Ihto heatpump connected to Domoticz Topic is solved
Rik60
- Domoticz version: 2026.3
I am trying to connect a Itho heatpump to Domoticz. I am using (trying) to do this with MQTT. I do have a connection, Auto discover is creating a fan in Domoticz, no other devices. With MQTT explorer i can see some data, but does this data telling me that it is not possible in this way?
- MQTT_Explorer.jpg (217.85 KiB) Viewed 7693 times
Re: Ihto heatpump connected to Domoticz
There is only a fan device config in the homeassistant topic so that should be correct.
I dont know where the config topic in the Domoticz topic is coming from but that seems to be a configuration error made by you.
I suspect in the Itho topic all the device states are shown and in the homeassistant topic all the device config are shown. Domoticz looks at the config topics to create devices. In the state topics the states of those devices are shown.
So it seems you miss some config topics in the homeassistant topic if you expect more devices should be created.
Rik60
Thanks.
I have looked a bit closer in de api program files, found that there is just 1 config file, it is for a fan. Other config files has to be done. So, for a heatpump there is no config file and i don't know how to write one. I am going to try with the web-api. If i do a web request i get all the information i need, but have to figure out how to put it in Domoticz (plug-in?)
You could try to create Autodiscover config topics with mqtt explorer based on the Homeassistant integration in the wiki page
https://github.com/arjenhiemstra/ithowi ... mp-support
The data is in the ithostatus message so you can also try to use the Domoticz MQTTmapper python plugin. viewtopic.php?f=65&t=39279
I tried copilot for this and it says:
Auto-Discovery Topics:
For each sensor or device, you need to publish a configuration payload to the appropriate topic. Here are some examples based on the Itho WPU Heat Pump:
Temperature Sensor:
Humidity Sensor:
Power Consumption:
Publishing the Configuration:
Use an MQTT client to publish these configuration payloads to the respective topics. For example, using mosquitto_pub:
These steps should help you integrate the Itho WPU Heat Pump with Home Assistant using MQTT auto-discovery.
Temperature Sensor:
homeassistant/sensor/itho_wpu_temperature/config:
"name": "Itho WPU Temperature",
"state_topic": "itho/wpu/temperature",
"unit_of_measurement": "°C",
"value_template": "{{ value_json.temperature }}"
homeassistant/sensor/itho_wpu_humidity/config:
"name": "Itho WPU Humidity",
"state_topic": "itho/wpu/humidity",
"unit_of_measurement": "%",
"value_template": "{{ value_json.humidity }}"
homeassistant/sensor/itho_wpu_power/config:
"name": "Itho WPU Power",
"state_topic": "itho/wpu/power",
"unit_of_measurement": "W",
"value_template": "{{ value_json.power }}"
mosquitto_pub -h <broker_address> -t homeassistant/sensor/itho_wpu_temperature/config -m '{"name": "Itho WPU Temperature", "state_topic": "itho/wpu/temperature", "unit_of_measurement": "°C", "value_template": "{{ value_json.temperature }}"}'
Reading the above Copilot fooled me.... It should all link to topic itho/ithostatus
homeassistant/sensor/itho_wpu_boiler_temp/config:
"name": "Itho WPU Boiler temp",
"state_topic": "itho/ithostatus",
"value_template": "{{ value_json['Boiler temp up (°C)'] }}",
"state_class": "measurement",
"device_class": "temperature"
}Domoticz running on Udoo X86 (on Ubuntu)
Rik60
Thanks Walter,
It's the first time i am going to use MQTT. So this will be a good practice
Rik60
Playing with MQTT mapper, making it working for 1 sensor. If i create a second sensor i see an error in the domoticz logging:
How can i create more sensors with the same topic itho/ithostatus in the file MqttMapper.json?
File MqttMapper.json that is working:
File MqttMapper.json failing:
What could be the problem?
MQTT mapper: Duplicate itho/ithostatus node/key....
"Itho Boiler temp beneden": {
"topic": "itho/ithostatus",
"type": "80", "subtype": "5", "switchtype": "0",
"mapping": {"item": "Boiler temp down (°C)"}
"Itho Boiler temp boven": {
"mapping": {"item": "Boiler temp up (°C)"}
FlyingDomotic
- Domoticz version: 2020.2
Problem is that 2 devices are linked to topic "itho/ithostatus", and as this is Domoticz default key for device, 2 of them are hidden.
That's why a "key" item has been created.
To fix the issue, you may try something like:
"key": itho/ithostatus"
"key": itho/ithostatus-up"
Keys should be unique among a file, and doesn't need to be related to anything.
You can also use "key": "itho/ithostatus1"/"itho/ithostatus2" or "tempxxx"/"tempyyy" as long as keys are unique into the considered file.
As soon as yo define them, don't change them, otherwise you create new devices, with same name. After a change, don't forget to check that there's no duplicate devices in Domoticz. In doubt, delete all dupplicate, and restart MqttMapper.
Don't hesitate to ask, if something is not so clear.
Rik60
It's working now. I already saw this "key" solution in another Mqtt topic, tried it but didn't work. But now it is, thanks.
This is the file now (and i am going to add more...):
"key": "itho/ithostatus1",
"key": "itho/ithostatus2",
"Itho Kamer temperatuur": {
"key": "itho/ithostatus3",
"mapping": {"item": "Room temp (°C)"}
"Itho Kamer setpoint": {
"key": "itho/ithostatus4",
"mapping": {"item": "Requested room temp (°C)"}
