Shutdown domoticz pi
Maybe its in the wrong subforum, excuse me for that but I dont know exactly what should then be the right one.
I would like to create a shutdown switch, to shutdown the rpi with domoticz itself. I dont know if that is possible, but its also shitty to shut it down by a command (sudo poweroff) as I dont have a display/keyboard on the pi.
Is it possible to do that and how?
Raspberry Pi 2 model B with domoticz
OMV NAS installed on thin client HP T610
Openelec Kodi Mediaplayer on thin client HP T520 (and with multiboot windows 10)
- Domoticz version: V3.4964
Re: Shutdown domoticz pi
why don't you just ssh into your pi like the rest of the world?
Windows Server, Aeotec Z-Stick Gen5, V3.4964
Well, because I have to start my laptop, and so on.
Its easier to do it by the domoticz app on my phone. Why not automate it.
- Domoticz version: v3.8975
Yes, it is possible. You have to come up with your own script (as demon) and as soon as you issue a command, which can be adopted as a virtual sensor in Domoticz, RPI will be reboot/shutdown.
Please see below:
https://lowpowerlab.com/guide/atxraspi/
Please see below:
- Egregius
- Domoticz version: v2024.7
http://192.168.2.10:8084/json.htm?type=command¶m=system_shutdown
- Domoticz version: 2022.2
I have a reboot button on my frontpage.
Where in which gui do yo see this?Egregius wrote:should do it as that is the url that the www gui calls.Code: Select all
I cant find it in the webgui of domoticz?
- Egregius
I have a restart and shutdown option in the menu.
Then used feveloper view of my browser to see the url.
Ok but I dont, domoticz is running on a rpi.
How can I get that options?
Hm, I run domoticz on a pi. The restart in somewhere in the lower part of the settings menu
I found it now, on my laptop resolution 1366x768 the bottom of the options menu are not visible.
I connected a larger external screen and now I see them.
In the dev view the link is this: <a id="cShutdown" href="javascript:SwitchLayout('Shutdown')"><img src="images/shutdown.png"> <span data-i18n="Shutdown System">Computer afsluiten</span></a>
How can I use this on a switch, it cant because its html ...
- Egregius
The link is as I posted it earlier.
You need to open the network tab of develover view and click the button to see the action.
Just a normal switch command in the screenshot, shutdown url posted above
The info is also in wiki as far as I remember
ok, i created a switch, push off button and gave it an off action http://192.168.1.14/json.htm?type=comma ... m_shutdown
But nothing happens...
- Egregius
Logfile? Authentication?
I only get these :
I have to log in, in my webgui.
2016-10-19 20:34:35.928 Error: Error opening url: http://192.168.1.14/json.htm?type=command¶m=system_reboot
- Egregius
Something is wrong with your url. 'Param' got replaced.
yeah I dont know why, @ the action is really typed http://192.168.1.14/json.htm?type=comma ... m_shutdown
Its solved, i'm really shaming myself, I forgot the :8080 port in the url.
