ELV Max! Heating control system
Re: ELV Max! Heating control system
Hi guys,
thanks for nice topic. I have 5 valves EQ-3 with Cube and RPi with Domoticz and I would like to use Domoticz to control valves. I read all topic but I'm little bit lost. I tried to install LUA5.2 into RPi but without success. Is there somebody who can send me some "How to install to RPi"? Thanks.
- blackdog65
@Hasan
Hi, some raspberry distros already have lua installed so 1st try and you will either get something like this
or this
or
if it isn't installed at all
If no lua should do the trick
Once you have it "in" your RasPi you may have problems with where it was placed or conflict with 5.1 or 5.0. I seem to remember I had to completely flush my system of everything lua related and reinstall... or maybe that was another project
But try this 1st and see how you go from there.
Sean
pi@xxxxxx:~ $ lua
Lua 5.1.5 Copyright (C) 1994-2012 Lua.org, PUC-Rio
Lua 5.2.3 Copyright (C) 1994-2013 Lua.org, PUC-Rio
The program 'lua' can be found in the following packages:
* lua5.2
* lua5.1
* lua50
Try: sudo apt install <selected package>
If no lua
sudo apt-get update
sudo apt-get lua5.2
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
- blackdog65
@mvzut
1st many thanks for the hard work so far!
I had problems getting this to run so I wandered off and played with another project for a while (The wonderful Amazon Doorstop
) and then came back to it this week. At 1st I only had partial success as I could only update one room with the script yet the "Westcott test script"
shows all rooms stats and valves. Then it hit me, 3 rooms were set to auto in the max app. set them to manual and BOOM all showing!
So temps all fine, set-points fine but my valve percentages are not correct. How should the be named? e.g. my kitchen is set up as
Room = Kitchen
Stat = Kitchen-Stat
TRV = Kitchen-Rad
My virtual devices are
Temp = Kitchen
Stat = Kitchen-Stat
% = Kitchen-Rad
The 1st 2 work but not the 3rd. Others are similar V-Room, V-Room-Stat, V-Room-Rad etc. All with the same issue.
I hope this sense (and is an easy solution
Many thanks
Sean
Room = Kitchen
Stat = Kitchen-Stat
TRV = Kitchen-Rad
Temp = Kitchen
Stat = Kitchen-Stat
% = Kitchen-Rad
Many thanks
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
I am getting the following error message with the lua script (named script_time.lua) that was posted in this forum (not that I have uncommented all prints to get the messages shown, hoping that this helps figuring what the problem is).
lua scripts/lua/script_time_max.lua
H=JEQ0543318,03f77a,0113,00000000,7e71f81d,01,32,100a19,1124,03,0000
C=03f77a,7QP3egATAf9KRVEwNTQzMzE4AQsABEAAAAAAAAAAAP///////////////////////////wsABEAAAAAAAAAAQf///////////////////////////2h0dHA6Ly93d3cubWF4LXBvcnRhbC5lbHYuZGU6ODAvY3ViZQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENFVAAACgADAAAOEENFU1QAAwACAAAcIA==
C=0b0442,0gsEQgICEABLRVEwNTcxNzk4JiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f6d7,0gj21wIDEP9LRVEwNTcwOTAzJiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIUQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f616,0gj2FgIFEP9LRVEwNTY5OTA3JiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f6d4,0gj21AIBEABLRVEwNTcwOTA2JiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=09b650,zgm2UAMBEP9LRVEwODYzNzAwJiE9CURITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgBxgw
C=08f541,0gj1QQIBEP9LRVEwNTY5NjkzJiE9CQcYAzAM/wBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERITQlFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhNCUUgRSBFIEUgRSBFIEUgRSBFIEUgRSBESE0JRSBFIEUgRSBFIEUgRSBFIEUgRSBFIA==
C=08f556,0gj1VgIEEABLRVEwNTY5NzE0KyE9CQcYAzAM/wBESFUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIVQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhUbETMVRRFIEUgRSBFIEUgRSBFIEUgRSBESFRsRMxVFEUgRSBFIEUgRSBFIEUgRSBFIERIVGxEzFUURSBFIEUgRSBFIEUgRSBFIEUgREhUbETMVRRFIEUgRSBFIEUgRSBFIEUgRSBESFRsRMxVFEUgRSBFIEUgRSBFIEUgRSBFIA==
lua: scripts/lua/script_time_max.lua:90: attempt to index global 'bit32' (a nil value)
stack traceback:
scripts/lua/script_time_max.lua:90: in function 'maxCmd_L'
scripts/lua/script_time_max.lua:202: in main chunk
[C]: ?
Your naming scheme seems correct, but I took out the updates of the valve positions in the alternative version of the script (the one that has a "useWMT" setting to work with systems without a wall mounted thermostat in every room). I figured most people would probably not need that funtionality. You should be able to put it back in by adding this lineblackdog65 wrote:@mvzut![]()
I had problems getting this to run so I wandered off and played with another project for a while (The wonderful Amazon Doorstop) and then came back to it this week. At 1st I only had partial success as I could only update one room with the script yet the "Westcott test script"
Room = Kitchen
Stat = Kitchen-Stat
TRV = Kitchen-Rad
Temp = Kitchen
Stat = Kitchen-Stat
% = Kitchen-Rad
I hope this sense (and is an easy solution)
Many thanks
Sean
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name]..'|0|'..valve_pos})
Hope this helps.
- blackdog65
Many thanks!
I'll try later when I get home.
My current script is based on the max buddy set up and activates the heating if 2 or more valves are open more than 50%. This works well for me so I plan to cannibalise it to work with your script (if my ability allows).
Thanks again
Sean
Thanks again
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
- blackdog65
and it doesn'tblackdog65 wrote:My current script is based on the max buddy set up and activates the heating if 2 or more valves are open more than 50%. This works well for me so I plan to cannibalise it to work with your script (if my ability allows).
I've been going round in circles with this and getting further confused.
I have 2 scripts
Script "A" based on the script written by l0gic viewtopic.php?f=34&t=841&start=60#p38160
-- script_time_Heating Valves.lua
-- Version 1.8 26/03/15
-- Script to read the % open of radiator valves
-- All radiator valves are labelled "RV <room name>"
-- search is made for "RV " (Note space) to indicate a radiator valve
-- If found it will be interrogated for % open value
-- Thermostat are named "Stat <room name>" so a search is made for "Sta" to indicate thermostats
-- If found it will be interrogated for temperature value
-- If demand is greater than BoilerOnPercent value then fire up boiler
-- If demand is less than BoilerOnPercent minus HysterysisOffPercent then switch off boiler
-- Preset Values
BoilerOnPercent = 50 -- percentage valve open at which the boiler will be turned on
HysterysisOffPercent = 20 -- percentage below BoilerOnPercent to switch off the boiler
MinValves = 2 -- Number of Valves that need to be open before boiler is turned on
ValvePercentOveride = 99 -- Percentage value of valve open required to override MinValves value (one room is very cold)
HolidayMinTemp = 10 -- Minimum room temperature before boiler is turned on during holiday period
HolidayHysterysisTemp = 2 -- Value to increase house temperature by while in holiday mode if boiler is turned on due to low temperatures
MissingDevicesTime = 3600 -- Value in seconds to allow before reporting a device has not been updated
email = "[email protected]" -- email address for warnings
-- Script Variables
PercentMax = 0
TempMin = 100
ValveCount = 0
MissingDeviceCount = 0
SendAnEmail = false
-- Set printing to log options (true / false)
-- printData = false
printData = false
printDebug = false
-- printDebug = true
-- Get current date & time
t1 = os.time()
local currentDate = os.date("*t"); -- sets up currentDate.[table]
-- (currentDate.year [full], .month [1-12], .day [1-31], .hour [0-23], .min [0-59], .sec [0-59], .wday [0-6 {Sun-Sat}])
sCurrentTime = currentDate.year .. "-" .. currentDate.month .. "-" .. currentDate.day .. " " .. currentDate.hour .. ":" .. currentDate.min .. ":" .. currentDate.sec
function TimeElapsed(s) -- expects date & time in the form of 2010-01-23 12:34:56
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = os.difftime (t1, t2)
return difference -- in seconds
-- print blank line in log
if printData == true then
print (" ")
print (" *** Heating Script Output ***")
print (" ")
-- Get Data from Radiator Valves
for i, v in pairs(otherdevices) do -- Get all devices in the database
v = i:sub(1,3) -- Grab the first three characters of the device name
if (v == 'RV ') then -- are the first three characters "RV "? If so we have a Radiator Valve
RoomName = i:sub(4) -- Get the rest of the name, which will be the room name
sSetTempValue, sValvePercentOpen = otherdevices_svalues[i]:match("([^;]+);([^;]+)") -- get the valve set Point and the valve % open (Temp, Humidity)
sLastUpdateTime = otherdevices_lastupdate[i]
sElapsedTime = TimeElapsed(otherdevices_lastupdate[i])
message = RoomName .. " valve is open " .. sValvePercentOpen .. " percent " .. " Setpoint temperature is " .. sSetTempValue .. "C" -- for debug
message2 = RoomName .. " last seen " .. sLastUpdateTime .. " Elapsed time " .. sElapsedTime
print (message)
print (message2)
-- check for missing devices
if sElapsedTime > MissingDevicesTime then
SendAnEmail = false
MissingDeviceCount = MissingDeviceCount + 1
-- get the % value of the most open Radiator Valve
if tonumber(sValvePercentOpen) > PercentMax then
PercentMax = tonumber(sValvePercentOpen)
-- Count the number of valves that are open more than BoilerOnPercent
if tonumber(sValvePercentOpen) >= BoilerOnPercent then
ValveCount = ValveCount + 1
print (" ")
-- Get Data from Thermostats
v = i:sub(1,5) -- Grab the first three characters of the device name
if (v == 'Stat ') then -- are the first five characters "Stat "? If so we have an EQ-3 Thermostat
RoomName = i:sub(6) -- Get the rest of the name, which will be the room name
sTemp = otherdevices_svalues[i] -- get the temperature
message = RoomName.." temperature is " .. sTemp .. " Centigrade " -- for debug
print(message)
print(message2)
-- get the lowest temperature of the thermostats
if tonumber(sTemp) < TempMin then
TempMin = tonumber(sTemp)
SendAnEmail = true -- change this to false if you do not require emails to be sent
print (" ")
print ("Number of valves open more than " .. BoilerOnPercent .. "% is " .. ValveCount .." valves")
print("Highest valve open value is " .. PercentMax .." percent ")
print("Lowest thermostat reading is " .. TempMin .." Centigrade ")
print (" ")
if (otherdevices['CH_Switch'] == 'On')then
print ("Current state - Boiler is ON ")
print ("Current state - Boiler is OFF ")
-- Check the elapsed time and email if overdue
if (SendAnEmail == true) then
print (" ")
print("Heating Script: missing device email sent to " .. (email) );
notifyString = os.date("Domoticz Alert # The current time is %X on %A Lost contact with " .. MissingDeviceCount .. " Heating script devices, check if Max!Buddy is running. #") .. (email)
commandArray['SendEmail'] = notifyString
-- Perform logic
if printDebug == true then
-- view the settings to understand logic performance
print ("PercentMax (" .. PercentMax .. "%) " .. "Boiler On value (" .. BoilerOnPercent .. "%) " .. "Boiler Off value (" .. (BoilerOnPercent - HysterysisOffPercent) .. ")% ")
print ("Number of valves open more than " .. BoilerOnPercent .. "% is " .. ValveCount .." valves. Minimum valves setting " .. MinValves )
print ("Maximum open value " .. PercentMax .. "%" .. " Override value " .. ValvePercentOveride .."%")
print (" ")
if (otherdevices['Holiday'] == 'Off')then -- Not on holiday
if (otherdevices['Heating'] == 'On')then -- It's time to heat the house
if (otherdevices['CH_Switch'] == 'Off') then --If a minimum of 'MinValves' valves are on by more that pre-set value BoilerOnPercent
print ("Test passed - Boiler is OFF ")
if (PercentMax > BoilerOnPercent) then
print ("Test passed - Radiators are open beyond the threshold ")
if (ValveCount >= MinValves) or (BoilerOnPercent >= ValvePercentOveride) then
print ("Test passed - Either multiple valves are open or override count is reached ")
commandArray['CH_Switch']='On' -- turn on boiler
print ("Command sent - Turn ON Boiler ")
if (PercentMax < (BoilerOnPercent - HysterysisOffPercent) or (ValveCount < MinValves)) and (otherdevices['CH_Switch'] == 'On') then -- If the number of valves open more than BoilerOnPercent minus HysterysisOffPercent
commandArray['CH_Switch']='Off' -- turn off boiler
print ("Command sent - Turn OFF Boiler ")
else -- on holiday
if (TempMin <= HolidayMinTemp) and (otherdevices['CH_Switch'] == 'Off') then -- house is very cold
if (TempMin >= (HolidayMinTemp + HolidayHysterysisTemp)) and (otherdevices['CH_Switch'] == 'On') then -- house is warm enough
commandArray['CH_Switch']='Off' -- turn on boiler
print (" ")
And the mvzut script viewtopic.php?f=34&t=841&start=220#p88647
--./script_time_max.lua
-- Script parameters
package.loadlib("core.so", "*")
local Socket = require "socket"
local Basexx = require "basexx"
local Rooms = {}
local Devices = {}
local Room_nums = {}
local MaxIP = "192.168.1.131"
local MaxPort = 62910
local useWMT = true --# Set to true if there is a wall mounted thermostat in every room, then this one will be used for setpoint getting/setting
Debug = "YES" --# Turn debugging on ("YES") or off ("NO")
-- Script functions
function age(timestring)
t = {}
t.year = string.sub(timestring,1,4)
t.month = string.sub(timestring,6,7)
t.day = string.sub(timestring,9,10)
t.hour = string.sub(timestring,12,13)
t.min = string.sub(timestring,15,16)
t.sec = string.sub(timestring,18,19)
return os.difftime(os.time(),os.time(t))
function maxCmd_H(data)
--if Debug=="YES" then print('H='..data) end
function maxCmd_M(data)
i = 0
j = 0
while true do --find next comma
i = string.find(data, ",", i+1)
if not i then break end
j = i
s = data:sub(j+1)
dec = Basexx.from_base64(s)
num_rooms = string.byte(dec,3)
pos=4
for i=1, num_rooms do
room_num = string.byte(dec, pos)
name_len = string.byte(dec, pos+1)
pos = pos+2
name = dec:sub(pos, pos+name_len-1)
pos = pos+name_len
adr = Basexx.to_hex(dec:sub(pos, pos+2))
Rooms[room_num] = name
pos = pos+3
num_devs = string.byte(dec, pos)
for i=1, num_devs do
dtype = string.byte(dec, pos+1)
adr = Basexx.to_hex(dec:sub(pos+2, pos+4))
snum = dec:sub(pos+5, pos+14)
name_len = string.byte(dec, pos+15)
pos = pos+16
pos = pos+name_len
Room_nums[adr] = room_num
Devices[adr] = name
function maxCmd_C(data)
--if Debug=="YES" then print('C='..data) end
function maxCmd_L(data)
pos = 1
dec = Basexx.from_base64(data)
L_hex = Basexx.to_hex(dec)
L_len = string.len(L_hex)
while (pos < L_len) do
s = L_hex:sub(pos,(pos+1))
data_len = tonumber(s,16) + 1
hex = L_hex:sub(pos,pos+(data_len*2))
adr = hex:sub(3,8)
room_num = string.format("%02X", Room_nums[adr])
room = Rooms[Room_nums[adr]]
name = Devices[adr]
if not name then name=adr end
valve_info = tonumber(hex:sub(13,14),16)
batt = bit32.extract(valve_info,7,1)
bst = bit32.extract(valve_info,3,1)
mode = bit32.extract(valve_info,0,2)
if (batt==0) then sbat="OK" else sbat="Low" end
if (mode==0) then
smode="Auto"
elseif (mode==1) then
smode="Manual"
elseif (mode==2) then
smode="Holiday"
elseif (mode==3) then
smode="Boost"
if (data_len == 13) then -- WallMountedThermostat (dev_type 3)
valve_pos = -1
s = hex:sub(17,18)
setpoint = tonumber(s,16) / 2
s = hex:sub(23,26)
temp = tonumber(s,16) / 10
dtype = "Thermostat"
elseif (data_len == 12) then -- HeatingThermostat (dev_type 1 or 2)
s = hex:sub(15,16)
valve_pos = tonumber(s,16)
s = hex:sub(17,18)
if (mode ~= 2) then
s = hex:sub(19,22)
temp = 0
dtype = "Valve"
--Temperaturdevices den Status aktualisieren
if temp ~= 0 and dtype == "Valve" then
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name.." (Valve)"]..'|0|'..temp..';'..valve_pos..';0'})
elseif temp ~= 0 and dtype == "Thermostat" then
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[room]..'|0|'..temp})
if smode=="Manual" then
--Update virtual devices in Domoticz and update MAX! setpoints if necessary
if Debug=="YES" then print(dtype.." "..name.." Setpoint="..setpoint.." Temp="..temp.." Valve pos="..valve_pos) end
if dtype == "Valve" then
--table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name.." (Valve)"]..'|0|'..temp..';'..valve_pos..';0'})
if not useWMT and tonumber(otherdevices_svalues[name])~=nil then --Use valve to check setpoint mismatch
setpoint_Domoticz = tonumber(otherdevices_svalues[name])
---if name ~= "EcoTaster" and name ~= "Switch-SZ" and name ~= "Switch-WZ" then
if setpoint_Domoticz ~= setpoint then
print(otherdevices_lastupdate[name])
print(age(otherdevices_lastupdate[name]))
if otherdevices_lastupdate[name]~=nil and age(otherdevices_lastupdate[name]) > 120 then --Domoticz thermostat value must be updated
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name]..'|0|'..setpoint})
if Debug=="YES" then print("Domoticz setpoint updated") end
else --Max! setpoint must be updated
MaxCmdSend(adr, room_num, "manual", setpoint_Domoticz)
if Debug=="YES" then print("MAX!Valve setpoint updated") end
---end
elseif dtype == "Thermostat" then
--table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[room]..'|0|'..temp})
if Debug=="YES" then print("MAX!WMT setpoint updated") end
dtype=""
name=""
setpoint=""
temp=""
valve_pos=""
pos = pos + (data_len*2)
function MaxCmdSend(id, room, mode, setpoint)
bits = setpoint * 2
smode = string.upper(mode)
if smode == 'MANUAL' then
bits = 64 + bits
elseif smode == 'BOOST' then
bits = 192 + bits
elseif smode == 'VACATION' then
bits = 128 + bits
hex = "000440000000"..id..room..string.format("%x",bits)
sendStr = Basexx.to_base64(Basexx.from_hex(hex))
i, status = tcp:send("s:"..sendStr.."\r\n")
if not i then
print("MAX! TCP send failed - "..status)
return
-- CommandArray
local m = os.date('%M')
if (m % 2 == 0) then
--print("The 3 minute script interval reached")
tcp = Socket.connect(MaxIP, MaxPort)
if not tcp then
print("MAX! Socket connect failed for "..MaxIP..':'..MaxPort)
return
tcp:settimeout(2)
local time = os.date("*t")
while (time.min ~= 0) do
s, status, partial = tcp:receive()
if (status) then
print("MAX! TCP receive - "..status)
break
local line = (s or partial)
local cmd = line:sub(1,1)
local data = line:sub(3)
if (cmd == 'H') then
maxCmd_H(data)
elseif (cmd == 'M') then
maxCmd_M(data)
elseif (cmd == 'C') then
maxCmd_C(data)
elseif (cmd == 'L') then
maxCmd_L(data)
break
tcp:close()
I've been pulling my hair out trying to see a way to combine the two to create the perfect heating control script. Can any kind soul offer some pointers.
My 1st thought was to strip the "Find devices" part from l0gic's script and get the mvzut script to fill in the missing information... but as a non-coder I over-heated my brain and I'm lucky to still have functioning heating at all!
Please help me!
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
- Domoticz version: 4.10233
Reading through the 2 scripts a combination would be indeed haven on earth... Im unfortunetly no coder also.. Fingers crossed
Do you mean that the % devices for the valves still don't update?blackdog65 wrote:and it doesn'tblackdog65 wrote:My current script is based on the max buddy set up and activates the heating if 2 or more valves are open more than 50%. This works well for me so I plan to cannibalise it to work with your script (if my ability allows).![]()
I've been going round in circles with this and getting further confused.![]()
Can you maybe put a "print(valve_pos)" line below "valve_pos = tonumber(s,16)", does it print the valve positions in the log?
- blackdog65
No, my friend. Your script works fine. I have setpoints, temps and %, all fine. My problem is using the % to control my system as in the 1st (l0gic) script.mvzut wrote:Do you mean that the % devices for the valves still don't update?
I really do struggle with code
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
The script written by l0gic requires your device names to start with "RV " for radiator valves, and "Stat " for thermostats. If I understand your previous post correct, you have named them:blackdog65 wrote:No, my friend. Your script works fine. I have setpoints, temps and %, all fine. My problem is using the % to control my system as in the 1st (l0gic) script.mvzut wrote:Do you mean that the % devices for the valves still don't update?
Stat = Kitchen-Stat
% = Kitchen-Rad
Moreover, l0gic's script assumes that the setpoint temperatures & valve positions are stored together in temp/humidity devices. I have separated them: the setpoint temperature is stored in a thermostat device, and the valve position is a separate % device. I have modified the script so that it should work again for your situation:
-- Version 1.9 27/10/16
-- All radiator valves are labelled "<room name>-Rad"
-- search is made for "-Rad" to indicate a radiator valve
-- Thermostat are named <room name>-Stat so a search is made for "-Stat" to indicate thermostats
-- Preset Values
-- Script Variables
PercentMax = 0
TempMin = 100
ValveCount = 0
SendAnEmail = false
printData = false
printDebug = false
t1 = os.time()
t1 = os.time()
print (" ")
print (" ")
v = i:sub(-4,-1) -- Grab the last four characters of the device name
if (v == '-Rad ') then -- are the last four characters "-Rad"? If so we have a Radiator Valve
RoomName = i:sub(1,-5) -- Get the rest of the name, which will be the room name
sSetTempValue = otherdevices_svalues[RoomName..'-Stat']
print (message)
print (message2)
SendAnEmail = false
print (" ")
v = i:sub(-5,-1) -- Grab the last five characters of the device name
if (v == '-Stat ') then -- are the last five characters "-Stat "? If so we have an EQ-3 Thermostat
RoomName = i:sub(1,-6) -- Get the rest of the name, which will be the room name
print(message)
print(message2)
print (" ")
print (" ")
print (" ")
-- Perform logic
print (" ")
else -- on holiday
print (" ")
UPDATE 27-10-2016 23:17
I have taken out a few errors in the adapted script after publishing it. Please use the latest version.
- blackdog65
WOW! @ mvzut!!!
Many thanks for such a fast AND comprehensive reply. I just saw this before going to bed so I shall try it tomorrow morning and get back to you.
Am I right in assuming that this eliminates the need to run maxbuddy? Also, I think I need to run your original script + this script together?
Fingers crossed and huge thanks
Sean
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
You're welcomeblackdog65 wrote:WOW! @ mvzut!!!![]()
Fingers crossed and huge thanks![]()
Sean
Yes, this eliminates the need for maxbuddy. You should indeed run both scripts as time scripts, I also have it set up that way.
Let me know if it works or not, including any error messages you may get.
- blackdog65
Hi mvzut!
I have both scripts running now.
The max script is reporting
so it only appears to get part way through the interrogation process.
And the heating script outputs
So no heat even though 2 valves are actually open 100%
I hope this makes sense to you
Thanks again
Sean
PS. I owe you a BIG beer
2016-10-28 11:50:01.930 LUA: Thermostat SittingRoom-Stat Setpoint=20 Temp=19.6 Valve pos=-1
2016-10-28 11:50:01.931 LUA: Thermostat V-Bed-Stat Setpoint=17.5 Temp=20.4 Valve pos=-1
2016-10-28 11:50:01.931 LUA: Valve SittingRoom-Rad Setpoint=20 Temp=0 Valve pos=100
2016-10-28 11:50:01.931 LUA: Valve Z-Bed-Rad Setpoint=17.5 Temp=0 Valve pos=0
2016-10-28 11:50:01.932 Error: EventSystem: in /home/linaro/domoticz/scripts/lua/script_time_max2.lua: /home/linaro/domoticz/scripts/lua/script_time_max.lua:131: attempt to concatenate field '?' (a nil value)
2016-10-28 11:50:01.938 EventSystem: Script event triggered: /home/linaro/domoticz/scripts/lua/script_time_max.lua
2016-10-28 11:50:49.279 LUA: *** Heating Script Output ***
2016-10-28 11:50:49.280 LUA:
2016-10-28 11:50:49.281 LUA:
2016-10-28 11:50:49.281 LUA: Number of valves open more than 50% is 0 valves
2016-10-28 11:50:49.281 LUA: Highest valve open value is 0 percent
2016-10-28 11:50:49.281 LUA: Lowest thermostat reading is 100 Centigrade
2016-10-28 11:50:49.281 LUA: Current state - Boiler is OFF
2016-10-28 11:50:49.281 LUA: PercentMax (0%) Boiler On value (50%) Boiler Off value (30)%
2016-10-28 11:50:49.281 LUA: Number of valves open more than 50% is 0 valves. Minimum valves setting 2
2016-10-28 11:50:49.281 LUA: Maximum open value 0% Override value 99%
2016-10-28 11:50:49.281 LUA: Test passed - Boiler is OFF
2016-10-28 11:50:49.282 LUA:
Thanks again
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
- blackdog65
Ok,
now I have a full read
the max script is seeing 2 valves open but the heating valve script isn't
2016-10-28 12:24:00.878 LUA: Thermostat SittingRoom-Stat Setpoint=20 Temp=19.6 Valve pos=-1
2016-10-28 12:24:00.878 LUA: Thermostat V-Bed-Stat Setpoint=17.5 Temp=20.4 Valve pos=-1
2016-10-28 12:24:00.878 LUA: Valve SittingRoom-Rad Setpoint=20 Temp=0 Valve pos=100
2016-10-28 12:24:00.879 LUA: Valve Z-Bed-Rad Setpoint=17.5 Temp=0 Valve pos=0
2016-10-28 12:24:00.879 LUA: Valve V-Bed-Rad Setpoint=17.5 Temp=0 Valve pos=35
2016-10-28 12:24:00.879 LUA: Valve Kitchen-Rad Setpoint=20 Temp=0 Valve pos=100
2016-10-28 12:24:00.879 LUA: Thermostat Kitchen-Stat Setpoint=20 Temp=19.1 Valve pos=-1
2016-10-28 12:24:00.880 LUA: Thermostat Z-Bed-Stat Setpoint=17.5 Temp=18.5 Valve pos=-1
2016-10-28 12:24:00.892 EventSystem: Script event triggered: /home/linaro/domoticz/scripts/lua/script_time_max.lua
2016-10-28 12:24:00.906 LUA:
2016-10-28 12:24:00.906 LUA: *** Heating Script Output ***
2016-10-28 12:24:00.907 LUA:
2016-10-28 12:24:00.907 LUA: Number of valves open more than 50% is 0 valves
2016-10-28 12:24:00.907 LUA: Highest valve open value is 0 percent
2016-10-28 12:24:00.907 LUA: Lowest thermostat reading is 100 Centigrade
2016-10-28 12:24:00.907 LUA: Current state - Boiler is OFF
2016-10-28 12:24:00.907 LUA: PercentMax (0%) Boiler On value (50%) Boiler Off value (30)%
2016-10-28 12:24:00.907 LUA: Number of valves open more than 50% is 0 valves. Minimum valves setting 2
2016-10-28 12:24:00.907 LUA: Maximum open value 0% Override value 99%
2016-10-28 12:24:00.907 LUA: Test passed - Boiler is OFF
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Do you know why the MAX script gave an error at first, and then suddenly worked later?blackdog65 wrote:Ok,
now I have a full readthe max script is seeing 2 valves open but the heating valve script isn'tCode: Select all
2016-10-28 12:24:00.878 LUA: Thermostat SittingRoom-Stat Setpoint=20 Temp=19.6 Valve pos=-1 2016-10-28 12:24:00.878 LUA: Thermostat V-Bed-Stat Setpoint=17.5 Temp=20.4 Valve pos=-1 2016-10-28 12:24:00.878 LUA: Valve SittingRoom-Rad Setpoint=20 Temp=0 Valve pos=100 2016-10-28 12:24:00.879 LUA: Valve Z-Bed-Rad Setpoint=17.5 Temp=0 Valve pos=0 2016-10-28 12:24:00.879 LUA: Valve V-Bed-Rad Setpoint=17.5 Temp=0 Valve pos=35 2016-10-28 12:24:00.879 LUA: Valve Kitchen-Rad Setpoint=20 Temp=0 Valve pos=100 2016-10-28 12:24:00.879 LUA: Thermostat Kitchen-Stat Setpoint=20 Temp=19.1 Valve pos=-1 2016-10-28 12:24:00.880 LUA: Thermostat Z-Bed-Stat Setpoint=17.5 Temp=18.5 Valve pos=-1 2016-10-28 12:24:00.892 EventSystem: Script event triggered: /home/linaro/domoticz/scripts/lua/script_time_max.lua 2016-10-28 12:24:00.906 LUA: 2016-10-28 12:24:00.906 LUA: *** Heating Script Output *** 2016-10-28 12:24:00.906 LUA: 2016-10-28 12:24:00.906 LUA: 2016-10-28 12:24:00.907 LUA: 2016-10-28 12:24:00.907 LUA: Number of valves open more than 50% is 0 valves 2016-10-28 12:24:00.907 LUA: Highest valve open value is 0 percent 2016-10-28 12:24:00.907 LUA: Lowest thermostat reading is 100 Centigrade 2016-10-28 12:24:00.907 LUA: 2016-10-28 12:24:00.907 LUA: Current state - Boiler is OFF 2016-10-28 12:24:00.907 LUA: PercentMax (0%) Boiler On value (50%) Boiler Off value (30)% 2016-10-28 12:24:00.907 LUA: Number of valves open more than 50% is 0 valves. Minimum valves setting 2 2016-10-28 12:24:00.907 LUA: Maximum open value 0% Override value 99% 2016-10-28 12:24:00.907 LUA: 2016-10-28 12:24:00.907 LUA: Test passed - Boiler is OFF
I'll see if I can find why the heating valve script doesn't show the correct info, but that will probably be tonight (while enjoying a (your?) beer
- blackdog65
It seems to be a "feature"mvzut wrote: Do you know why the MAX script gave an error at first, and then suddenly worked later?
I'll see if I can find why the heating valve script doesn't show the correct info, but that will probably be tonight (while enjoying a (your?) beer)
However, many thanks so far! I'm sure there are more people watching this and hoping. Full heating automation is something of a "Holy Grail" for me as it will make the wife appreciate Domoticz more... and loosen the purse strings
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Wow, do you live in a castle?blackdog65 wrote:It seems to be a "feature"mvzut wrote: Do you know why the MAX script gave an error at first, and then suddenly worked later?
as it will do it for 3 or 4 checks then run perfect for 24hrs. Would it happen if a device wasn't picked up? I have some very thick walls (800mm+) and massive chimney breasts that can be a nuisance at times, causing the EQ3 devices to skip a check occasionally.
However, many thanks so far! I'm sure there are more people watching this and hoping. Full heating automation is something of a "Holy Grail" for me as it will make the wife appreciate Domoticz more... and loosen the purse strings![]()
Sean
As you probably know, Domoticz doesn't directly communicate with the valves/thermostats but with the Cube, which in turn communicates with the valves. As far as I know, the Cube will always return a value, even if it briefly lost communication with the devices. It will then simply return the last known value. So I don't expect that this is the cause for the missed updates, although I could of course be wrong.
My wife also very much likes the fact that she now can turn on the heat in her study, even if the rest of the house is unheated. She didn't buy me a beer for it (yet), maybe I should show her your post
- blackdog65
not quite. It's a very big 400 year old farm house... they knew how to build them back then!Wow, do you live in a castle?
My wife has her desk in "The Library" which makes it sound more like the "Cluedo" house than a castleMy wife also very much likes the fact that she now can turn on the heat in her study
But seriously, heating is a very wife friendly thing. Most of what I do looks like either magic or a waste of time to my wife... unless it keeps her warm or saves money... THEN she's interested
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
I think I know what the problem is. There are two typos is the valve script. Please changeblackdog65 wrote: the max script is seeing 2 valves open but the heating valve script isn't
if (v == '-Rad') then -- are the last four characters "-Rad"? If so we have a Radiator Valve
Similarly, change
if (v == '-Stat') then -- are the last five characters "-Stat"? If so we have an EQ-3 Thermostat
