[Plugin now available in Beta] Help with Yeelight Bulb
- Domoticz version: BETA
Re: [Plugin now available in Beta] Help with Yeelight Bulb
@ Farhanito
Your sript is working....Thanks..
on, off, toggle works oke!!!
Only i think with the b and ct i mis something or i do something wrong...
Can i command all the setting on this way for this bulb? disco wakeup etc..
Can i switch 2 light @ the same time [ orderd more ] when i put in the script multiple Ip?
got the sunrise script working to..
Make a dummy mistake not chmod 777..
And did a trick to start the light from the off position...
Because replace the start_cf in stead of set_scene was not working
Now it is working great....
Are there more nice scripts...
Orderd more bulbs ...
Milight for sale...
echo -ne '{"id":1,"method":"set_scene", "params": ["color", 65280, 1]}\r\n' | nc -w1 192.168.5.30 55443
echo -ne '{"id":1, "method":"start_cf", "params":[3,1,"50,1,16731392,1,360000,2,1700,10,540000,2,2700,100"]}\r\n' | nc -w1 192.168.5.30 55443
Milight for sale...
@ weiweipossible
Is there perhaps a extension option for the ledstrip..
I need 4M ledstrip...
Or can i extend with a neopixel or a regulair HUE, or a other rgbw strip or something else?
Please do you have a example for the script so the bulb are acting exactly like a hue
I see in the manual that this is possible.
Only i do not understand this option..
Are there new bulbs for Sale?
Just update my Domoticz on a Syno :
Yeelight arrive half : no way to set adresses. does domoticz will look by his self is there any yeelight at home ?
Version: 3.5814
Build Hash: 9817a5e-modified
Compile Date: 2016-10-24 08:44:40
http://domo-attitude.fr
- corbin
Are the Yeelights not getting added to Domoticz devices? There isn't any need to tell it IP addresses as it will use a UDP broadcast to discover devices.deennoo wrote:Just update my Domoticz on a Syno :
Ok, bulb still not arrive, want to prepare.
UDP discover is fantastic but this make my domoticz unstable ! Especialy when it discover nothing...remove for now and wait for bulb.
Maybe it can be more easyer to set ip adresse (your will not be alone todo this).
We are really sorry that the current LED strip can't be extended.Derik wrote:@ weiweipossible
The 4M ledstrip is being developed and may be released next year.
Regarding bulbs, we only have two version, white and color.
I have a Mi yeelight color wifi bulb.
When I activate ‘Yeelight Led’ Domoticz will crash after a minute. When I restart Domoticz in less a minute it will crash again. When I deactivate ‘Yeelight Led’ it is stable. It also didn’t find any lights at the devices tabs.
Any suggestions?
Synology
Version: 3.5814
RFXCOM 443, RFXCOM 868, Hue, Aon Zwave
Any suggestions?
Synology
Version: 3.5814
I installed 2 rgbw bulb but i can't get warm light ( 2700-3000 kelvin) any help?
Can you get this CT through Yeelight or MiHome app?Mazzokun wrote:I installed 2 rgbw bulb but i can't get warm light ( 2700-3000 kelvin) any help?
yes, something similar to warm and not yellow.. isn't there a code for warm light?
Hi, I have found this plugin for homebridge, It works like a charm and if I pull off dc power to the bulb domoticz doesn't crash... I wish this could help you with some code..
https://github.com/vvpossible/homebridge_yeelight
I'm maintaining this pluginMazzokun wrote:Hi, I have found this plugin for homebridge, It works like a charm and if I pull off dc power to the bulb domoticz doesn't crash... I wish this could help you with some code..![]()
Yes it's more stable, because if I use the domoticz integration and physically disconnect a bulb from ac power, domoticz goes immediately offline.. With the homebridge plugin there isn't this issueweiweipossible wrote:I'm maintaining this pluginMazzokun wrote:Hi, I have found this plugin for homebridge, It works like a charm and if I pull off dc power to the bulb domoticz doesn't crash... I wish this could help you with some code..![]()
. Are you saying current domoticz with yeelight-plugin is not stable enough? Maybe I can take a look and provide some help.
- corbin
I've borrowed a Raspberry Pi B and installed the beta image, which has worked with the lights powered, and it is stable when the lights are unplugged. Using the wired network connection, then I added a USB WIFI adapter, and it is still stable. I have a USB keyboard, 4GB SD card, and HDMI monitor plugged in also.
Any suggestions on hardware or software changes I could do to replicate the crashing?
Pull off AC Power of a bulb, pull on AC Power and the bulb should power on, then try to change state of the bulb via domoticz.. sometimes the bulb work ok, but usually don't respond and then domoticz goes offline. ( tested with 3 bulbs 2 works after shutdown 1 doesn't respond )corbin wrote:I've borrowed a Raspberry Pi B and installed the beta image, which has worked with the lights powered, and it is stable when the lights are unplugged. Using the wired network connection, then I added a USB WIFI adapter, and it is still stable. I have a USB keyboard, 4GB SD card, and HDMI monitor plugged in also.
I have a Raspberry Pi 3
- corbin
Thanks for testingMazzokun wrote: Pull off AC Power of a bulb, pull on AC Power and the bulb should power on, then try to change state of the bulb via domoticz.. sometimes the bulb work ok, but usually don't respond and then domoticz goes offline. ( tested with 3 bulbs 2 works after shutdown 1 doesn't respond )
This kind of problem will be fixed in a new update I've been working on.
- corbin
I have a question for the people this is still crashing for, I just want to confirm something - Did you only add the Yeelight hardware and do nothing else in Domoticz? ie control the lights with scripts or try to turn the lights on/off from Domoticz GUI when they have been physically unplugged?
yes I have other hardware in domoticz and yes I control this hardware with some lua script.
For yeelight I tried to control them from Domoticz GUI when they have been physically unplugged
The issue I'm having on my RPi2 is exactly the same as described by @ErikJ with Synology.corbin wrote:I've borrowed a Raspberry Pi B and installed the beta image, which has worked with the lights powered, and it is stable when the lights are unplugged. Using the wired network connection, then I added a USB WIFI adapter, and it is still stable. I have a USB keyboard, 4GB SD card, and HDMI monitor plugged in also.
ErikJ wrote:Hi,
Any suggestions?
Synology
Version: 3.5814
