Hi everybody,
I have recently purchase the RFLink and some mi-light led controller.
https://www.amazon.de/gp/product/B00KF9 ... UTF8&psc=1
Short story:
I have manage to pair these controller but the remote was needed otherwise I could not pair it directly with RFLink. I have been in touch with Frank from http://www.nemcon.nl/blog2/contact he told me that there is some issue and the remote help to pair.
Now I have all my controller pair in different zone. But when I change the color of one they all change in same time. With the remote I'm able to change individually each zone.
this is the command sent for led saloon
2016-10-25 12:53:01.154 User: admin initiated a switch command (149/LedSaloon/On)
2016-10-25 12:53:01.154 RFLink Sending: 10;MiLightv1;dd54;01;0000;ON
here for led bedroom
2016-10-25 12:53:58.597 User: admin initiated a switch command (153/LedBedroom/On)
2016-10-25 12:53:58.597 RFLink Sending: 10;MiLightv1;dd54;04;0000;ON
As you could see they are in different zone 01 and 04.
and this when I change the color
2016-10-25 12:55:24.147 (RFLINK) Lighting Limitless/Applamp (LedBedroom)
2016-10-25 12:55:24.861 RFLink Sending: 10;MiLightv1;dd54;04;00dd;ON
2016-10-25 12:55:25.037 RFLink Sending: 10;MiLightv1;dd54;04;00dd;BRIGHT
But than it change also the other led controller and that it's a big problem because if I create a scene to switch ON the controller you have to chose a color and then it will not work.
Do you guys have this problem?
I forgot
Domoticz version 3.57.47
Windoz10 for now
Milight led controler cant change color individually
HP NL54 with Xpenology DSM 5.2-5592 Update 3
HarmonyHub
Rpi
HarmonyHub
Rpi
Re: Milight led controler cant change color individually
Nobody has this problem? So I'm doing something wrong... I did follow the FAQ from RFLink site. All my controller are in different zone and it works with the remote. I do not have the mi-light bridge only RFLink and the led controller.
Please I need your help.
HarmonyHub
Rpi
HarmonyHub
Rpi
- Stuntteam
We have to look into it.. possibly there is an issue cause by "cloned" products.
We did see some differences in the behaviour of the various devices.
That was probably also the reason the new rgbww devices use scrambled communication.
Thank you Stuntteam for your answer.
What I notice is with the remote the code send is dd54. So what I did, I send manually the code with domoticz and the the code to dd55 I manage to pair a controller without the remote that way and that one did not change color when I change another one. I will try to pair all my controller that way.
Please let me know if I could help you I'm willing to do some test for you.
mvg
mvg
HarmonyHub
Rpi
HarmonyHub
Rpi
I just updated the firmware and added the NRF to my RFLink set up to enable the milight functionality. I have control of the bulbs now which is great, but I have observed the same problem alphawarrior is describing.
Thought I would let you know you are not alone alpha
Just did this and it seems to solved it for me, seems like a reasonable work around. But, I cannot seem to turn the bulb I paired off?alphawarrior wrote:Thank you Stuntteam for your answer.
mvg
Hi thazlett,
Thank you to confirm. I was doubting...
I'm pretty sure if you send the command with zone/group 0 which is the main it will switch OFF. Try to do it via the rflink software.
HarmonyHub
Rpi
HarmonyHub
Rpi
- sincze
- Domoticz version: 2024.4
Hi guys did R45 of rflink fix this issue for you?
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
