🌙 Nightglass Theme (WIP)
imautohuttraeger
Domoticz version: latest
Re: 🌙 Nightglass Theme (WIP)
Post by imautohuttraeger »
Just recognized the menu icon "Recent Events" top right. I am detecting new, cool stuff every day.
EDIT: And rooms filter is working now. Even with the possibility to select multiple rooms.
Nightglass really is extremely much more than just a skin or theme. It lifts Domoticz into a new age up to the stars.
Great! Thanks! ❤️
Last edited by imautohuttraeger on Thursday 07 May 2026 9:44, edited 1 time in total.
Stop, look and listen.
imautohuttraeger
domcars0 wrote: Wednesday 06 May 2026 15:25 Hi,
Just a question. I've personnal icons for the 'child lock' switch devices and would like to replace the On/Off png images by awesome fonts.
I've added :
 'images/ChildLock48_On.png':   'fa-solid fa-lock',
	 'images/ChildLock48_Off.png':   'fa-solid fa-lock-open',
In the src/js/icons.js file.
It works when I load the page, but font does not change when I switch the device (I must reload the page) . What do I do to make it works ?
Thank you very much
I can't help with this particular question. But I know a good workaround:
Upload your individual iconset ChildLock48_On.png and ChildLock48_Off.png via the standard custom icons procedure
(settings / more options / custom icons)
https://wiki.domoticz.com/Custom_icons_for_webinterface
If the name does not correspond to any matching font awesome icon, it will be taken as .PNG and will not be overwritten by a font awesome picture. See my screenshot with individual solar icons. Tested it with a switch also and the on / off change works.
domcars0
Domoticz version: 2026.2
Post by domcars0 »
imautohuttraeger wrote: Thursday 07 May 2026 9:29
Thanks but ... That is what I want (img to be overwritten by fa fonts). It statically works (fa fonts replace the .png img), but when I switch, the fa font does not change, I need to reload the page.
domcars0 wrote: Thursday 07 May 2026 12:41
Why don't you use the long time build in custom Icon functionality as mentioned before? No need to hardcode something in the js files.
Edit- A wait, you want custom awesome fonts. Why?
domcars0
Post by domcars0 »
waltervl wrote: Thursday 07 May 2026 14:04 Why don't you use the long time build in custom Icon functionality as mentioned before? No need to hardcode something in the js files.
??? Why do I want to replace personnal icon by fa fonts ? For the same reason galadril replace png icons by fa fonts :lol:
What don't you understand in my question ?
galadril
Post by galadril »
domcars0 wrote: Thursday 07 May 2026 18:31 ??? Why do I want to replace personnal icon by fa fonts ? For the same reason galadril replace png icons by fa fonts :lol:
Actually the question or need for help is also a bit hard to understand for me :D.
1) The idea is that the custom icon feature of domoticz still works, so you can set a custom icon via Domoticz UI as before
2) This theme only replaces icons that it matches by default
3) There is a way to turn this off completely and use the defaut icons from Domoticz
4) There is now a dialog where you could override the icons for the devices.
Im i something missing, or is something not working as expected?
domcars0
Post by domcars0 »
It looks like my English is too poor to explain my problem, sorry. Anyway, it's not very important. Thanks to all.
imautohuttraeger
Write it in your mother tongue in Google translate and paste the English translation here.
Andreotti
Post by Andreotti »
I like this theme very much, it gives Domoticz a long needed fresh look.
But, if I had to come up with suggestions, these would be it:
Respect this setting: Setup->Settings->System->Hardware/Devices->Flash sensor
Also a way to disable Notification history (Recent events)
imautohuttraeger
In the settings of the nightglass theme, there is an option for a highlight of changes which can be switched on or off. However, this seems to be redundant with the option of the general settings.
JediMax
Post by JediMax »
It's very good theme. Thank you.
May I suggest a new feature? In another theme (Aurora), we can group sensors by the beginning of their name. I think this would be very convenient.
Andreotti
Post by Andreotti »
imautohuttraeger wrote: Saturday 09 May 2026 2:43 In the settings of the nightglass theme, there is an option for a highlight of changes which can be switched on or off. However, this seems to be redundant with the option of the general settings.
But again, this is a very very nice theme!
galadril
Post by galadril »
Andreotti wrote: Saturday 09 May 2026 1:12 I like this theme very much, it gives Domoticz a long needed fresh look.
JediMax wrote: Saturday 09 May 2026 22:36 It's very good theme. Thank you.
Good suggestions!
Would you create a Issue/Feature Request here please:
https://github.com/galadril/Domoticz-Ni ... eme/issues
(Its easier for me to keep track of those ;) )
Thanks also for others to reply here, I do read this forum, but im more active on github ;) :arrow:
galadril
Post by galadril »
Btw the latets version has now Filters implemented. Hope you like them.
imautohuttraeger
galadril wrote: Saturday 23 May 2026 10:56 Btw the latets version has now Filters implemented. Hope you like them.
I do like it an recommend to everyone to give it a trial - it is worth it 👍
rron
Post by rron »
I hope this theme will be part off the official domoticz software.
Arjan2019
Post by Arjan2019 »
Filter doesn't work correct for me.
On my dashboard I only see my favorites but when I go to another tab and back to my dashboard I see all devices
So Nightglass it's working for me now so I did go back to the default
imautohuttraeger
I confirm this behaviour, so this might be fixed.
However, if you activate "dynamic dashboard" in your user profile, you would not consider the nightglass theme as "not working for me". I guarantee this 😉
Micha123
Post by Micha123 »
possible to also add "event" filter in recent events ??? in my case i need there only some sensors (i dont mean the popups )
in my case this logs are filled within 2 seconds now
pipiche
Post by pipiche »
[quote=jannl post_id=333093 time=1776683644 user_id=1929]
I am propably missing something, but how does this work with docker? www/styles dis not exist at first and after creating it en putting nightglass in it, it does not show up as template.
[/quote]
I have the same question ?
