(Basexx.from_hex(hex))
i, status = tcp:send("s:"..sendStr.."\r\n")
if not i then
print("MAX! TCP send failed - "..status)
return
-- CommandArray
local m = os.date('%M')
if (m % 2 == 0) then
--print("The 3 minute script interval reached")
tcp = Socket.connect(MaxIP, MaxPort)
if not tcp then
print("MAX! Socket connect failed for "..MaxIP..':'..MaxPort)
return
tcp:settimeout(2)
local time = os.date("*t")
while (time.min ~= 0) do
s, status, partial = tcp:receive()
if (status) then
print("MAX! TCP receive - "..status)
break
local line = (s or partial)
local cmd = line:sub(1,1)
local data = line:sub(3)
if (cmd == 'H') then
maxCmd_H(data)
elseif (cmd == 'M') then
maxCmd_M(data)
elseif (cmd == 'C') then
maxCmd_C(data)
elseif (cmd == 'L') then
maxCmd_L(data)
break
tcp:close()
local Rooms = {}
local Devices = {}
local MaxIP = "192.168.1.131"
local useWMT = true --# Set to true if there is a wall mounted thermostat in every room, then this one will be used for setpoint getting/setting
-- Script functions
t = {}
i = 0
j = 0
j = i
s = data:sub(j+1)
pos=4
pos = pos+2
pos = pos+name_len
pos = pos+3
pos = pos+16
pos = pos+name_len
Devices[adr] = name
pos = 1
adr = hex:sub(3,8)
name = Devices[adr]
if (mode==0) then
smode="Auto"
smode="Manual"
smode="Holiday"
smode="Boost"
valve_pos = -1
s = hex:sub(17,18)
s = hex:sub(23,26)
s = hex:sub(15,16)
s = hex:sub(17,18)
if (mode ~= 2) then
s = hex:sub(19,22)
temp = 0
dtype = "Valve"
---end
dtype=""
name=""
setpoint=""
temp=""
valve_pos=""
bits = setpoint * 2
bits = 64 + bits
bits = 192 + bits
bits = 128 + bits
if not i then
return
-- CommandArray
if not tcp then
return
tcp:settimeout(2)
if (status) then
break
maxCmd_H(data)
maxCmd_M(data)
maxCmd_C(data)
maxCmd_L(data)
break
tcp:close()
I think this error occurs because the script tries to find the IDX of a device named "<valve device name> (Valve)", i.e. it expects the device name to end with " (Valve)". Nowhere else in the Wiki it is stated that this is the required naming scheme, it actually suggests valves to end with "-Rad".blackdog65 wrote:line 131 is where the error occursMany thanksCode: Select all
Sean
Rooms
Alienor 08F556
Cuisine
0B0442
Salon 08F541
Garcons 08F6D7
Couloir 08F616
Devices
Salon-Stat 09B650
Alienor-Rad 08F556
Cuisine-Rad 0B0442
Salon-rue-Rad 08F6D4
Salon-jardin-Rad 08F541
Couloir-Rad 08F616
Garcon-Rad 08F6D7
Device status
lua: maxtest.lua:91: attempt to index global 'bit32' (a nil value)
stack traceback:
maxtest.lua:91: in function 'maxCmd_L'
maxtest.lua:148: in main chunk
[C]: ?
Rooms
Alienor 08F556
Cuisine
0B0442
Salon 08F541
Garcons 08F6D7
Couloir 08F616
Devices
Salon-Stat 09B650
Alienor-Rad 08F556
Cuisine-Rad 0B0442
SalonRue-Rad 08F6D4
SalonJardin-Rad 08F541
Couloir-Rad 08F616
Garcon-Rad 08F6D7
Device status
stack traceback:
[C]: ?
lua maxtest.lua
H=JEQ0543318,03f77a,0113,00000000,5e12eb04,2a,32,100b02,1707,03,0000
Rooms
Alienor 08F556
Cuisine
0B0442
Salon 08F541
Garcons 08F6D7
Couloir 08F616
Devices
Salon-Stat 09B650
Alienor-Rad 08F556
Cuisine-Rad 0B0442
SalonRue-Rad 08F6D4
Couloir-Rad 08F616
Garcon-Rad 08F6D7
C=03f77a,7QP3egATAf9KRVEwNTQzMzE4AQsABEAAAAAAAAAAAP///////////////////////////wsABEAAAAAAAAAAQf///////////////////////////2h0dHA6Ly93d3cubWF4LXBvcnRhbC5lbHYuZGU6ODAvY3ViZQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENFVAAACgADAAAOEENFU1QAAwACAAAcIA==
C=0b0442,0gsEQgICEABLRVEwNTcxNzk4JiE9CQcYAzAM/wBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f6d7,0gj21wIDEP9LRVEwNTcwOTAzJiE9CQcYAzAM/wBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f616,0gj2FgIFEP9LRVEwNTY5OTA3JiE9CQcYAzAM/wBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f6d4,0gj21AIBEABLRVEwNTcwOTA2JiE9CQcYAzAM/wBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=09b650,zgm2UAMBEP9LRVEwODYzNzAwJiE9CURITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgBxgw
C=08f541,0gj1QQIBEP9LRVEwNTY5NjkzJiE9CQcYAzAM/wBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f556,0gj1VgIEEABLRVEwNTY5NzE0KyE9CQcYAzAM/wBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITRRFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNFEUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0URSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
Device status
stack traceback:
[C]: ?
print("valve_info for "..pos.." out of "..L_len)
print(valve_info)
Device status
valve_info for 1 out of 170
25
lua: maxtest.lua:93: attempt to index global 'bit32' (a nil value)
stack traceback:
maxtest.lua:93: in function 'maxCmd_L'
maxtest.lua:150: in main chunk
[C]: ?
"DOH! Don't you just hate it when that happens? Good catch. Is everything else working now?jmbjmbjmb wrote:Found the issue. I had lua 5.1 which does not have bit32.
idx = otherdevices_idx[name.." (Valve)"]
if not idx then
print("No device "..name.." (Valve)")
print(data)
elseif temp ~= 0 and dtype == "Valve" then
2016-11-03 08:02:00.861 LUA: No device SittingRoom-Stat (Valve)
2016-11-03 08:02:00.861 LUA: DBNwNQkSGQEoAAAAzQwU7Z0JElkBJgAAAL0LE4YvCRIZACgAzQALE4ZeCRIZACIAAAALFVXz8RoZACIAtwALDrjoCRIZZCgAAAAMFPDNCRIZASgAAAC1DBNwhAkSGQEiAAAArQ==
2016-11-03 08:02:00.861 LUA: Thermostat SittingRoom-Stat Setpoint=20 Temp=20.5 Valve pos=-1
2016-11-03 08:02:00.861 LUA: No device V-Bed-Stat (Valve)
2016-11-03 08:02:00.862 LUA: DBNwNQkSGQEoAAAAzQwU7Z0JElkBJgAAAL0LE4YvCRIZACgAzQALE4ZeCRIZACIAAAALFVXz8RoZACIAtwALDrjoCRIZZCgAAAAMFPDNCRIZASgAAAC1DBNwhAkSGQEiAAAArQ==
2016-11-03 08:02:00.862 LUA: Thermostat V-Bed-Stat Setpoint=19 Temp=18.9 Valve pos=-1
2016-11-03 08:02:00.862 LUA: No device SittingRoom-Rad (Valve)
2016-11-03 08:02:00.862 LUA: Valve SittingRoom-Rad Setpoint=20 Temp=20.5 Valve pos=0
2016-11-03 08:02:00.862 LUA: No device Z-Bed-Rad (Valve)
2016-11-03 08:02:00.862 LUA: Valve Z-Bed-Rad Setpoint=17 Temp=0 Valve pos=0
2016-11-03 08:02:00.863 LUA: No device V-Bed-Rad (Valve)
2016-11-03 08:02:00.863 LUA: DBNwNQkSGQEoAAAAzQwU7Z0JElkBJgAAAL0LE4YvCRIZACgAzQALE4ZeCRIZACIAAAALFVXz8RoZACIAtwALDrjoCRIZZCgAAAAMFPDNCRIZASgAAAC1DBNwhAkSGQEiAAAArQ==
2016-11-03 08:02:00.863 LUA: Valve V-Bed-Rad Setpoint=17 Temp=18.3 Valve pos=0
2016-11-03 08:02:00.863 LUA: No device Kitchen-Rad (Valve)
2016-11-03 08:02:00.864 LUA: Valve Kitchen-Rad Setpoint=20 Temp=0 Valve pos=100
2016-11-03 08:02:00.864 LUA: No device Kitchen-Stat (Valve)
2016-11-03 08:02:00.864 LUA: DBNwNQkSGQEoAAAAzQwU7Z0JElkBJgAAAL0LE4YvCRIZACgAzQALE4ZeCRIZACIAAAALFVXz8RoZACIAtwALDrjoCRIZZCgAAAAMFPDNCRIZASgAAAC1DBNwhAkSGQEiAAAArQ==
2016-11-03 08:02:00.864 LUA: Thermostat Kitchen-Stat Setpoint=20 Temp=18.1 Valve pos=-1
2016-11-03 08:02:00.864 LUA: No device Z-Bed-Stat (Valve)
