Zigbee gateway
vanbako
Zigbee gateway
Post by vanbako »
I've created a zigbee gateway, harware is raspberry pi with atsamr21 connected through usb.
Using perl to expose commands in a simple json api.
It's a work in progress, it works with Osram lightify Lights and self made sensor devices.
Can I integrate this easily in Domoticz?
Derik
Re: Zigbee gateway
Post by Derik »
great.....
What is the hardware that i need to buy...
Do you have other sensor with Zigbee that i can buy?
vanbako
Re: Zigbee gateway
Post by vanbako »
I use the Atmel ATSAMR21-XPRO Evaluation Board, one as gateway and one as coordinator (combined interface), both connected with usb to the raspberry pi.
I tested with Wink and the Lightify HUB, and that works as well. (I present the gateway as a generic zigbee on/off light)
Keep in mind that it's still a work in progress.
For the sensor, I'm currently using the same atmel evaluation board and a BME280 sensor from Bosch.
I plan to make boards with the ATSAMR21B18-MZ210PA module, but that might take some time to finish.
vanbako
Re: Zigbee gateway
Post by vanbako »
I made the lights work with dummy hardware, create manual light/switch, then edit the light.
For On and Off Action:
http://<ip>:<port>/ep/setOn/de58+03
http://<ip>:<port>/ep/setOff/de58+03
Where de58 (hex) is the zigbee short address of the light and 03 (hex) the endpoint number.
It works with a group as well:
http://<ip>:<port>/group/setOn/0006
http://<ip>:<port>/group/setOff/0006
Where 0006 (hex) is the zigbee group number
Derik
Re: Zigbee gateway
Post by Derik »
Dear vanbako..
What is the status of your project?
