Conrad RSL Wireless 1-channel Built-in switch
How to include this wall switch if I want to conrol it only using rflink?
https://www.conrad.nl/nl/rsl-draadloze- ... 40302.html
Shall I create manually switch in domoticz and send the On command while the wall switch is in learning mode?
Thanks for help
treb0r
Thanks for help
treb0r
Re: Conrad RSL Wireless 1-channel Built-in switch
Maybe you can use : créate device on rflink hardware page.
http://domo-attitude.fr
- Stuntteam
Indeed.. go to create device on the hardware page and enter:
20;21;Conrad;ID=220c49;SWITCH=01;CMD=ON;
this will create a device for you..
then send ON with this device to pair it to the switch.
- Stuntteam
Sorry derik, I removed your post as it is only causing confusion and it will not work.
The right way is..:
1. under settings tab, make sure "accept new hardware/sensors is enabled.. if not enable it and disable when done.
2. go to hardware tab
3. press create rflink device
4. enter string: 20;21;Conrad;ID=220c49;SWITCH=01;CMD=ON;
5. press OK
6. go to devices tab find the new conrad device, press green arrow and name it
7. go to switches tab and locate the new device
8. set the switch in learning mode and press "ON" on the device to pair it to the switch.
The right way is..:
5. press OK
Thank you very much. I will receive the switch tomorrow so I will check it and let you know. How to "decrypt" this string? Which part shall I change if I want to add next switch?
treb0r
PS. When I am trying to add Rflink device, I can't find new device (neither in used nor in not used) and in the log i can see: Error: RFLink: Unhandled switch type: Conrad RSL2.
treb0r
Hello ,
One question regarding step 4 of your explanation. Do I have to write 20;21 at the beginning of the string ? or do I start by Conrad....
Thank you
Thank you
20;21 = créate a device and send
ConradRSL2 = protocole/language used
ID = Remote control ID number : each remote got a différent id
Switch = switch number (this have to be change for your next wall plug)
Have you allowing new sensors ?
I have a conrad RSL shutter actuator
I can control it with RFlink loader : 10;Conrad;645c20;4;OFF;
but never succeeded to add it on domoticz, so I will give it a try and let you know...
Thank you for your message
Here what I have done :
at step 4, I entered the command : 20;21;Conrad RSL;ID=645c20;SWITCH=04;CMD=ON;
but got the answer : "probleme creation de capteur" which means : issue creating device
any clue what is wrong ?
Thank you
here is my actuator : http://www.conrad.fr/ce/fr/product/0964 ... io-Connect
Thank you
- Stuntteam
Sorry.. my bad..
20;21;Conrad;ID=645c20;SWITCH=04;CMD=ON;
21 is irrelevant, Conrad is the protocol name, 645c20 is the ID, can be almost any value
04 is the switch number (00 to 0F)
Hello all,
Thank you Stuntteam for your answer. I will try tonight.
I understand that I can use any ID, but can I use an existing ID (my remote) ?
My switches are behind the wall, and would prefer not pairing them again.
So if I entered :
20;Conrad;ID=645c20;SWITCH=04;CMD=ON;
it should work. shouldn't it ?
Thank you
So if I entered :
Thank you
- Stuntteam
If you have a remote, then you do not need any of the above.
Conrad remotes are auto detected..
(under settings tab, make sure "accept new hardware/sensors is enabled.. )
I am sorry, but I cannot make it work.
I tried with the remote, checked "accept new hardware" and even clicked on allow for 5 minutes.
When I press the remote my blind goes down, but nothing under domoticz is detected. I tried auto detection in the tab 'switch', but nothing happens when i press the remote.
Besides, I also tried to add manually and entered :
but got same message : "probleme creation de capteur" which means : issue creating device
I am getting desperate, as I really would like to make it work !
Thank you for your help
To keep you posted...
I have updated RFLink to latest firmware, and now it works !!!
Thank you so much
I love you guys
PS : only my avidsen devices do not work now...
Thank you so much
I love you guys
Ok, so I have finally got my switch. Everything is connected and...how to press switch created in domoticz for 3 seconds? It is necessery to bind rflink and Conrad switch. When I presss switch On in domoticz nothing happend.
Thx for an answer
treb0r
Edit: Single ON press, multi ON press (10x ON in Scene) doesn't work. What am I doing wrong?
Thx for an answer
treb0r
Sorry for necromancering this thread, but I'm interested in the Conrad RSL products, but it's difficult to see whether they're properly supported, considering terb0r's unanswered post.
Specifically, I'm considering getting the PIR devices. However, another worry I have with those, is that they have the same "bombing" issue as the cheap chinese PIRs, where they block the frequency for 10 seconds when activated.
- Stuntteam
No idea if it was solved already or not.. but I have added support for a pair command to the firmware so that it can be done anyway..
I'll order a PIR and door switch. I'll be sure to send you the debug data from them if they're not working.
