Zigate ETRV Lidl Silvercrest "TS0601"; "_TZE200_chyvmhay" not supported Topic is solved
Domoticz version: 2025.1
I have bought a Zigbee Radiator valve from LIDL Silvercrest "TS0601"; "_TZE200_chyvmhay".
https://www.lidl.nl/p/silvercrest-radia ... p100335076
https://zigbee.blakadder.com/Lidl_TVR01.html
It is pairing with Zigate, 3 devices are created in Domoticz but no interaction. No update from devices and also if setpoint or mode is set no action on the ETRV
I have also attached the raw devices json (as txt)
Plugin Raw devices (device 40)
export-etrv.json.txt
(179.73 KiB) Downloaded 49 times
Can we make it work with Zigate?
pipiche
Re: Zigate ETRV Lidl Silvercrest "TS0601"; "_TZE200_chyvmhay" not supported
Post by pipiche »
@waltervl, I starting to be very tired with Tuya Valve and all of the variances.
In between, can you please get the latest beta 6.0.007
then you remove those 3 widgets, and then restart the plugin
if you can also enable debugTuya and debugPairing via the WebUI
and then redo the pairing.
I would be then interested of the pairing logs as well as a new export.json
Thanks in advance
I now got 2 devices with at least one strange value (Setpoint)
And the logs
Tuya_pairing_log.txt
(13.8 KiB) Downloaded 58 times
And the json export (device 40)
export-etrv2.json.txt
(179.19 KiB) Downloaded 51 times
pipiche
Post by pipiche »
Thanks very much for the logs.
Can you kindly try the most recent beta 6.0.008)
1/ after restarting the plugin, can you check how the SetPoint behave ? Do you get the right value ?
2/ then, can you remove the 2 widgets and redo the pairing. You should then get 3 widgets one for Thermostat.
Yes, thanks, I get Temp, Setpoint and some selectorswitch Confort/No Freeze (type error, should be Comfort). This selector switch is not working.
The ETRV has auto/manual mode switch and a switch for heating and holiday/energy saving mode. That last switch could be similar with the Confort/No Freeze domoticz device.
Attached the new json export.
export-etrv3.json.txt
(191.13 KiB) Downloaded 47 times
If I switch from Heating to Holiday mode it gives the following log (including Setpoint from 21 to 17 C). No selector switch change in Domoticz during below mentioned actions.
  2022-01-12 18:29:41.678 ZiGate: receive_setpoint - Nwkid: 25e8/01 Setpoint: 34 for model taget: TS0601-_TZE200_chyvmhay
2022-01-12 18:29:41.679 ZiGate: receive_setpoint - After Nwkid: 25e8/01 Setpoint: 17.0 for model taget: TS0601-_TZE200_chyvmhay
2022-01-12 18:29:41.685 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_ThermoSetpoint-b4e3f9fffec1ecea-01) 0:17.00
2022-01-12 18:29:41.851 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 10 dt: 02 data: 00000022
2022-01-12 18:29:41.851 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 10 datatype: 2 data: 00000022
2022-01-12 18:29:41.852 ZiGate: receive_setpoint - Nwkid: 25e8/01 Setpoint: 34 for model taget: TS0601-_TZE200_chyvmhay
2022-01-12 18:29:41.852 ZiGate: receive_setpoint - After Nwkid: 25e8/01 Setpoint: 17.0 for model taget: TS0601-_TZE200_chyvmhay
2022-01-12 18:29:46.725 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 18 dt: 02 data: 000000e6
2022-01-12 18:29:46.726 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 18 datatype: 2 data: 000000e6
2022-01-12 18:29:46.726 ZiGate: receive_temperature - Nwkid: 25e8/01 Temperature: 230
2022-01-12 18:29:46.731 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_Temp-b4e3f9fffec1ecea-01) 23.0:23.0
2022-01-12 18:29:46.888 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 18 dt: 02 data: 000000e6
2022-01-12 18:29:46.889 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 18 datatype: 2 data: 000000e6
2022-01-12 18:29:46.889 ZiGate: receive_temperature - Nwkid: 25e8/01 Temperature: 230
2022-01-12 18:29:47.032 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 23 dt: 02 data: 0000009b
2022-01-12 18:29:47.033 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 23 datatype: 2 data: 0000009b
2022-01-12 18:29:47.033 ZiGate: receive_battery - Nwkid: 25e8/01 Battery status 155
2022-01-12 18:29:47.203 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 23 dt: 02 data: 0000009b
2022-01-12 18:29:47.203 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 23 datatype: 2 data: 0000009b
2022-01-12 18:29:47.203 ZiGate: receive_battery - Nwkid: 25e8/01 Battery status 155
2022-01-12 18:29:51.717 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 23 dt: 02 data: 0000009c
2022-01-12 18:29:51.718 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 23 datatype: 2 data: 0000009c
2022-01-12 18:29:51.718 ZiGate: receive_battery - Nwkid: 25e8/01 Battery status 156
2022-01-12 18:29:51.834 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 23 dt: 02 data: 0000009c
2022-01-12 18:29:51.835 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 23 datatype: 2 data: 0000009c
2022-01-12 18:29:51.835 ZiGate: receive_battery - Nwkid: 25e8/01 Battery status 156
Going back to Heating mode gives (incl setpoint freom 17 to 21 c)
2022-01-12 18:32:01.707 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 10 dt: 02 data: 0000002a
2022-01-12 18:32:01.707 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 10 datatype: 2 data: 0000002a
2022-01-12 18:32:01.708 ZiGate: receive_setpoint - Nwkid: 25e8/01 Setpoint: 42 for model taget: TS0601-_TZE200_chyvmhay
2022-01-12 18:32:01.708 ZiGate: receive_setpoint - After Nwkid: 25e8/01 Setpoint: 21.0 for model taget: TS0601-_TZE200_chyvmhay
2022-01-12 18:32:01.718 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_ThermoSetpoint-b4e3f9fffec1ecea-01) 0:21.00
2022-01-12 18:32:01.865 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 10 dt: 02 data: 0000002a
2022-01-12 18:32:01.865 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 10 datatype: 2 data: 0000002a
2022-01-12 18:32:01.865 ZiGate: receive_setpoint - Nwkid: 25e8/01 Setpoint: 42 for model taget: TS0601-_TZE200_chyvmhay
2022-01-12 18:32:01.866 ZiGate: receive_setpoint - After Nwkid: 25e8/01 Setpoint: 21.0 for model taget: TS0601-_TZE200_chyvmhay
Switching from Manual to Auto logs:
 2022-01-12 18:33:27.680 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 02 dt: 04 data: 00
2022-01-12 18:33:27.680 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 02 datatype: 4 data: 00
2022-01-12 18:33:27.680 ZiGate: receive_receive_LIDLMode - Nwkid: 25e8/01 Dp: 2 DataType: 4 ManualMode: 00
2022-01-12 18:33:27.681 ZiGate: receive_receive_LIDLMode - Nwkid: 25e8/01 Manual Mode Off
2022-01-12 18:33:27.847 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 02 dt: 04 data: 00
2022-01-12 18:33:27.847 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 02 datatype: 4 data: 00
2022-01-12 18:33:27.847 ZiGate: receive_receive_LIDLMode - Nwkid: 25e8/01 Dp: 2 DataType: 4 ManualMode: 00
2022-01-12 18:33:27.847 ZiGate: receive_receive_LIDLMode - Nwkid: 25e8/01 Manual Mode Off
2022-01-12 18:33:32.716 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 23 dt: 02 data: 0000009b
2022-01-12 18:33:32.716 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 23 datatype: 2 data: 0000009b
2022-01-12 18:33:32.717 ZiGate: receive_battery - Nwkid: 25e8/01 Battery status 155
2022-01-12 18:33:32.828 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 23 dt: 02 data: 0000009b
2022-01-12 18:33:32.829 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 23 datatype: 2 data: 0000009b
2022-01-12 18:33:32.829 ZiGate: receive_battery - Nwkid: 25e8/01 Battery status 155
2022-01-12 18:33:37.676 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 23 dt: 02 data: 0000009c
2022-01-12 18:33:37.676 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 23 datatype: 2 data: 0000009c
2022-01-12 18:33:37.677 ZiGate: receive_battery - Nwkid: 25e8/01 Battery status 156
2022-01-12 18:33:37.836 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 23 dt: 02 data: 0000009c
2022-01-12 18:33:37.837 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 23 datatype: 2 data: 0000009c
2022-01-12 18:33:37.837 ZiGate: receive_battery - Nwkid: 25e8/01 Battery status 156
Switching from Auto to Manual:
2022-01-12 18:35:02.706 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 02 dt: 04 data: 01
2022-01-12 18:35:02.706 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 02 datatype: 4 data: 01
2022-01-12 18:35:02.706 ZiGate: receive_receive_LIDLMode - Nwkid: 25e8/01 Dp: 2 DataType: 4 ManualMode: 01
2022-01-12 18:35:02.707 ZiGate: receive_receive_LIDLMode - Nwkid: 25e8/01 Manual Mode Off
2022-01-12 18:35:02.815 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 25e8/01 dp: 02 dt: 04 data: 01
2022-01-12 18:35:02.816 ZiGate: tuya_eTRV_response - Nwkid: 25e8 dp: 02 datatype: 4 data: 01
2022-01-12 18:35:02.816 ZiGate: receive_receive_LIDLMode - Nwkid: 25e8/01 Dp: 2 DataType: 4 ManualMode: 01
2022-01-12 18:35:02.816 ZiGate: receive_receive_LIDLMode - Nwkid: 25e8/01 Manual Mode Off
pipiche
Post by pipiche »
@walter , I'll probably work on that issue later end of the week, if that is ok for you
the log you provided are splendid and will really ease my part
Ok, no problem, thanks for your help so far!
pipiche
Post by pipiche »
My understanding from the log and what I found is that there are 3 modes
0 => Auto
1 => Manual
2 => Away
The fact that you had Comfort/No Freeze is a mistake, I'm correcting that.
I think I have corrected. You can simply retreive the latest beta, then you can use a new feature in the WebUi to recreate the widget, and then AFTER you can remove the old one.
This can be done in Admin > Provisionning
Screenshot 2022-01-14 at 23.45.15.png (29.2 KiB) Viewed 1355 times
Thank you, it is working. All changes seems to work (tested 10 minutes so have to be carefull).
Only one issue: When switching Auto/Manual/Away I get errors in the Domoticz log. But the switching is executed.
See log:
2022-01-15 16:58:34.093 ZiGate: receive_receive_LIDLMode - Nwkid: 059c/01 Dp: 2 DataType: 4 Mode: 01
2022-01-15 16:58:34.094 ZiGate: receive_LIDLMode - Nwkid: 059c/01 Mode 01
2022-01-15 16:58:34.224 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 059c/01 dp: 02 dt: 04 data: 01
2022-01-15 16:58:34.224 ZiGate: tuya_eTRV_response - Nwkid: 059c dp: 02 datatype: 4 data: 01
2022-01-15 16:58:34.224 ZiGate: receive_receive_LIDLMode - Nwkid: 059c/01 Dp: 2 DataType: 4 Mode: 01
2022-01-15 16:58:34.225 ZiGate: receive_LIDLMode - Nwkid: 059c/01 Mode 01
2022-01-15 16:58:34.097 Error: ZiGate: forwarder_thread - Error while receiving a ZiGate command
2022-01-15 16:58:34.107 Error: ZiGate: 'forwarder_thread' failed '%d format: a number is required, not str'
2022-01-15 16:58:34.115 Error: ZiGate: ----> Line 36 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/forwarderThread.py', function forwarder_thread
2022-01-15 16:58:34.119 Error: ZiGate: ----> Line 51 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/instrumentation.py', function f_out
2022-01-15 16:58:34.123 Error: ZiGate: ----> Line 60 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/forwarderThread.py', function forward_message
2022-01-15 16:58:34.127 Error: ZiGate: ----> Line 694 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2022-01-15 16:58:34.140 Error: ZiGate: ----> Line 197 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2022-01-15 16:58:34.154 Error: ZiGate: ----> Line 754 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8002
2022-01-15 16:58:34.162 Error: ZiGate: ----> Line 261 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/inRawAps.py', function inRawAps
2022-01-15 16:58:34.167 Error: ZiGate: ----> Line 344 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuya.py', function tuyaReadRawAPS
2022-01-15 16:58:34.171 Error: ZiGate: ----> Line 423 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuya.py', function tuya_response
2022-01-15 16:58:34.177 Error: ZiGate: ----> Line 660 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuyaTRV.py', function tuya_eTRV_response
2022-01-15 16:58:34.182 Error: ZiGate: ----> Line 199 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuyaTRV.py', function receive_LIDLMode
2022-01-15 16:58:34.186 Error: ZiGate: ----> Line 544 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/domoMaj.py', function MajDomoDevice
2022-01-15 16:58:34.194 Error: ZiGate: handle_error_in_thread
2022-01-15 16:58:34.225 Error: ZiGate: forwarder_thread - Error while receiving a ZiGate command
2022-01-15 16:58:34.230 Error: ZiGate: 'forwarder_thread' failed '%d format: a number is required, not str'
2022-01-15 16:58:34.236 Error: ZiGate: ----> Line 36 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/forwarderThread.py', function forwarder_thread
2022-01-15 16:58:34.241 Error: ZiGate: ----> Line 51 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/instrumentation.py', function f_out
2022-01-15 16:58:34.246 Error: ZiGate: ----> Line 60 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/forwarderThread.py', function forward_message
2022-01-15 16:58:34.251 Error: ZiGate: ----> Line 694 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2022-01-15 16:58:34.255 Error: ZiGate: ----> Line 197 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2022-01-15 16:58:34.259 Error: ZiGate: ----> Line 754 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8002
2022-01-15 16:58:34.263 Error: ZiGate: ----> Line 261 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/inRawAps.py', function inRawAps
2022-01-15 16:58:34.268 Error: ZiGate: ----> Line 344 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuya.py', function tuyaReadRawAPS
2022-01-15 16:58:34.272 Error: ZiGate: ----> Line 423 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuya.py', function tuya_response
2022-01-15 16:58:34.277 Error: ZiGate: ----> Line 660 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuyaTRV.py', function tuya_eTRV_response
2022-01-15 16:58:34.281 Error: ZiGate: ----> Line 199 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuyaTRV.py', function receive_LIDLMode
2022-01-15 16:58:34.286 Error: ZiGate: ----> Line 544 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/domoMaj.py', function MajDomoDevice
2022-01-15 16:58:34.290 Error: ZiGate: handle_error_in_thread
2022-01-15 16:58:36.566 ZiGate: UpdateDevice - ( Tem+Hum Zolder) 0:7.0;83.4;3
2022-01-15 16:58:36.575 ZiGate: UpdateDevice - ( Temp Zolder) 7.0:7.0
2022-01-15 16:58:39.351 ZiGate: mgtCommand : Set Level for Device: 059c EPout: 01 Unit: 78 DeviceType: ThermoMode_5 Level: 30
2022-01-15 16:58:39.351 ZiGate: tuya_lidl_set_mode - 059c mode: 2
2022-01-15 16:58:39.351 ZiGate: tuya_trv_brt100_set_mode - 059c dp for mode: 2
2022-01-15 16:58:39.351 ZiGate: tuya_cmd - 059c/01 cmd: 00 payload: 112a0000090204000102
2022-01-15 16:58:39.362 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_ThermoMode_5-b4e3f9fffec1ecea-01) 3:30
2022-01-15 16:58:39.372 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_ThermoMode_5-b4e3f9fffec1ecea-01) 1:30
2022-01-15 16:58:39.714 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 059c/01 dp: 02 dt: 04 data: 02
2022-01-15 16:58:39.715 ZiGate: tuya_eTRV_response - Nwkid: 059c dp: 02 datatype: 4 data: 02
2022-01-15 16:58:39.715 ZiGate: receive_receive_LIDLMode - Nwkid: 059c/01 Dp: 2 DataType: 4 Mode: 02
2022-01-15 16:58:39.715 ZiGate: receive_LIDLMode - Nwkid: 059c/01 Mode 02
2022-01-15 16:58:39.873 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 059c/01 dp: 02 dt: 04 data: 02
2022-01-15 16:58:39.874 ZiGate: tuya_eTRV_response - Nwkid: 059c dp: 02 datatype: 4 data: 02
2022-01-15 16:58:39.874 ZiGate: receive_receive_LIDLMode - Nwkid: 059c/01 Dp: 2 DataType: 4 Mode: 02
2022-01-15 16:58:39.874 ZiGate: receive_LIDLMode - Nwkid: 059c/01 Mode 02
2022-01-15 16:58:39.336 Status: Incoming connection from: 192.168.1.45
2022-01-15 16:58:39.344 Status: User: Admin (IP: 192.168.1.37) initiated a switch command (397/ZiGate - TS0601-_TZE200_chyvmhay_ThermoMode_5-b4e3f9fffec1ecea-01/Set Level)
2022-01-15 16:58:39.716 Error: ZiGate: forwarder_thread - Error while receiving a ZiGate command
2022-01-15 16:58:39.720 Error: ZiGate: 'forwarder_thread' failed '%d format: a number is required, not str'
2022-01-15 16:58:39.728 Error: ZiGate: ----> Line 36 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/forwarderThread.py', function forwarder_thread
2022-01-15 16:58:39.732 Error: ZiGate: ----> Line 51 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/instrumentation.py', function f_out
2022-01-15 16:58:39.737 Error: ZiGate: ----> Line 60 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/forwarderThread.py', function forward_message
2022-01-15 16:58:39.742 Error: ZiGate: ----> Line 694 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2022-01-15 16:58:39.746 Error: ZiGate: ----> Line 197 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2022-01-15 16:58:39.749 Error: ZiGate: ----> Line 754 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8002
2022-01-15 16:58:39.754 Error: ZiGate: ----> Line 261 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/inRawAps.py', function inRawAps
2022-01-15 16:58:39.758 Error: ZiGate: ----> Line 344 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuya.py', function tuyaReadRawAPS
2022-01-15 16:58:39.762 Error: ZiGate: ----> Line 423 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuya.py', function tuya_response
2022-01-15 16:58:39.765 Error: ZiGate: ----> Line 660 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuyaTRV.py', function tuya_eTRV_response
2022-01-15 16:58:39.769 Error: ZiGate: ----> Line 199 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuyaTRV.py', function receive_LIDLMode
2022-01-15 16:58:39.773 Error: ZiGate: ----> Line 544 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/domoMaj.py', function MajDomoDevice
2022-01-15 16:58:39.777 Error: ZiGate: handle_error_in_thread
2022-01-15 16:58:39.875 Error: ZiGate: forwarder_thread - Error while receiving a ZiGate command
2022-01-15 16:58:39.881 Error: ZiGate: 'forwarder_thread' failed '%d format: a number is required, not str'
2022-01-15 16:58:39.888 Error: ZiGate: ----> Line 36 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/forwarderThread.py', function forwarder_thread
2022-01-15 16:58:39.892 Error: ZiGate: ----> Line 51 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/instrumentation.py', function f_out
2022-01-15 16:58:39.897 Error: ZiGate: ----> Line 60 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Classes/Transport/forwarderThread.py', function forward_message
2022-01-15 16:58:39.902 Error: ZiGate: ----> Line 694 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2022-01-15 16:58:39.906 Error: ZiGate: ----> Line 197 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2022-01-15 16:58:39.910 Error: ZiGate: ----> Line 754 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8002
2022-01-15 16:58:39.914 Error: ZiGate: ----> Line 261 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/inRawAps.py', function inRawAps
2022-01-15 16:58:39.918 Error: ZiGate: ----> Line 344 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuya.py', function tuyaReadRawAPS
2022-01-15 16:58:39.923 Error: ZiGate: ----> Line 423 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuya.py', function tuya_response
2022-01-15 16:58:39.927 Error: ZiGate: ----> Line 660 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuyaTRV.py', function tuya_eTRV_response
2022-01-15 16:58:39.931 Error: ZiGate: ----> Line 199 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/tuyaTRV.py', function receive_LIDLMode
2022-01-15 16:58:39.936 Error: ZiGate: ----> Line 544 in '/home/udoox86/domoticz/plugins/Domoticz-Zigate/Modules/domoMaj.py', function MajDomoDevice
2022-01-15 16:58:39.940 Error: ZiGate: handle_error_in_thread
Yes spoke too soon ;-)
When setting Setpoint from device widget gives gives incorrect value to etrv.
eg setting to 20 degrees gives 72 on etrv and that is also giving back to device widget.
See log
2022-01-15 17:12:45.981 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 059c/01 dp: 10 dt: 02 data: 00000026
2022-01-15 17:12:45.982 ZiGate: tuya_eTRV_response - Nwkid: 059c dp: 10 datatype: 2 data: 00000026
2022-01-15 17:12:45.982 ZiGate: receive_setpoint - Nwkid: 059c/01 Setpoint: 38 for model taget: TS0601-_TZE200_chyvmhay
2022-01-15 17:12:45.982 ZiGate: receive_setpoint - After Nwkid: 059c/01 Setpoint: 19.0 for model taget: TS0601-_TZE200_chyvmhay
2022-01-15 17:12:45.988 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_ThermoSetpoint-b4e3f9fffec1ecea-01) 0:19.00
2022-01-15 17:12:46.002 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_ThermoSetpoint-b4e3f9fffec1ecea-01) 0:19.00
2022-01-15 17:12:46.151 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 059c/01 dp: 10 dt: 02 data: 00000026
2022-01-15 17:12:46.151 ZiGate: tuya_eTRV_response - Nwkid: 059c dp: 10 datatype: 2 data: 00000026
2022-01-15 17:12:46.151 ZiGate: receive_setpoint - Nwkid: 059c/01 Setpoint: 38 for model taget: TS0601-_TZE200_chyvmhay
2022-01-15 17:12:46.151 ZiGate: receive_setpoint - After Nwkid: 059c/01 Setpoint: 19.0 for model taget: TS0601-_TZE200_chyvmhay
2022-01-15 17:12:51.001 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 059c/01 dp: 18 dt: 02 data: 000000b5
2022-01-15 17:12:51.001 ZiGate: tuya_eTRV_response - Nwkid: 059c dp: 18 datatype: 2 data: 000000b5
2022-01-15 17:12:51.001 ZiGate: receive_temperature - Nwkid: 059c/01 Temperature: 181
2022-01-15 17:12:51.006 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_Temp-b4e3f9fffec1ecea-01) 18.1:18.1
2022-01-15 17:12:51.014 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_Temp-b4e3f9fffec1ecea-01) 18.1:18.1
2022-01-15 17:12:51.156 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 059c/01 dp: 18 dt: 02 data: 000000b5
2022-01-15 17:12:51.156 ZiGate: tuya_eTRV_response - Nwkid: 059c dp: 18 datatype: 2 data: 000000b5
2022-01-15 17:12:51.156 ZiGate: receive_temperature - Nwkid: 059c/01 Temperature: 181
--------------- Setting to 20 Degrees from widget gives 72 degrees on etrv
2022-01-15 17:13:21.714 ZiGate: tuya_setpoint - 059c setpoint: 2000
2022-01-15 17:13:21.714 ZiGate: tuya_setpoint - 059c dp 16 for SetPoint: 2000
2022-01-15 17:13:21.714 ZiGate: tuya_setpoint - 059c dp 16 to Tuya Format SetPoint: 400 for model TS0601-_TZE200_chyvmhay with data 00000190
2022-01-15 17:13:21.715 ZiGate: tuya_cmd - 059c/01 cmd: 00 payload: 114a00000e1002000400000190
2022-01-15 17:13:21.715 ZiGate: tuya_setpoint - 059c dp 16 cmd sent to Tuya Format SetPoint: 400
2022-01-15 17:13:21.728 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_ThermoSetpoint-b4e3f9fffec1ecea-01) 0:20.00
2022-01-15 17:13:26.954 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 059c/01 dp: 10 dt: 02 data: 00000090
2022-01-15 17:13:26.954 ZiGate: tuya_eTRV_response - Nwkid: 059c dp: 10 datatype: 2 data: 00000090
2022-01-15 17:13:26.954 ZiGate: receive_setpoint - Nwkid: 059c/01 Setpoint: 144 for model taget: TS0601-_TZE200_chyvmhay
2022-01-15 17:13:26.954 ZiGate: receive_setpoint - After Nwkid: 059c/01 Setpoint: 72.0 for model taget: TS0601-_TZE200_chyvmhay
2022-01-15 17:13:26.960 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_ThermoSetpoint-b4e3f9fffec1ecea-01) 0:72.00
2022-01-15 17:13:26.974 ZiGate: UpdateDevice - (ZiGate - TS0601-_TZE200_chyvmhay_ThermoSetpoint-b4e3f9fffec1ecea-01) 0:72.00
2022-01-15 17:13:27.054 ZiGate: tuya_response - Model: TS0601-_TZE200_chyvmhay Nwkid: 059c/01 dp: 10 dt: 02 data: 00000090
2022-01-15 17:13:27.055 ZiGate: tuya_eTRV_response - Nwkid: 059c dp: 10 datatype: 2 data: 00000090
2022-01-15 17:13:27.055 ZiGate: receive_setpoint - Nwkid: 059c/01 Setpoint: 144 for model taget: TS0601-_TZE200_chyvmhay
2022-01-15 17:13:27.055 ZiGate: receive_setpoint - After Nwkid: 059c/01 Setpoint: 72.0 for model taget: TS0601-_TZE200_chyvmhay
pipiche
Post by pipiche »
Ok. so we are progressing ;-)
can you try 6.0.010 ?
thanks
I tried 6.0.010
Setpoint is now working OK, but still have errors when switching mode as mentioned before (perhaps you missed my message).
waltervl wrote: Saturday 15 January 2022 17:07 Thank you, it is working. All changes seems to work (tested 10 minutes so have to be carefull).
See log:
pipiche
Post by pipiche »
My apologize for missing that one. Please check the updated version
pipiche wrote: Sunday 16 January 2022 15:20 My apologize for missing that one. Please check the updated version
Big thanks again!
All is running fine now, no issues anymore.
