Domoticz log and failed attempt (to use fail2ban)
tlpeter
Re: Domoticz log and failed attempt (to use fail2ban)
Post by tlpeter »
I tried most of them but i see i missed one.
I will try that later this week and see what happens.
tlpeter
Post by tlpeter »
Fail2ban starts now but the RPI doesn't have iptables so this is useless i guess.
ThinkPad
Post by ThinkPad »
Can't you just install it with something like sudo apt-get install iptables or something?
jadijkstra2000
Post by jadijkstra2000 »
I got connections from the outside world :o
2015-12-30 00:16:02.530 Incoming connection from:
2015-12-30 00:17:55.008 Incoming connection from: ***external ip address***
2015-12-30 02:16:42.866 Incoming connection from: ***external ip address***
I had set up authentication... and always when logging in external I need to fill in username / password.
Looking at the above means that they can connect from the outside or with my account and they have my password, or on a other way...
I have closed the port from the outside for now.
Any idea?
Egregius
Domoticz version: v2024.7
Post by Egregius »
On what port is domoticz running?
jadijkstra2000
443 & 8082
Egregius
Post by Egregius »
Change them to a random number between 1024 and 65535. 443 is a standard port, ones they know it they attack.
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
Exactely followed the wiki http://domoticz.com/wiki/Automated_bann ... iple_times eveything seems to work fine.
But when i test 3 times login using some smartphones, nothing happens :(
Domoticz log:
2016-07-07 23:49:32.074 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:49:34.818 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:49:38.430 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:49:38.502 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:49:38.777 (Slimme meter) P1 Smart Meter (energie verbruik)
2016-07-07 23:49:40.349 (MySensors) RFXMeter (Water)
2016-07-07 23:49:44.178 Hardware Monitor: Fetching data (System sensors)
2016-07-07 23:49:46.492 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:49:46.558 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:49:48.797 (Slimme meter) P1 Smart Meter (energie verbruik)
2016-07-07 23:49:50.123 (RFLink) Temp + Humidity (AlectoV3)
2016-07-07 23:49:53.669 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:49:58.820 (Slimme meter) P1 Smart Meter (energie verbruik)
2016-07-07 23:50:02.255 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 127.0.0.1)
2016-07-07 23:50:02.259 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 127.0.0.1)
2016-07-07 23:50:03.292 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 127.0.0.1)
2016-07-07 23:50:05.594 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:50:06.472 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:50:08.839 (Slimme meter) P1 Smart Meter (energie verbruik)
2016-07-07 23:50:10.326 (MySensors) RFXMeter (Water)
2016-07-07 23:50:13.089 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:50:14.235 Hardware Monitor: Fetching data (System sensors)
2016-07-07 23:50:16.220 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
2016-07-07 23:50:16.299 Error: [web:8080] Failed authentication attempt, ignoring client request (remote address: 143.179.114.223)
The IPTABELS DROP rule is still empty ?
IPtables:
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
fail2ban-domoticz  tcp  --  anywhere             anywhere             multiport dports http-alt
fail2ban-ssh  tcp  --  anywhere             anywhere             multiport dports ssh
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain fail2ban-domoticz (1 references)
RETURN     all  --  anywhere             anywhere
Chain fail2ban-ssh (1 references)
What did i do possibly wrong ?
running Domoticz V3.5290
It's nice to be important, but it's more important to be nice
Scooter ;)
l00pz
Post by l00pz »
I don't know if you got it working by now, but I think the error message changed in Domoticz and therefore the "failregex" isn't correct. I got it working on my Setup with this "failregex" configured:
failregex = Failed authentication attempt, ignoring client request \(remote address: <HOST>\)
I use Basic Authentication on my Domoticz.
Michel13
Domoticz version: 2024.7
Post by Michel13 »
Good evening,
I have the same issue as thecosmicgate.
fail2ban is installed on my Rasp PI3.
All is ok, checked and rechecked again and again, but I have no ban at all.
Logs are OK, but iptables remain empty.
Error message have not change "Error: Failed login attempt from <IP> for user 'xxxx' !
Is there any change with the last Domoticz preventing fail2ban to work ?
HansieNL
Post by HansieNL »
These are my Values for domoticz.conf:
failregex = Error: Failed login attempt from <HOST> for user '.*' !
Error: Failed login attempt from <HOST> for '.*' !
Error: Webserver: Failed authentication attempt, ignoring client request \(remote addresses: <HOST>\)
Error: \[web:8080\] Failed authentication attempt, ignoring client request \(remote address: <HOST>\)
I added the last line... I don't know if there are more new messages?
Blah blah blah
Michel13
Post by Michel13 »
Thanks HansieNL for your feedback.
I have finally found this morning where was the problem.
Despite all the checks, I did a typing mistake in the jail.local file thus preventing fail2ban to run properly.
All is running perfect now after correction.
I have not used your last line, but I keep them aside in case of later use.
Nibble
Post by Nibble »
I have installed fail2ban today, but it won't match the failregex rule.
I found out the reason why, the date is missing of when the error happend.
This is needed by the fail2ban.
The error in the Domoticz log file is like:
Error: Failed login attempt from 1.2.3.4 for user 'Me' !
This one is ignored by fail2ban.
I think it should be like:
2017-03-05 15:59:46.732 Error: Failed login attempt from 1.2.3.4 for user 'Me' !
When I test this with the fail2ban-regex, I got a match.
Does anyone know how to get the date in the logfile messages?
Thank you for your help.
HansieNL
Post by HansieNL »
Hello Nibble,
The line "Error: Failed login attempt from <HOST> for user 'Me' !" should work because your line with the date is the same with only the dateand time added. There must be a typo or exclusion in fail2ban' jail.local file. Maybe you try from your own network and you have excluded from filtering?
You can also check /var/log/fail2ban.log what fail2ban is logging.
Blah blah blah
Nibble
Post by Nibble »
You would say, but when I only add the date and time before the log entry, it is a match, while the regex isn't changed.
Also I read that Fail2ban test is of to parts, one the date and time and after that the regex line.
The regex rule I'm using: Error: Failed login attempt from <HOST> for user '.*' !
I have no idea what is going wrong here.
JohnnySK
Post by JohnnySK »
Hi!, Will Fail2Ban protect domoticz webserver? I have lot of time this in error log
2017-03-05 19:30:09.653 Error: Webserver: File '/HNAP1/index.html': No such file or directory (2)
2017-03-05 19:30:09.835 Error: Webserver: File '/hudson/script': No such file or directory (2)
2017-03-05 19:30:10.016 Error: Webserver: File '/script': No such file or directory (2)
2017-03-05 19:30:10.932 Error: Webserver: File '/phpmyadmin/index.html': No such file or directory (2)
2017-03-05 19:30:11.011 Error: Webserver: File '/phpMyAdmin/index.html': No such file or directory (2)
2017-03-05 19:30:20.103 Error: Webserver: File '/PMA/index.html': No such file or directory (2)
2017-03-05 19:30:20.207 Error: Webserver: File '/pma/index.html': No such file or directory (2)
2017-03-05 19:30:23.393 Error: Webserver: File '/admin/index.html': No such file or directory (2)
2017-03-05 19:30:23.485 Error: Webserver: File '/dbadmin/index.html': No such file or directory (2)
2017-03-05 19:30:26.575 Error: Webserver: File '/mysql/index.html': No such file or directory (2)
2017-03-05 19:30:26.661 Error: Webserver: File '/myadmin/index.html': No such file or directory (2)
2017-03-05 19:30:29.988 Error: Webserver: File '/openserver/phpmyadmin/index.html': No such file or directory (2)
2017-03-05 19:30:30.170 Error: Webserver: File '/phpmyadmin2/index.html': No such file or directory (2)
2017-03-05 19:30:30.352 Error: Webserver: File '/phpMyAdmin2/index.html': No such file or directory (2)
2017-03-05 19:30:30.568 Error: Webserver: File '/phpMyAdmin-2/index.html': No such file or directory (2)
2017-03-05 19:30:51.702 Error: Webserver: File '/php-my-admin/index.html': No such file or directory (2)
2017-03-05 19:30:52.073 Error: Webserver: File '/phpMyAdmin-2.2.3/index.html': No such file or directory (2)
2017-03-05 19:30:52.441 Error: Webserver: File '/phpMyAdmin-2.2.6/index.html': No such file or directory (2)
2017-03-05 19:30:52.518 Error: Webserver: File '/phpMyAdmin-2.5.1/index.html': No such file or directory (2)
2017-03-05 19:30:52.594 Error: Webserver: File '/phpMyAdmin-2.5.4/index.html': No such file or directory (2)
2017-03-05 19:30:52.671 Error: Webserver: File '/phpMyAdmin-2.5.5-rc1/index.html': No such file or directory (2)
2017-03-05 19:30:52.771 Error: Webserver: File '/phpMyAdmin-2.5.5-rc2/index.html': No such file or directory (2)
2017-03-05 19:30:52.843 Error: Webserver: File '/phpMyAdmin-2.5.5/index.html': No such file or directory (2)
2017-03-05 19:30:55.912 Error: Webserver: File '/phpMyAdmin-2.5.5-pl1/index.html': No such file or directory (2)
2017-03-05 19:30:56.191 Error: Webserver: File '/phpMyAdmin-2.5.6-rc1/index.html': No such file or directory (2)
2017-03-05 19:30:56.256 Error: Webserver: File '/phpMyAdmin-2.5.6-rc2/index.html': No such file or directory (2)
2017-03-05 19:30:56.519 Error: Webserver: File '/phpMyAdmin-2.5.6/index.html': No such file or directory (2)
2017-03-05 19:30:56.895 Error: Webserver: File '/phpMyAdmin-2.5.7/index.html': No such file or directory (2)
2017-03-05 19:31:00.059 Error: Webserver: File '/phpMyAdmin-2.5.7-pl1/index.html': No such file or directory (2)
2017-03-05 19:31:00.245 Error: Webserver: File '/phpMyAdmin-2.6.0-alpha/index.html': No such file or directory (2)
2017-03-05 19:31:00.433 Error: Webserver: File '/phpMyAdmin-2.6.0-alpha2/index.html': No such file or directory (2)
2017-03-05 19:31:00.516 Error: Webserver: File '/phpMyAdmin-2.6.0-beta1/index.html': No such file or directory (2)
2017-03-05 19:31:00.600 Error: Webserver: File '/phpMyAdmin-2.6.0-beta2/index.html': No such file or directory (2)
2017-03-05 19:31:01.185 Error: Webserver: File '/phpMyAdmin-2.6.0-rc1/index.html': No such file or directory (2)
2017-03-05 19:31:01.600 Error: Webserver: File '/phpMyAdmin-2.6.0-rc2/index.html': No such file or directory (2)
2017-03-05 19:31:02.151 Error: Webserver: File '/phpMyAdmin-2.6.0-rc3/index.html': No such file or directory (2)
2017-03-05 19:31:05.226 Error: Webserver: File '/phpMyAdmin-2.6.0/index.html': No such file or directory (2)
2017-03-05 19:31:05.321 Error: Webserver: File '/phpMyAdmin-2.6.0-pl1/index.html': No such file or directory (2)
2017-03-05 19:31:05.420 Error: Webserver: File '/phpMyAdmin-2.6.0-pl2/index.html': No such file or directory (2)
2017-03-05 19:31:05.507 Error: Webserver: File '/phpMyAdmin-2.6.0-pl3/index.html': No such file or directory (2)
2017-03-05 19:31:08.586 Error: Webserver: File '/phpMyAdmin-2.6.1-rc1/index.html': No such file or directory (2)
2017-03-05 19:31:08.811 Error: Webserver: File '/phpMyAdmin-2.6.1-rc2/index.html': No such file or directory (2)
2017-03-05 19:31:09.233 Error: Webserver: File '/phpMyAdmin-2.6.1/index.html': No such file or directory (2)
2017-03-05 19:31:39.366 Error: Webserver: File '/phpMyAdmin-2.6.1-pl1/index.html': No such file or directory (2)
2017-03-05 19:31:39.429 Error: Webserver: File '/phpMyAdmin-2.6.1-pl2/index.html': No such file or directory (2)
2017-03-05 19:31:39.504 Error: Webserver: File '/phpMyAdmin-2.6.1-pl3/index.html': No such file or directory (2)
2017-03-05 19:31:39.582 Error: Webserver: File '/phpMyAdmin-2.6.2-rc1/index.html': No such file or directory (2)
2017-03-05 19:31:39.643 Error: Webserver: File '/phpMyAdmin-2.6.2-beta1/index.html': No such file or directory (2)
2017-03-05 19:31:39.722 Error: Webserver: File '/phpMyAdmin-2.6.2-rc1/index.html': No such file or directory (2)
2017-03-05 19:31:39.788 Error: Webserver: File '/phpMyAdmin-2.6.2/index.html': No such file or directory (2)
2017-03-05 19:31:39.859 Error: Webserver: File '/phpMyAdmin-2.6.2-pl1/index.html': No such file or directory (2)
2017-03-05 19:31:39.928 Error: Webserver: File '/phpMyAdmin-2.6.3/index.html': No such file or directory (2)
2017-03-05 19:31:39.998 Error: Webserver: File '/phpMyAdmin-2.6.3-rc1/index.html': No such file or directory (2)
2017-03-05 19:31:40.193 Error: Webserver: File '/phpMyAdmin-2.6.3/index.html': No such file or directory (2)
2017-03-05 19:31:40.260 Error: Webserver: File '/phpMyAdmin-2.6.3-pl1/index.html': No such file or directory (2)
2017-03-05 19:31:40.335 Error: Webserver: File '/phpMyAdmin-2.6.4-rc1/index.html': No such file or directory (2)
2017-03-05 19:31:40.406 Error: Webserver: File '/phpMyAdmin-2.6.4-pl1/index.html': No such file or directory (2)
2017-03-05 19:31:40.507 Error: Webserver: File '/phpMyAdmin-2.6.4-pl2/index.html': No such file or directory (2)
2017-03-05 19:31:40.575 Error: Webserver: File '/phpMyAdmin-2.6.4-pl3/index.html': No such file or directory (2)
2017-03-05 19:31:40.829 Error: Webserver: File '/phpMyAdmin-2.6.4-pl4/index.html': No such file or directory (2)
2017-03-05 19:32:02.132 Error: Webserver: File '/phpMyAdmin-2.6.4/index.html': No such file or directory (2)
2017-03-05 19:32:02.318 Error: Webserver: File '/phpMyAdmin-2.7.0-beta1/index.html': No such file or directory (2)
2017-03-05 19:32:02.504 Error: Webserver: File '/phpMyAdmin-2.7.0-rc1/index.html': No such file or directory (2)
2017-03-05 19:32:02.569 Error: Webserver: File '/phpMyAdmin-2.7.0-pl1/index.html': No such file or directory (2)
2017-03-05 19:32:02.655 Error: Webserver: File '/phpMyAdmin-2.7.0-pl2/index.html': No such file or directory (2)
2017-03-05 19:32:02.989 Error: Webserver: File '/phpMyAdmin-2.7.0/index.html': No such file or directory (2)
2017-03-05 19:32:03.361 Error: Webserver: File '/phpMyAdmin-2.8.0-beta1/index.html': No such file or directory (2)
2017-03-05 19:32:03.545 Error: Webserver: File '/phpMyAdmin-2.8.0-rc1/index.html': No such file or directory (2)
2017-03-05 19:32:03.615 Error: Webserver: File '/phpMyAdmin-2.8.0-rc2/index.html': No such file or directory (2)
2017-03-05 19:32:03.711 Error: Webserver: File '/phpMyAdmin-2.8.0/index.html': No such file or directory (2)
2017-03-05 19:32:03.929 Error: Webserver: File '/phpMyAdmin-2.8.0.1/index.html': No such file or directory (2)
2017-03-05 19:32:04.323 Error: Webserver: File '/phpMyAdmin-2.8.0.2/index.html': No such file or directory (2)
2017-03-05 19:32:04.402 Error: Webserver: File '/phpMyAdmin-2.8.0.3/index.html': No such file or directory (2)
2017-03-05 19:32:04.465 Error: Webserver: File '/phpMyAdmin-2.8.0.4/index.html': No such file or directory (2)
2017-03-05 19:32:04.548 Error: Webserver: File '/phpMyAdmin-2.8.1-rc1/index.html': No such file or directory (2)
2017-03-05 19:32:07.770 Error: Webserver: File '/phpMyAdmin-2.8.1/index.html': No such file or directory (2)
2017-03-05 19:32:07.902 Error: Webserver: File '/phpMyAdmin-2.8.2/index.html': No such file or directory (2)
2017-03-05 19:32:08.040 Error: Webserver: File '/sqlmanager/index.html': No such file or directory (2)
2017-03-05 19:32:08.209 Error: Webserver: File '/mysqlmanager/index.html': No such file or directory (2)
2017-03-05 19:32:08.288 Error: Webserver: File '/p/m/a/index.html': No such file or directory (2)
2017-03-05 19:32:11.708 Error: Webserver: File '/PMA2005/index.html': No such file or directory (2)
2017-03-05 19:32:11.898 Error: Webserver: File '/pma2005/index.html': No such file or directory (2)
2017-03-05 19:32:12.051 Error: Webserver: File '/phpmanager/index.html': No such file or directory (2)
2017-03-05 19:32:12.456 Error: Webserver: File '/php-myadmin/index.html': No such file or directory (2)
2017-03-05 19:32:12.644 Error: Webserver: File '/phpmy-admin/index.html': No such file or directory (2)
2017-03-05 19:32:12.718 Error: Webserver: File '/webadmin/index.html': No such file or directory (2)
2017-03-05 19:32:12.944 Error: Webserver: File '/sqlweb/index.html': No such file or directory (2)
2017-03-05 19:32:13.313 Error: Webserver: File '/websql/index.html': No such file or directory (2)
2017-03-05 19:32:16.384 Error: Webserver: File '/webdb/index.html': No such file or directory (2)
2017-03-05 19:32:16.489 Error: Webserver: File '/mysqladmin/index.html': No such file or directory (2)
2017-03-05 19:32:16.731 Error: Webserver: File '/mysql-admin/index.html': No such file or directory (2)
Nibble
Post by Nibble »
Yes, you can protect the webserver with fail2ban.
I used this https://www.domoticz.com/wiki/Automated ... iple_times to setup my fail2ban.
Although it doesn't work yet with the rules from here,
i would say add a regex string to the domoticz.conf file of fail2ban with something like: Error: Webserver: File '.*': No such file or directory (2)
I notice you've got date and time before those webserver rules, on my system it only writes: Error: Webserver: File '/index2.html': No such file or directory (2) without date.
Do I have to edit some file to get the date in front of the logfile entries?
//Edwin
JohnnySK
Post by JohnnySK »
But in this error is not HOST.. so how will fail2ban know what to ban ?
Nibble
Post by Nibble »
oops, my bad, overlooked that one, sorry.
Freemann
Domoticz version: >=Béta
Post by Freemann »
Anybody has an idea on why this message isn't showing an IP;
[web:8080] Failed authentication attempt, ignoring client request (remote address: )
I'm I missing something on my Rpi?
Also how to prevent or fix this?
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
Users browsing this forum: Semrush [Bot] and 1 guest
