I have several motioneye cameras around my house and just wanted to set them up with Domoticz.
I've seen another similar post already but with no fix for the issue at all.
I can see the stream perfectly ok when testing connection on Edit Camera menu.
However once off from that menu, stream and preview don't work at all.
Any suggestions?
Thanks,
Rafal
Motioneye camera - no streaming in Domoticz
- Domoticz version: 3.5809
Re: Motioneye camera - no streaming in Domoticz
do you have fond a solution ? i have the same issue
I was able to check motioneye logs and posted that issue on their forum. Just got a reply from the guy who invented that software:
The signature-based authentication mechanism used by motionEye is probably not implemented in Domoticz. This is not going to work unless either they implement it or I implement the good old HTTP authentication scheme in motionEye.
So, seems that we have to wait for them or kindly ask gizmocuz to implement it.
