homebridge-edomoticz Plugin
rwijbenga
Re: homebridge-edomoticz Plugin
Post by rwijbenga »
@mazzokun
You are missing the MQTT part in the config.json. Take a look at the config.json example on the github page:
https://github.com/PatchworkBoy/homebridge-edomoticz
Add the missing lines to your config.json and it should work.. :ugeek:
TheRamon
Post by TheRamon »
@G3rard thank you so much. :)
rwijbenga wrote:I get an error about hardware:
   "message" : "Error sending switch command, check device/hardware !",
   "status" : "ERROR",
   "title" : "SwitchLight"
When I use this JSON command it changes the color:
http://domoticz_url:8080/json.htm?type=command&param=setcolbrightnessvalue&idx=291&hex=FFC700
Output:
   "status" : "OK",
   "title" : "SetColBrightnessValue"
I use the RFLink hardware in combination wit MiLight's. Maybe the JSON command are different? :?
Oh wow, that one changes colour? What's the first one then?
You changed the "param=switchlight" to param="setcolbrightnessvalue", and dropped "switchcmd=" alltogether right?
Mazzokun
Post by Mazzokun »
I reinstalled and followed the readme into repo https://github.com/PatchworkBoy/homebri ... stallGuide but it doesn't work :(
pi@raspberrypi:~/domoticz $ sudo apt-get install -y build-essential python-rpi.gpio nodejs
Reading package lists... Done
Building dependency tree
Reading state information... Done
build-essential is already the newest version.
nodejs is already the newest version.
nodejs set to manually installed.
python-rpi.gpio is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~/domoticz $ sudo apt-get install libavahi-compat-libdnssd-dev
The following extra packages will be installed:
  libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd1 libdbus-1-dev
The following NEW packages will be installed:
  libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libdbus-1-dev
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 401 kB of archives.
After this operation, 1,160 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-compat-libdnssd1 armhf 0.6.31-5 [42.9 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-common-dev armhf 0.6.31-5 [61.4 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main libdbus-1-dev armhf 1.8.20-0+deb8u1 [184 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-client-dev armhf 0.6.31-5 [55.4 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-compat-libdnssd-dev armhf 0.6.31-5 [57.7 kB]
Fetched 401 kB in 1s (286 kB/s)
Selecting previously unselected package libavahi-compat-libdnssd1:armhf.
(Reading database ... 121774 files and directories currently installed.)
Preparing to unpack .../libavahi-compat-libdnssd1_0.6.31-5_armhf.deb ...
Unpacking libavahi-compat-libdnssd1:armhf (0.6.31-5) ...
Selecting previously unselected package libavahi-common-dev.
Preparing to unpack .../libavahi-common-dev_0.6.31-5_armhf.deb ...
Unpacking libavahi-common-dev (0.6.31-5) ...
Selecting previously unselected package libdbus-1-dev:armhf.
Preparing to unpack .../libdbus-1-dev_1.8.20-0+deb8u1_armhf.deb ...
Unpacking libdbus-1-dev:armhf (1.8.20-0+deb8u1) ...
Selecting previously unselected package libavahi-client-dev.
Preparing to unpack .../libavahi-client-dev_0.6.31-5_armhf.deb ...
Unpacking libavahi-client-dev (0.6.31-5) ...
Selecting previously unselected package libavahi-compat-libdnssd-dev.
Preparing to unpack .../libavahi-compat-libdnssd-dev_0.6.31-5_armhf.deb ...
Unpacking libavahi-compat-libdnssd-dev (0.6.31-5) ...
Setting up libavahi-compat-libdnssd1:armhf (0.6.31-5) ...
Setting up libavahi-common-dev (0.6.31-5) ...
Setting up libdbus-1-dev:armhf (1.8.20-0+deb8u1) ...
Setting up libavahi-client-dev (0.6.31-5) ...
Setting up libavahi-compat-libdnssd-dev (0.6.31-5) ...
Processing triggers for libc-bin (2.19-18+deb8u6) ...
pi@raspberrypi:~/domoticz $ sudo apt-get install git
git is already the newest version.
git set to manually installed.
pi@raspberrypi:~/domoticz $ sudo apt-get install mosquitto
  mosquitto
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 101 kB of archives.
After this operation, 190 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main mosquitto armhf 1.3.4-2 [101 kB]
Fetched 101 kB in 0s (136 kB/s)
Selecting previously unselected package mosquitto.
(Reading database ... 121863 files and directories currently installed.)
Preparing to unpack .../mosquitto_1.3.4-2_armhf.deb ...
Unpacking mosquitto (1.3.4-2) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for systemd (215-17+deb8u5) ...
Setting up mosquitto (1.3.4-2) ...
pi@raspberrypi:~/domoticz $ sudo npm install -g node-red --unsafe-perm
sudo: npm: command not found
pi@raspberrypi:~/domoticz $ sudo apt-get install npm
  gyp libc-ares-dev libjs-node-uuid libssl-dev libssl-doc libv8-3.14-dev node-abbrev node-ansi node-ansi-color-table node-archy
  node-async node-block-stream node-combined-stream node-cookie-jar node-delayed-stream node-forever-agent node-form-data
  node-fstream node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs node-gyp node-inherits node-ini
  node-json-stringify-safe node-lockfile node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid
  node-nopt node-normalize-package-data node-npmlog node-once node-osenv node-qs node-read node-read-package-json node-request
  node-retry node-rimraf node-semver node-sha node-sigmund node-slide node-tar node-tunnel-agent node-underscore node-which
  nodejs-dev
Suggested packages:
  node-hawk node-aws-sign node-oauth-sign node-http-signature
  nodejs-dev npm
0 upgraded, 54 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,689 kB of archives.
After this operation, 13.3 MB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main gyp all 0.1~svn1729-3 [201 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libjs-node-uuid all 1.4.0-1 [12.6 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-dev armhf 1.0.1t-1+deb8u5 [1,094 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-doc all 1.0.1t-1+deb8u5 [1,167 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main libv8-3.14-dev armhf 3.14.5.8-8.1+rpi1 [108 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-async all 0.8.0-1 [24.6 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-node-uuid all 1.4.0-1 [9,194 B]
Get:8 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-underscore all 1.7.0~dfsg-1 [34.2 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc-ares-dev armhf 1.10.0-2+deb8u1 [131 kB]
Get:10 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-abbrev all 1.0.5-2 [3,540 B]
Get:11 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-ansi all 0.3.0-2 [8,608 B]
Get:12 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-ansi-color-table all 1.0.0-1 [4,408 B]
Get:13 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-archy all 0.0.2-1 [3,620 B]
Get:14 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-inherits all 2.0.1-1 [3,230 B]
Get:15 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-block-stream all 0.0.7-1 [4,550 B]
Get:16 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-delayed-stream all 0.0.5-1 [4,482 B]
Get:17 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-combined-stream all 0.0.5-1 [4,918 B]
Get:18 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-cookie-jar all 0.3.1-1 [3,570 B]
Get:19 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-forever-agent all 0.5.1-1 [3,066 B]
Get:20 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-mime all 1.2.11-1 [18.1 kB]
Get:21 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-form-data all 0.1.0-1 [6,084 B]
Get:22 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-rimraf all 2.2.8-1 [5,668 B]
Get:23 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-mkdirp all 0.5.0-1 [4,634 B]
Get:24 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-graceful-fs all 3.0.2-1 [7,070 B]
Get:25 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-fstream all 0.1.24-1 [17.5 kB]
Get:26 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-lru-cache all 2.3.1-1 [5,344 B]
Get:27 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-sigmund all 1.0.0-1 [3,750 B]
Get:28 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-minimatch all 1.0.0-1 [13.9 kB]
Get:29 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-fstream-ignore all 0.0.6-2 [5,536 B]
Get:30 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-github-url-from-git all 1.1.1-1 [2,986 B]
Get:31 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-once all 1.1.1-1 [2,552 B]
Get:32 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-glob all 4.0.5-1 [13.1 kB]
Get:33 http://mirrordirector.raspbian.org/raspbian/ jessie/main nodejs-dev armhf 0.10.29~dfsg-2 [247 kB]
Get:34 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-nopt all 3.0.1-1 [9,484 B]
Get:35 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-npmlog all 0.0.4-1 [5,516 B]
Get:36 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-osenv all 0.1.0-1 [3,734 B]
Get:37 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-tunnel-agent all 0.3.1-1 [3,840 B]
Get:38 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-json-stringify-safe all 5.0.0-1 [3,356 B]
Get:39 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-qs all 2.2.4-1 [8,474 B]
Get:40 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-request all 2.26.1-1 [15.7 kB]
Get:41 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-semver all 2.1.0-2 [14.9 kB]
Get:42 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-tar all 0.1.18-1 [16.9 kB]
Get:43 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-which all 1.0.5-2 [3,610 B]
Get:44 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-gyp all 0.12.2+ds-1 [19.4 kB]
Get:45 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-ini all 1.1.0-1 [4,720 B]
Get:46 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-lockfile all 0.4.1-1 [5,150 B]
Get:47 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-mute-stream all 0.0.4-1 [4,056 B]
Get:48 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-normalize-package-data all 0.2.2-1 [8,604 B]
Get:49 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-read all 1.0.5-1 [4,262 B]
Get:50 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-read-package-json all 1.2.4-1 [7,740 B]
Get:51 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-retry all 0.6.0-1 [6,124 B]
Get:52 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-sha all 1.2.3-1 [4,064 B]
Get:53 http://mirrordirector.raspbian.org/raspbian/ jessie/main node-slide all 1.1.4-1 [6,078 B]
Get:54 http://mirrordirector.raspbian.org/raspbian/ jessie/main npm all 1.4.21+ds-2 [354 kB]
Fetched 3,689 kB in 10s (347 kB/s)
Extracting templates from packages: 100%
Selecting previously unselected package gyp.
(Reading database ... 121893 files and directories currently installed.)
Preparing to unpack .../gyp_0.1~svn1729-3_all.deb ...
Unpacking gyp (0.1~svn1729-3) ...
Selecting previously unselected package libjs-node-uuid.
Preparing to unpack .../libjs-node-uuid_1.4.0-1_all.deb ...
Unpacking libjs-node-uuid (1.4.0-1) ...
Selecting previously unselected package libssl-dev:armhf.
Preparing to unpack .../libssl-dev_1.0.1t-1+deb8u5_armhf.deb ...
Unpacking libssl-dev:armhf (1.0.1t-1+deb8u5) ...
Selecting previously unselected package libssl-doc.
Preparing to unpack .../libssl-doc_1.0.1t-1+deb8u5_all.deb ...
Unpacking libssl-doc (1.0.1t-1+deb8u5) ...
Selecting previously unselected package libv8-3.14-dev.
Preparing to unpack .../libv8-3.14-dev_3.14.5.8-8.1+rpi1_armhf.deb ...
Unpacking libv8-3.14-dev (3.14.5.8-8.1+rpi1) ...
Selecting previously unselected package node-async.
Preparing to unpack .../node-async_0.8.0-1_all.deb ...
Unpacking node-async (0.8.0-1) ...
Selecting previously unselected package node-node-uuid.
Preparing to unpack .../node-node-uuid_1.4.0-1_all.deb ...
Unpacking node-node-uuid (1.4.0-1) ...
Selecting previously unselected package node-underscore.
Preparing to unpack .../node-underscore_1.7.0~dfsg-1_all.deb ...
Unpacking node-underscore (1.7.0~dfsg-1) ...
Selecting previously unselected package libc-ares-dev:armhf.
Preparing to unpack .../libc-ares-dev_1.10.0-2+deb8u1_armhf.deb ...
Unpacking libc-ares-dev:armhf (1.10.0-2+deb8u1) ...
Selecting previously unselected package node-abbrev.
Preparing to unpack .../node-abbrev_1.0.5-2_all.deb ...
Unpacking node-abbrev (1.0.5-2) ...
Selecting previously unselected package node-ansi.
Preparing to unpack .../node-ansi_0.3.0-2_all.deb ...
Unpacking node-ansi (0.3.0-2) ...
Selecting previously unselected package node-ansi-color-table.
Preparing to unpack .../node-ansi-color-table_1.0.0-1_all.deb ...
Unpacking node-ansi-color-table (1.0.0-1) ...
Selecting previously unselected package node-archy.
Preparing to unpack .../node-archy_0.0.2-1_all.deb ...
Unpacking node-archy (0.0.2-1) ...
Selecting previously unselected package node-inherits.
Preparing to unpack .../node-inherits_2.0.1-1_all.deb ...
Unpacking node-inherits (2.0.1-1) ...
Selecting previously unselected package node-block-stream.
Preparing to unpack .../node-block-stream_0.0.7-1_all.deb ...
Unpacking node-block-stream (0.0.7-1) ...
Selecting previously unselected package node-delayed-stream.
Preparing to unpack .../node-delayed-stream_0.0.5-1_all.deb ...
Unpacking node-delayed-stream (0.0.5-1) ...
Selecting previously unselected package node-combined-stream.
Preparing to unpack .../node-combined-stream_0.0.5-1_all.deb ...
Unpacking node-combined-stream (0.0.5-1) ...
Selecting previously unselected package node-cookie-jar.
Preparing to unpack .../node-cookie-jar_0.3.1-1_all.deb ...
Unpacking node-cookie-jar (0.3.1-1) ...
Selecting previously unselected package node-forever-agent.
Preparing to unpack .../node-forever-agent_0.5.1-1_all.deb ...
Unpacking node-forever-agent (0.5.1-1) ...
Selecting previously unselected package node-mime.
Preparing to unpack .../node-mime_1.2.11-1_all.deb ...
Unpacking node-mime (1.2.11-1) ...
Selecting previously unselected package node-form-data.
Preparing to unpack .../node-form-data_0.1.0-1_all.deb ...
Unpacking node-form-data (0.1.0-1) ...
Selecting previously unselected package node-rimraf.
Preparing to unpack .../node-rimraf_2.2.8-1_all.deb ...
Unpacking node-rimraf (2.2.8-1) ...
Selecting previously unselected package node-mkdirp.
Preparing to unpack .../node-mkdirp_0.5.0-1_all.deb ...
Unpacking node-mkdirp (0.5.0-1) ...
Selecting previously unselected package node-graceful-fs.
Preparing to unpack .../node-graceful-fs_3.0.2-1_all.deb ...
Unpacking node-graceful-fs (3.0.2-1) ...
Selecting previously unselected package node-fstream.
Preparing to unpack .../node-fstream_0.1.24-1_all.deb ...
Unpacking node-fstream (0.1.24-1) ...
Selecting previously unselected package node-lru-cache.
Preparing to unpack .../node-lru-cache_2.3.1-1_all.deb ...
Unpacking node-lru-cache (2.3.1-1) ...
Selecting previously unselected package node-sigmund.
Preparing to unpack .../node-sigmund_1.0.0-1_all.deb ...
Unpacking node-sigmund (1.0.0-1) ...
Selecting previously unselected package node-minimatch.
Preparing to unpack .../node-minimatch_1.0.0-1_all.deb ...
Unpacking node-minimatch (1.0.0-1) ...
Selecting previously unselected package node-fstream-ignore.
Preparing to unpack .../node-fstream-ignore_0.0.6-2_all.deb ...
Unpacking node-fstream-ignore (0.0.6-2) ...
Selecting previously unselected package node-github-url-from-git.
Preparing to unpack .../node-github-url-from-git_1.1.1-1_all.deb ...
Unpacking node-github-url-from-git (1.1.1-1) ...
Selecting previously unselected package node-once.
Preparing to unpack .../node-once_1.1.1-1_all.deb ...
Unpacking node-once (1.1.1-1) ...
Selecting previously unselected package node-glob.
Preparing to unpack .../node-glob_4.0.5-1_all.deb ...
Unpacking node-glob (4.0.5-1) ...
Selecting previously unselected package nodejs-dev.
Preparing to unpack .../nodejs-dev_0.10.29~dfsg-2_armhf.deb ...
Unpacking nodejs-dev (0.10.29~dfsg-2) ...
Selecting previously unselected package node-nopt.
Preparing to unpack .../node-nopt_3.0.1-1_all.deb ...
Unpacking node-nopt (3.0.1-1) ...
Selecting previously unselected package node-npmlog.
Preparing to unpack .../node-npmlog_0.0.4-1_all.deb ...
Unpacking node-npmlog (0.0.4-1) ...
Selecting previously unselected package node-osenv.
Preparing to unpack .../node-osenv_0.1.0-1_all.deb ...
Unpacking node-osenv (0.1.0-1) ...
Selecting previously unselected package node-tunnel-agent.
Preparing to unpack .../node-tunnel-agent_0.3.1-1_all.deb ...
Unpacking node-tunnel-agent (0.3.1-1) ...
Selecting previously unselected package node-json-stringify-safe.
Preparing to unpack .../node-json-stringify-safe_5.0.0-1_all.deb ...
Unpacking node-json-stringify-safe (5.0.0-1) ...
Selecting previously unselected package node-qs.
Preparing to unpack .../node-qs_2.2.4-1_all.deb ...
Unpacking node-qs (2.2.4-1) ...
Selecting previously unselected package node-request.
Preparing to unpack .../node-request_2.26.1-1_all.deb ...
Unpacking node-request (2.26.1-1) ...
Selecting previously unselected package node-semver.
Preparing to unpack .../node-semver_2.1.0-2_all.deb ...
Unpacking node-semver (2.1.0-2) ...
Selecting previously unselected package node-tar.
Preparing to unpack .../node-tar_0.1.18-1_all.deb ...
Unpacking node-tar (0.1.18-1) ...
Selecting previously unselected package node-which.
Preparing to unpack .../node-which_1.0.5-2_all.deb ...
Unpacking node-which (1.0.5-2) ...
Selecting previously unselected package node-gyp.
Preparing to unpack .../node-gyp_0.12.2+ds-1_all.deb ...
Unpacking node-gyp (0.12.2+ds-1) ...
Selecting previously unselected package node-ini.
Preparing to unpack .../node-ini_1.1.0-1_all.deb ...
Unpacking node-ini (1.1.0-1) ...
Selecting previously unselected package node-lockfile.
Preparing to unpack .../node-lockfile_0.4.1-1_all.deb ...
Unpacking node-lockfile (0.4.1-1) ...
Selecting previously unselected package node-mute-stream.
Preparing to unpack .../node-mute-stream_0.0.4-1_all.deb ...
Unpacking node-mute-stream (0.0.4-1) ...
Selecting previously unselected package node-normalize-package-data.
Preparing to unpack .../node-normalize-package-data_0.2.2-1_all.deb ...
Unpacking node-normalize-package-data (0.2.2-1) ...
Selecting previously unselected package node-read.
Preparing to unpack .../node-read_1.0.5-1_all.deb ...
Unpacking node-read (1.0.5-1) ...
Selecting previously unselected package node-read-package-json.
Preparing to unpack .../node-read-package-json_1.2.4-1_all.deb ...
Unpacking node-read-package-json (1.2.4-1) ...
Selecting previously unselected package node-retry.
Preparing to unpack .../node-retry_0.6.0-1_all.deb ...
Unpacking node-retry (0.6.0-1) ...
Selecting previously unselected package node-sha.
Preparing to unpack .../node-sha_1.2.3-1_all.deb ...
Unpacking node-sha (1.2.3-1) ...
Selecting previously unselected package node-slide.
Preparing to unpack .../node-slide_1.1.4-1_all.deb ...
Unpacking node-slide (1.1.4-1) ...
Selecting previously unselected package npm.
Preparing to unpack .../npm_1.4.21+ds-2_all.deb ...
Unpacking npm (1.4.21+ds-2) ...
Setting up gyp (0.1~svn1729-3) ...
Setting up libjs-node-uuid (1.4.0-1) ...
Setting up libssl-dev:armhf (1.0.1t-1+deb8u5) ...
Setting up libssl-doc (1.0.1t-1+deb8u5) ...
Setting up libv8-3.14-dev (3.14.5.8-8.1+rpi1) ...
Setting up node-async (0.8.0-1) ...
Setting up node-node-uuid (1.4.0-1) ...
Setting up node-underscore (1.7.0~dfsg-1) ...
Setting up libc-ares-dev:armhf (1.10.0-2+deb8u1) ...
Setting up node-abbrev (1.0.5-2) ...
Setting up node-ansi (0.3.0-2) ...
Setting up node-ansi-color-table (1.0.0-1) ...
Setting up node-archy (0.0.2-1) ...
Setting up node-inherits (2.0.1-1) ...
Setting up node-block-stream (0.0.7-1) ...
Setting up node-delayed-stream (0.0.5-1) ...
Setting up node-combined-stream (0.0.5-1) ...
Setting up node-cookie-jar (0.3.1-1) ...
Setting up node-forever-agent (0.5.1-1) ...
Setting up node-mime (1.2.11-1) ...
Setting up node-form-data (0.1.0-1) ...
Setting up node-rimraf (2.2.8-1) ...
Setting up node-mkdirp (0.5.0-1) ...
Setting up node-graceful-fs (3.0.2-1) ...
Setting up node-fstream (0.1.24-1) ...
Setting up node-lru-cache (2.3.1-1) ...
Setting up node-sigmund (1.0.0-1) ...
Setting up node-minimatch (1.0.0-1) ...
Setting up node-fstream-ignore (0.0.6-2) ...
Setting up node-github-url-from-git (1.1.1-1) ...
Setting up node-once (1.1.1-1) ...
Setting up node-glob (4.0.5-1) ...
Setting up nodejs-dev (0.10.29~dfsg-2) ...
Setting up node-nopt (3.0.1-1) ...
Setting up node-npmlog (0.0.4-1) ...
Setting up node-osenv (0.1.0-1) ...
Setting up node-tunnel-agent (0.3.1-1) ...
Setting up node-json-stringify-safe (5.0.0-1) ...
Setting up node-qs (2.2.4-1) ...
Setting up node-request (2.26.1-1) ...
Setting up node-semver (2.1.0-2) ...
Setting up node-tar (0.1.18-1) ...
Setting up node-which (1.0.5-2) ...
Setting up node-gyp (0.12.2+ds-1) ...
Setting up node-ini (1.1.0-1) ...
Setting up node-lockfile (0.4.1-1) ...
Setting up node-mute-stream (0.0.4-1) ...
Setting up node-normalize-package-data (0.2.2-1) ...
Setting up node-read (1.0.5-1) ...
Setting up node-read-package-json (1.2.4-1) ...
Setting up node-retry (0.6.0-1) ...
Setting up node-sha (1.2.3-1) ...
Setting up node-slide (1.1.4-1) ...
Setting up npm (1.4.21+ds-2) ...
npm WARN engine [email protected]: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine [email protected]: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
> [email protected] install /usr/local/lib/node_modules/node-red/node_modules/bcrypt
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/bcrypt/build'
  CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
  CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
  CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt_node.o
In file included from ../src/bcrypt_node.cc:1:0:
../node_modules/nan/nan.h:324:47: error: ‘REPLACE_INVALID_UTF8’ is not a member of ‘v8::String’
   static const unsigned kReplaceInvalidUtf8 = v8::String::REPLACE_INVALID_UTF8;
bcrypt_lib.target.mk:84: recipe for target 'Release/obj.target/bcrypt_lib/src/bcrypt_node.o' failed
make: *** [Release/obj.target/bcrypt_lib/src/bcrypt_node.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/bcrypt/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack     at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
gyp ERR! stack     at ChildProcess.emit (events.js:98:17)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:809:12)
gyp ERR! System Linux 4.4.26-v7+
gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/bcrypt
gyp ERR! node -v v0.10.29
gyp ERR! node-gyp -v v0.12.2
gyp ERR! not ok
npm WARN engine [email protected]: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN deprecated [email protected]: you can use npm install i18next from version 2.0.0
npm WARN This failure might be due to the use of legacy binary "node"
npm WARN For further explanations, please read
/usr/share/doc/nodejs/README.Debian
> [email protected] install /usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/utf-8-validate
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/utf-8-validate/build'
  CXX(target) Release/obj.target/validation/src/validation.o
In file included from ../src/validation.cc:15:0:
validation.target.mk:84: recipe for target 'Release/obj.target/validation/src/validation.o' failed
make: *** [Release/obj.target/validation/src/validation.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/utf-8-validate/build'
gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/utf-8-validate
gyp ERR! not ok
npm WARN optional dep failed, continuing [email protected]
> [email protected] install /usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/bufferutil
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/bufferutil/build'
  CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
In file included from ../src/bufferutil.cc:16:0:
bufferutil.target.mk:84: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/bufferutil/build'
gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/ws/node_modules/bufferutil
gyp ERR! not ok
> [email protected] install /usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport
> node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v11-linux-arm.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for [email protected] and [email protected] (node-v11 ABI) (falling back to source compile with node-gyp)
make: Entering directory '/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build'
  CXX(target) Release/obj.target/serialport/src/serialport.o
In file included from ../src/./serialport.h:7:0,
                 from ../src/serialport.cpp:1:
serialport.target.mk:84: recipe for target 'Release/obj.target/serialport/src/serialport.o' failed
make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build'
gyp ERR! command "nodejs" "/usr/bin/node-gyp" "build" "--fallback-to-build" "--module=/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release"
gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute 'node-gyp build --fallback-to-build --module=/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/build/Release' (1)
node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:98:17)
node-pre-gyp ERR! stack     at maybeClose (child_process.js:755:16)
node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:822:5)
node-pre-gyp ERR! System Linux 4.4.26-v7+
node-pre-gyp ERR! command "node" "/usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/node-red/node_modules/node-red-node-serialport/node_modules/serialport
node-pre-gyp ERR! node -v v0.10.29
node-pre-gyp ERR! node-pre-gyp -v v0.6.28
node-pre-gyp ERR! not ok
/usr/local/bin/node-red -> /usr/local/lib/node_modules/node-red/red.js
/usr/local/bin/node-red-pi -> /usr/local/lib/node_modules/node-red/bin/node-red-pi
[email protected] /usr/local/lib/node_modules/node-red
├── [email protected]
├── [email protected] ([email protected])
├── [email protected] ([email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
└── [email protected] ([email protected])
pi@raspberrypi:~/domoticz $ sudo wget https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/nodered.service -O /lib/systemd/system/nodered.service
--2016-10-28 09:50:15--  https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/nodered.service
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.12.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.12.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 888 [text/plain]
Saving to: ‘/lib/systemd/system/nodered.service’
/lib/systemd/system/nodered.serv 100%[============================================================>]     888  --.-KB/s   in 0s
2016-10-28 09:50:15 (4.00 MB/s) - ‘/lib/systemd/system/nodered.service’ saved [888/888]
pi@raspberrypi:~/domoticz $ sudo wget https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/node-red-start -O /usr/bin/node-red-start
--2016-10-28 09:50:24--  https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/node-red-start
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.16.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.16.133|:443... connected.
Length: 1863 (1.8K) [text/plain]
Saving to: ‘/usr/bin/node-red-start’
/usr/bin/node-red-start          100%[============================================================>]   1.82K  --.-KB/s   in 0s
2016-10-28 09:50:25 (12.8 MB/s) - ‘/usr/bin/node-red-start’ saved [1863/1863]
pi@raspberrypi:~/domoticz $ sudo wget https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/node-red-stop -O /usr/bin/node-red-stop
--2016-10-28 09:50:29--  https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/node-red-stop
Length: 226 [text/plain]
Saving to: ‘/usr/bin/node-red-stop’
/usr/bin/node-red-stop           100%[============================================================>]     226  --.-KB/s   in 0s
2016-10-28 09:50:29 (94.0 MB/s) - ‘/usr/bin/node-red-stop’ saved [226/226]
pi@raspberrypi:~/domoticz $ sudo chmod +x /usr/bin/node-red-st*
pi@raspberrypi:~/domoticz $ sudo npm install -g homebridge --unsafe-perm
npm WARN engine [email protected]: wanted: {"node":">=4.3.2"} (current: {"node":"0.10.29","npm":"1.4.21"})
> [email protected] install /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n
> node-gyp rebuild
make: Entering directory '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n/build'
  CXX(target) Release/obj.target/curve/node_curve.o
In file included from ../node_curve.cc:9:0:
curve.target.mk:82: recipe for target 'Release/obj.target/curve/node_curve.o' failed
make: *** [Release/obj.target/curve/node_curve.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n/build'
cwd /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n
gyp ERR! not ok
> [email protected] install /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns
> node-gyp rebuild
gyp ERR! UNCAUGHT EXCEPTION
gyp ERR! stack Error: ENOENT, no such file or directory
gyp ERR! stack     at process.cwd (/usr/lib/nodejs/graceful-fs/polyfills.js:8:19)
gyp ERR! stack     at Object.exports.resolve (path.js:309:52)
gyp ERR! stack     at configure (/usr/share/node-gyp/lib/configure.js:26:23)
gyp ERR! stack     at Object.self.commands.(anonymous function) [as configure] (/usr/share/node-gyp/lib/node-gyp.js:66:37)
gyp ERR! stack     at run (/usr/share/node-gyp/bin/node-gyp.js:72:30)
gyp ERR! stack     at process._tickCallback (node.js:419:13)
    cwd = origCwd.call(process)
    at errorMessage (/usr/share/node-gyp/bin/node-gyp.js:119:28)
    at issueMessage (/usr/share/node-gyp/bin/node-gyp.js:125:3)
    at process.<anonymous> (/usr/share/node-gyp/bin/node-gyp.js:109:3)
    at process.emit (events.js:95:17)
    at process._fatalException (node.js:272:26)
npm ERR! Error: ENOENT, lstat '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/nopt/README.md'
npm ERR! If you need help, you may report this *entire* log,
npm ERR! including the npm and node versions, at:
npm ERR!     <http://github.com/npm/npm/issues>
npm ERR! System Linux 4.4.26-v7+
npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "-g" "homebridge" "--unsafe-perm"
npm ERR! cwd /home/pi/domoticz
npm ERR! node -v v0.10.29
npm ERR! npm -v 1.4.21
npm ERR! path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/nopt/README.md
npm ERR! fstream_path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/nopt/README.md
npm ERR! fstream_type File
npm ERR! fstream_class FileWriter
npm ERR! code ENOENT
npm ERR! errno 34
npm ERR! fstream_stack /usr/lib/nodejs/fstream/lib/writer.js:284:26
npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)
npm ERR! error rolling back Error: ENOTEMPTY, rmdir '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/npmlog'
npm ERR! error rolling back  [email protected] { [Error: ENOTEMPTY, rmdir '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/npmlog']
npm ERR! error rolling back   errno: 53,
npm ERR! error rolling back   code: 'ENOTEMPTY',
npm ERR! error rolling back   path: '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/npmlog' }
npm ERR! Error: ENOENT, lstat '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/semver/README.md'
npm ERR! path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/semver/README.md
npm ERR! fstream_path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/semver/README.md
npm ERR! errno 34
npm ERR! Error: ENOENT, lstat '/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/tar/LICENSE'
npm ERR! path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/tar/LICENSE
npm ERR! fstream_path /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/node_modules/tar/LICENSE
npm ERR! errno 34
> [email protected] install /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/ed25519
> node-gyp rebuild
pi@raspberrypi:~/domoticz $ sudo npm install -g homebridge-edomoticz --unsafe-perm
npm WARN engine [email protected]: wanted: {"node":">=0.12.0","homebridge":">=0.2.5"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN deprecated [email protected]: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
[email protected] /usr/local/lib/node_modules/homebridge-edomoticz
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
└── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
Marci
Domoticz version: 3.8153
Post by Marci »
Everyone trying to do barebones from scratch via method 3 / InstallGuide on repo:
USE THE PRECONFIGURED DOMOTICZ IMAGES FROM DOMOTICZ.COM
Then follow method 1 or 2.
We are here to support running the plugin.
NOT your entire install.
There is only so much we can do I'm afraid.
If you're using anything other than Method 1 or 2, you're on your own.
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
rwijbenga
Post by rwijbenga »
@TheRamon
The first is the erro I get when I use your commands to try....
I found the command the worked here on the forum:
viewtopic.php?t=11817#p88229
I only changed the IDX and IP ofocurse...
If you need more command testing let me know.
TheRamon
Post by TheRamon »
@rwijbenga:
I have just committed a new version on the master branch. I have changed the command to the one that is working on your side. Have just tried with a Hue emulator (since I don't have any hue lamp at work) and I have ironed out some more bugs regarding brightness.
Would you try checking out the master branch and trying again?
Thanks in advance.
Mazzokun
Post by Mazzokun »
Marci wrote:Everyone trying to do barebones from scratch via method 3 / InstallGuide on repo:
Now I reinstalled with DOmoticz SD images... I followed step by step the first post on this topic...
I can view switches in iOS, switch in iOS app but doesn't switch on or off...
pi@raspberrypi:~$ DEBUG=* homebridge -D
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[10/28/2016, 1:38:45 PM] Loaded plugin: homebridge-edomoticz
[10/28/2016, 1:38:46 PM] Registering accessory 'homebridge-edomoticz.eDomoticz'
[10/28/2016, 1:38:46 PM] Registering platform 'homebridge-edomoticz.eDomoticz'
[10/28/2016, 1:38:46 PM] ---
[10/28/2016, 1:38:46 PM] Loaded config.json with 0 accessories and 1 platforms.
[10/28/2016, 1:38:46 PM] Loading 1 platforms...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing eDomoticz platform...
[10/28/2016, 1:38:46 PM] [eDomoticz] Fetching Domoticz lights and switches...
[10/28/2016, 1:38:46 PM] Loading 0 accessories...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Accento Ingresso'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'CPU_Usage'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Corridoio Cupola'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Corridoio Fioriera'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Corridoio e Anticamera'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Cupola Xmas'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Esterno Cupola'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Facciata'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Fotovoltaico'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Lampada Sala'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Lampione'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Lanterna Ingresso'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Lanterna Nonna'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Luci'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Luci Cancellino'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'MacBook'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Memory Usage'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Pulsante Cancello'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Riavvio Modem'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Riavvio RaspBerry'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'Riavvio WiFi'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'iPad'...
[10/28/2016, 1:38:46 PM] [eDomoticz] Initializing platform accessory 'iPhone'...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
    │ 031-45-154 │
events.js:160
      throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51826
    at Object.exports._errnoException (util.js:1012:11)
    at exports._exceptionWithHostPort (util.js:1035:20)
    at Server._listen2 (net.js:1252:14)
    at listen (net.js:1288:10)
    at Server.listen (net.js:1384:5)
    at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:59:19)
    at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:157:20)
    at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:496:16)
    at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:111:16)
    at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:369:14)
TheRamon
Post by TheRamon »
Looks like you already have a "homebridge" version running.. Maybe try asking the guys from homebridge why their version is still running or try killing it.
Agree with Marci though, the plugin is running fine, but you can't seem to get your homebridge running. Ofcourse we'd want to help you, but it really clutters up the topic. Anyhow, try a complete restart of your device and check the logs after. Do not start homebridge manually, since then there are two versions running. Try googling the errors, too. Really helps.
rwijbenga
Post by rwijbenga »
@TheRamon
I am also not at home but I updated remotely, and when I change the color I can see it working with my webcam. :D
I will test some more @home but for now it looks like it is working again! :mrgreen:
bdormael
Post by bdormael »
I'm using the SecPanel switch from Domoticz in Home, which is showing in Home as an Alarm switch, this is really cool.
I'm aware that it's read only for now, no issue with that.
Small issue I've encountered is when the status changes in Domoticz from eg. Home to Away, when opening Home the first time, it is not updated.
When closing Home, then opening again, it is updated properly.
I don't have this with other switches from Domoticz.
Is this something that can be looked at or is it not supported properly yet ?
TheRamon
Post by TheRamon »
rwijbenga wrote:@TheRamon
Hahaha nice one!!
bdormael wrote:I'm using the SecPanel switch from Domoticz in Home, which is showing in Home as an Alarm switch, this is really cool.
Thank you for mentioning! I'll have a look!
Mazzokun
Post by Mazzokun »
TheRamon wrote:Looks like you already have a "homebridge" version running.. Maybe try asking the guys from homebridge why their version is still running or try killing it.
Thank you, I started home bridge manually but it was already in use :oops:
Solved, MUST add MQTT as hardware device.. :idea:
Now Work!! Thank you :P
rwijbenga
Post by rwijbenga »
@TheRamon
Everything working 100% :mrgreen:
Nautilus
Post by Nautilus »
TheRamon wrote:@rwijbenga:
Thanks in advance.
First things first - guys (Marci, TheRamon), great work with the plugin. Really enjoying the latest improvements! :D
With the MiLight hardware it seems that colour changing does not quite work yet. I think it differs from the RFLink json at least so that it will always result to white light unless there is "iswhite=false" as part of the command, e.g.
http://url:port/json.htm?type=command&param=setcolbrightnessvalue&idx=116&hue=233&brightness=50&iswhite=false
Ok, well now that I tested, it results to error if there isn't either iswhite=true or iswhite=false. Maybe the mqtt part then handles the turn on/off/brightness as that works :) Do you see some way to factor this into the code - or am I perhaps looking at this from the wrong direction?
edit: also noticed that the Squeezebox players show as dimmable device (type brightness), some also show up under type power (on / off) but not all. Not sure if the characteristics can be set somehow so that they would just be on/off (though there are different status available like Playing, Stop, Disconnected)? This post might be about same thing viewtopic.php?f=36&t=10272&p=94492&hili ... box#p94492. But turn on / off still works so it's nothing urgent...:)
phobosman
Post by phobosman »
What about door/window sensors, should they also work with MQTT now?
simon_rb
Post by simon_rb »
With the squeezebox players we are trying to map the dimmers to the volume controls so saying turn on kitchen radio would turn it on and saying set kitchen radio to 50 would set the volume to 50. Also be able to adjust the volume from within the native home app and from Apple Watch. Just not quite worked out how to map them yet. Marci was looking into I think with a custom handler..
Nautilus
Post by Nautilus »
simon_rb wrote:With the squeezebox players we are trying to map the dimmers to the volume controls so saying turn on kitchen radio would turn it on and saying set kitchen radio to 50 would set the volume to 50. Also be able to adjust the volume from within the native home app and from Apple Watch. Just not quite worked out how to map them yet. Marci was looking into I think with a custom handler..
Cool, that would be great of course! :)
edit: @simon_rb - yes, been using those since 2008 and still very happy with them. I only have a Duet and Radio from Logitech and then the rest are RPi software players :D
simon_rb
Post by simon_rb »
Just glad there is someone out there other than me still using the squeezebox line of players.
lidobin
Post by lidobin »
thank you.thats very useful
building information
http://www.lidobin.ir
michelz
Post by michelz »
I have installed the plug in and can see the device I want to control with Homekit. However when I press it to turn the light off nothing happens, when I reload the app the light is still on like it was before I pressed the button. In the domoticz log there is nothing about the event.
I followed the complete guide, this is my config:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:21:3E:E4:DE:33",
        "port": 51826,
        "pin": "031-45-154"
    "description": "Configuration file for (e)xtended Domoticz platform.",
    "platforms": [
            "platform": "eDomoticz",
            "name": "eDomoticz",
            "server": "192.168.1.5",
            "port": "8080",
            "ssl": 0,
            "roomid": 3,
            "mqttenable": 1,
            "mqttserver": "192.168.1.5",
            "mqttport": "1883",
            "mqttauth": 0,
            "mqttuser": "",
            "mqttpass": ""
    "accessories": []
The on/off I'm trying to control is just a simple KaKu (CoCo) outlet. I hope you can help me!
Users browsing this forum: felek and 1 guest
