I am unable to set a new mode for my RFXCom from Domoticz - other than that RFXCom is working fine receiving and transmitting ok.
If I click the 'Set Mode' button it dumps me back to the Dashboard with no changes to the ticked protocols.
I see the following lines in the log:
subtype = Interface Command
Sequence nbr = 11
set configuration of the interface
2016-11-01 22:25:54.087 Error: RFXCOM: Invalid data received!....
2016-11-01 22:25:54.339 Error: RFXCOM: Invalid data received!..
Running v3.5837 on Ubuntu Linux 14.04 RFXcom Firmware 246
Unable to set Mode on RFXCom
noddy119
- Domoticz version: 3.5837
Last edited by noddy119 on Tuesday 01 November 2016 23:49, edited 1 time in total.
- felix63
- Domoticz version: 2020.1
Re: Unable to set Mode on RFXCom
I had the same issue after updating Domoticz. It went away after updating the firmware on my RFXCom. Still have other problems with RFXCom,
noddy119
Thanks Felix63 -I updated to firmware 1008 and it works. However 1008 doesn't receive my Alecto WS1700 temperature sensors. Domoticz doesn't like the 251 or similar firmware's - it mis-reports the firmware version as well as the inability to set modes as in my original post. To get round the issue I think i can set the RFXcom protocols on my windows PC and make sure it is receiving all my devices, then plug back in to my linux box.
I am not sure why there are different RFXcom firmware variants?
- felix63
if you read the manual you'll see there are two types of devices 433 and 433E. For both types there are two different firmware versions. In my case I could choose between EXT and EXT2. In the manual you can see that each version supports a different combination of devices.
The Alecto WS1700 is reported to work with both firmware version but only on the RFXtrx433E.
Verzonden vanaf mijn iPad met Tapatalk
