Qubino thermostat defaulting set point
- Domoticz version: 3.6857
Seem to have an issue with a replacement stat i have just received.
The last one worked fine, pop a setpoint temperature in and away it went but the z-wave died on it.
The replacement seems really stubbon.
I need the set point at 45.0c (tried 45, 450/everything really) but whatever i put in, it then defaults seconds later to 23.0c.
Anyone know something i don't about these stat's?
ZMNHIDX is the model.
Cheers all
Stu
Sent from my SM-G925F using Tapatalk
Cheers all
Stu
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
Hi thats funny, mine just stopped working yesterday evening... if I write a set point it immediately switches back to 0.00. And I'm not able to set the Mode to heat..
It's looking to me that something is changed since the last update?
Some weeks ago I could set the MODE: auto/off
And now the mode has changed in off/heat
The same for the HEATING 1 is now Unused 0?
Before
After (now)
Before
After (now)
Re: Qubino thermostat defaulting set point
Yeah i'm seeing the same. The old thermostat was Auto/off and it's now Heat/off (preferred the old wording myself- more accurate).
Maybe we may need to raise an issue in github for this then?
I have since added a issue.
https://github.com/domoticz/domoticz/issues/934
I presume you update to beta's often?
Yes I'm running Domoticz on a Pi 2 with Razberry 2.0 on latest beta.. thanks for placing the issue and let's hope it will be solved soon.
In the meantime we don't have warm water in our house....
sorry to jump in on this as well but my thermostat also has Heat/off mode (which I currently do not use)
Can anyone explain this function / use?
But can you confirm your thermostat is still working?fergalom wrote:sorry to jump in on this as well but my thermostat also has Heat/off mode (which I currently do not use)
yes definitely working, was just curious if I was missing out on additional functionality
Using:
Horstman SRT321 Thermostat
Horstman SSR302 2 channel boiler relay for heat / hot water
All thermostat modes are "off" on the devices tab
Using:
Thanks for confirming but your not using the qubino ZMNHIDx where we have problems with.
But I assume that your thermostat have been changed in the OZW configuration panel as well?
I realise that but my question as I said was what is the function of Heat/off mode in these thermostats?
As far as I remember, it was always Heat/off and my heating 1 remains the same
Today I made a bypass because my girlfriend was very mad about not having warm water in our kitchen, hope there will be a solution asap.
Verzonden vanaf mijn iPad met Tapatalk
Gizmocuz has added a openzwave file that restores the old behaviour of the relay.
(its in latest beta).
I installed it, excluded node, added node but seem to still have the same problem.
2 links for you to look at:-
https://github.com/OpenZWave/open-zwave ... a9b463f820
and a further Domoticz forum thread (but in bugs).
http://www.domoticz.com/forum/viewtopic.php?f=6&t=13925
Thanks a lot! I noticed yesterday evening and have just exclude and include my thermostat. It look like it's working again.stuiow wrote:Gizmocuz has added a openzwave file that restores the old behaviour of the relay.
Accept when I change any configuration in the config. Then Dominicz crashes...
I get the same error when trying to change Hystersis
Any change on this?
I had given up on the quibno's ability to change its on switch, so i popped another relay in instead.
I still use the Qubno's temperature reading but from there, i use Domoticz to detect and switch the secondary relay on which operates my heating pump.
Same issue with mine Qubino ZMNHIDx(H1S1P), Domoticz 3.5877
The issue is "back" again
. After beta update from today. When changing a random setting of the thermostat it's crashing the domoticz server
. You guys experiencing the same?
