Does anyone know if this one is supported? It's cheap and support 8 channels!
https://www.conrad.nl/nl/thermo-en-hygr ... 25532.html
What I found about it:
http://www.uctechnologyltd.com/en/produ ... &sortid=81
http://www.uctechnologyltd.com/product/ ... 949560.xls
Grtz,
Pim
8 channel sensor FT007TH
- Target OS: -
Re: 8 channel sensor FT007TH
Better check bweienberg's site for the usermanual when you use the rfxtrx*** receiver/transmitter(s).
Out of my head there are a few sensors mentioned as supported with the sources from eg. Conrad and banggood.
Looking at the image it has some summularities with Cresta and Alecto sensors.
Check Conrad's returnoptions and buy & try
Sent from my D6603 using Tapatalk
- Stuntteam
The RFLink gateway supports the F007 / FT007 range of products sold under various brand names like Ambient Weather, Frogit, Renkforce..
Thus when you use an RFLink it works in Domoticz.
- Target OS: -
Re: RE: Re: 8 channel sensor FT007TH
I believe this is the DIY 433MHz device with an Arduino, right?Stuntteam wrote:The RFLink gateway supports the F007 / FT007 range of products sold under various brand names like Ambient Weather, Frogit, Renkforce..
- Stuntteam
Yes, you can either setup an arduino with some components or get a kit.
The RFLink firmware is the most complete and modular solution that exists when it comes to RF gateways.
- Target OS: -
Hmm maybe. But i own the rfxtrx433e already. In combination with a Hue Bridge.
So i think i wouldn't spend another buck fir niw, but keep my mind open for it.
Thanx for replies. I use the RFXCOM RFXtrx433E and Domoticz on a RPi.
I think I indeed buy and try. Unfortunatly new stock is expected in 5 weeks, so we have to wait. I'll let you know the results.
I'm afraid I don't know and can't find the 'bweienberg's site', but at rfxcom.com in the latest manual I can't find anything according to this.stlaha2007 wrote:Better check bweienberg's site for the usermanual when you use the rfxtrx*** receiver/transmitter(s).
Hi, Im new to this forum and in fact to Domoticz and home auto devices BUT found it very interesting and.. alrady started to build up own "auto-system".
So, system already running on: RFLink+Arduino+W8 (W10 and OSX Sierra checked to be working OK as well). As I thought Temp devices will be the most easy one to start work with so, I have started with FT007TH (renkforce / conrad)
AND... well - I could see all possible temp / weather devices all around (my neighbours) but no FT007TH. I have checked all channels (8 this device) and no success. Are there any good ways to check this sensor working? My plan was to add 4 sensors but Im afraid this model is not the best one... all ideas are most welcome
[2017-02-12] UPDATE: latest version of RFLink software makes it woring!!
Problem solved - FT007TH is working with DOMOTICZ
