SNZB-02P not supported Topic is solved
ssk17051980
- Domoticz version: 2023.2
I use domoticz
Version: 2024.1
Build Hash: 5279c8261
Compile Date: 2024-01-01 13:59:22
dzVents Version: 3.1.8
Zigbee2MQTT
sonoff dongle P
I'm trying to add 2 SNZB-02P sensors and I can't. do you have any idea if they are compatible or is it another problem for me?
It appears on the Zigbee2MQTT page but with Unsupported but I don't see them in domoticz in the device.
Version: 2024.1
Zigbee2MQTT
sonoff dongle P
- domoticz.jpg (35.11 KiB) Viewed 2616 times
Dave21w
- Domoticz version: Stable
Re: SNZB-02P not supported
Defintely supported by z2m, see here:
https://zigbee.blakadder.com/Sonoff_SNZB-02P.html
What version of z2m are you on ?
ssk17051980
I notice, but I can't add them
I tried with 2 different sensors
Dave21w
Z2M version ?
ssk17051980
Zigbee2MQTT Plugin (v. 3.2.0-beta)
Dave21w
Maybe a post on the z2m github support page will help, I don't have any of those sensors but someone else may have the same issue. Also I use MQTT auto detect instead of the zigbee plugin but i doubt that would change the lack of detection. If the device isn't understood by domoticz it wont appear (as far as I know)
ssk17051980
The admin just delete de post- 2x post ....
- Domoticz version: 2025.1
Yes, because you did not post it in the Zigbee2MQTT support forum but on this forum again....
The Zigbee2MQTT forum is here https://github.com/Koenkk/zigbee2mqtt/discussions
ssk17051980
I did not know this. thank you !!! I posted there
ssk17051980
after update plugin: v.3.2.0-beta, zigbee2mqtt: v.1.29.2 to plugin: v.3.2.0-beta, zigbee2mqtt: v.1.35.2 it's working.
