I have domoticz controlling my floor heating, switching on and off the circulation pump based on ingoing temperature in to header from a blocky script. Now this works OK but I rather have it based on differential temperature between in and outlet, which is not dependent on the ambient temperature.
I have an ESP8266 running ESP_EASY with 2 DS18B20's reading 'Aanvoertemp VVW' en 'Afvoertemp VVW' from the header.
Now I cannot calculate the difference in blocky sadly so I need some other measures...
Could anyone point me out how to generate a variable 'DeltaT' in a LUA script which I can use in blocky for switching the pump ??
Thanks !
lua through blocky
reddo
lua through blocky
-Domoticz-RFLink-PVoutput-Solarmeter-SBFSpot-ESPEasy-Volumio with spotify connect-
- Egregius
- Domoticz version: v2024.7
Re: lua through blocky
Why not do everything in lua, php or any other language?
Nlovlky is for simple things.
reddo
Because I have no clue how to do that. Blocky is workable for me, programming is sadly not my best side....
- Egregius
In PHP it's as simple as
$DeltaT=$AanvoertempVVW-$AfvoertempVVW
In Lua? I have no clue at all. I control everything with one php script.
