Python Plugin: Speedtest
emeyedeejay
Re: Python Plugin: Speedtest
Post by emeyedeejay »
Last edited by emeyedeejay on Wednesday 28 March 2018 20:13, edited 1 time in total.
emeyedeejay
OK - might be this...
pi@bart:~/domoticz/plugins $ python -V
Python 2.7.13
pi@bart:~/domoticz/plugins $ python3 -V
Python 3.5.3
Not sure which one will be used or whihc versions are required. Serious learning curve on the go here! :D
Xorfor
Post by Xorfor »
@ emeyedeejay
I was able to reproduce your problem! Probably you switched off the EventSystem. Please check the following:
Setup => Settings
Other tab
Check that EventSystem (Lua/Blockly/Scripts) is enabled
And restart Domoticz
emeyedeejay
How did you fathom that out! OK - it was disabled (I have no idea how though)...
I now see this in the log:
2018-03-29 15:06:22.322 EventSystem: reset all events...
2018-03-29 15:06:22.322 EventSystem: reset all device statuses...
2018-03-29 15:06:22.331 EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2018-03-29 15:06:22.331 EventSystem: Started
2018-03-29 15:06:22.331 EventSystem: Queue thread started...
Is that related to Python version?
Thank you!
emeyedeejay
Rebooted and all up and running again - fantastic - thank you!
MIDJ
Xorfor
Post by Xorfor »
capman
Post by capman »
I have sudenly this error in my log.
internet speed.JPG (58.74 KiB) Viewed 3590 times
Should this be a domoticz, python or plugin issue ?
I run domoticz on a synology with beta version 3.9208
edit: Now (may) version 3.9317
andersbz
Post by andersbz »
Same for me
Running on beta 3.9227 and python 3.4.2
2018-04-15 20:25:40.883 Error: (Speedtest) 'onHeartbeat' failed 'FileNotFoundError'.
2018-04-15 20:25:40.883 Error: (Speedtest) ----> Line 156 in /home/pi/domoticz/plugins/xfr_speedtest/plugin.py, function onHeartbeat
2018-04-15 20:25:40.883 Error: (Speedtest) ----> Line 105 in /home/pi/domoticz/plugins/xfr_speedtest/plugin.py, function onHeartbeat
2018-04-15 20:25:40.883 Error: (Speedtest) ----> Line 884 in /usr/lib/python3.4/subprocess.py, function __init__
2018-04-15 20:25:40.883 Error: (Speedtest) ----> Line 1457 in /usr/lib/python3.4/subprocess.py, function _execute_child
EdwinK
Post by EdwinK »
Me too. Although the linenumbers are a bit different
2018-05-04 21:54:06.785 Error: (SpeedTest) 'onHeartbeat' failed 'FileNotFoundError'.
2018-05-04 21:54:06.785 Error: (SpeedTest) ----> Line 156 in /home/pi/domoticz/plugins/SpeedTest/plugin.py, function onHeartbeat
2018-05-04 21:54:06.785 Error: (SpeedTest) ----> Line 105 in /home/pi/domoticz/plugins/SpeedTest/plugin.py, function onHeartbeat
2018-05-04 21:54:06.786 Error: (SpeedTest) ----> Line 701 in /usr/lib/python3.5/subprocess.py, function __init__
2018-05-04 21:54:06.786 Error: (SpeedTest) ----> Line 1282 in /usr/lib/python3.5/subprocess.py, function _execute_child
videodrome
Post by videodrome »
Xorfor wrote: Tuesday 27 March 2018 19:18 @Ventron,
This Python plugin is using a option, which is not available in your Domoticz.
You have 2 options:
1. Update to the latest beta version of Domoticz. If you are planning to use more plugins, this is the recommended option.
or
2. Change the Speedtest plugin:
a. Open the plugin.py in an editor
b. Goto to line 177, the UpdateDevice procedure:
I prefer use the 3.8153 version, not beta or new stable? version, thanx for the tip
boboz2
Post by boboz2 »
Thanks for the plugin but it doesn't work on my system.
You can see the log below.
Xorfor
Post by Xorfor »
@boboz2:
These messages are not coming from the plugin. I guess that these messages are generated by PP-Manager?
1kke
Post by 1kke »
This plugin looks great, but unfortunately it's not working on my system.
I'm running Domoticz in an Alpine docker container in OMV4, I installed speedtest cli and this is working when running in the SSH terminal.
The speedtest plugin runs without error in the Domoticz log but it doesn't trigger the speedtest.
In the spoiler are the speedtest messages from Domoticz's log:
2018-09-25 20:57:04.739 (Speedtest) onHeartbeat called, run again in 28 heartbeats.
2018-09-25 20:57:14.716 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:57:14.758 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:57:14.758 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:57:14.758 (Speedtest) onHeartbeat called
2018-09-25 20:57:14.758 (Speedtest) onHeartbeat called, run again in 27 heartbeats.
2018-09-25 20:57:24.718 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:57:24.731 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:57:24.731 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:57:24.731 (Speedtest) onHeartbeat called
2018-09-25 20:57:24.731 (Speedtest) onHeartbeat called, run again in 26 heartbeats.
2018-09-25 20:57:34.720 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:57:34.755 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:57:34.755 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:57:34.755 (Speedtest) onHeartbeat called
2018-09-25 20:57:34.756 (Speedtest) onHeartbeat called, run again in 25 heartbeats.
2018-09-25 20:57:44.722 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:57:44.727 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:57:44.727 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:57:44.727 (Speedtest) onHeartbeat called
2018-09-25 20:57:44.727 (Speedtest) onHeartbeat called, run again in 24 heartbeats.
2018-09-25 20:57:54.725 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:57:54.748 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:57:54.748 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:57:54.748 (Speedtest) onHeartbeat called
2018-09-25 20:57:54.748 (Speedtest) onHeartbeat called, run again in 23 heartbeats.
2018-09-25 20:58:04.727 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:58:04.771 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:58:04.771 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:58:04.772 (Speedtest) onHeartbeat called
2018-09-25 20:58:04.772 (Speedtest) onHeartbeat called, run again in 22 heartbeats.
2018-09-25 20:58:14.729 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:58:14.744 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:58:14.744 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:58:14.744 (Speedtest) onHeartbeat called
2018-09-25 20:58:14.744 (Speedtest) onHeartbeat called, run again in 21 heartbeats.
2018-09-25 20:58:24.732 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:58:24.768 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:58:24.768 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:58:24.768 (Speedtest) onHeartbeat called
2018-09-25 20:58:24.768 (Speedtest) onHeartbeat called, run again in 20 heartbeats.
2018-09-25 20:58:34.734 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:58:34.742 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:58:34.742 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:58:34.742 (Speedtest) onHeartbeat called
2018-09-25 20:58:34.742 (Speedtest) onHeartbeat called, run again in 19 heartbeats.
2018-09-25 20:58:44.736 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:58:44.768 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:58:44.768 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:58:44.769 (Speedtest) onHeartbeat called
2018-09-25 20:58:44.769 (Speedtest) onHeartbeat called, run again in 18 heartbeats.
2018-09-25 20:58:54.738 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:58:54.774 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:58:54.774 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:58:54.774 (Speedtest) onHeartbeat called
2018-09-25 20:58:54.774 (Speedtest) onHeartbeat called, run again in 17 heartbeats.
2018-09-25 20:59:04.741 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:59:04.747 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:59:04.747 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:59:04.747 (Speedtest) onHeartbeat called
2018-09-25 20:59:04.748 (Speedtest) onHeartbeat called, run again in 16 heartbeats.
2018-09-25 20:59:14.743 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:59:14.768 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:59:14.768 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:59:14.768 (Speedtest) onHeartbeat called
2018-09-25 20:59:14.768 (Speedtest) onHeartbeat called, run again in 15 heartbeats.
2018-09-25 20:59:24.745 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:59:24.791 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:59:24.791 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:59:24.791 (Speedtest) onHeartbeat called
2018-09-25 20:59:24.791 (Speedtest) onHeartbeat called, run again in 14 heartbeats.
2018-09-25 20:59:34.747 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:59:34.763 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:59:34.763 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:59:34.763 (Speedtest) onHeartbeat called
2018-09-25 20:59:34.763 (Speedtest) onHeartbeat called, run again in 13 heartbeats.
2018-09-25 20:59:44.749 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:59:44.784 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:59:44.784 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:59:44.784 (Speedtest) onHeartbeat called
2018-09-25 20:59:44.784 (Speedtest) onHeartbeat called, run again in 12 heartbeats.
2018-09-25 20:59:54.751 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 20:59:54.752 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 20:59:54.752 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 20:59:54.752 (Speedtest) onHeartbeat called
2018-09-25 20:59:54.752 (Speedtest) onHeartbeat called, run again in 11 heartbeats.
2018-09-25 21:00:04.753 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:00:04.772 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:00:04.772 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:00:04.772 (Speedtest) onHeartbeat called
2018-09-25 21:00:04.772 (Speedtest) onHeartbeat called, run again in 10 heartbeats.
2018-09-25 21:00:14.755 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:00:14.793 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:00:14.793 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:00:14.793 (Speedtest) onHeartbeat called
2018-09-25 21:00:14.793 (Speedtest) onHeartbeat called, run again in 9 heartbeats.
2018-09-25 21:00:24.757 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:00:24.766 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:00:24.766 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:00:24.766 (Speedtest) onHeartbeat called
2018-09-25 21:00:24.766 (Speedtest) onHeartbeat called, run again in 8 heartbeats.
2018-09-25 21:00:34.760 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:00:34.791 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:00:34.791 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:00:34.791 (Speedtest) onHeartbeat called
2018-09-25 21:00:34.791 (Speedtest) onHeartbeat called, run again in 7 heartbeats.
2018-09-25 21:00:44.762 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:00:44.765 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:00:44.765 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:00:44.765 (Speedtest) onHeartbeat called
2018-09-25 21:00:44.765 (Speedtest) onHeartbeat called, run again in 6 heartbeats.
2018-09-25 21:00:54.764 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:00:54.785 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:00:54.785 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:00:54.786 (Speedtest) onHeartbeat called
2018-09-25 21:00:54.786 (Speedtest) onHeartbeat called, run again in 5 heartbeats.
2018-09-25 21:01:04.766 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:01:04.809 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:01:04.809 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:01:04.810 (Speedtest) onHeartbeat called
2018-09-25 21:01:04.810 (Speedtest) onHeartbeat called, run again in 4 heartbeats.
2018-09-25 21:01:14.768 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:01:14.780 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:01:14.780 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:01:14.781 (Speedtest) onHeartbeat called
2018-09-25 21:01:14.781 (Speedtest) onHeartbeat called, run again in 3 heartbeats.
2018-09-25 21:01:24.771 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:01:24.804 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:01:24.804 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:01:24.804 (Speedtest) onHeartbeat called
2018-09-25 21:01:24.805 (Speedtest) onHeartbeat called, run again in 2 heartbeats.
2018-09-25 21:01:34.773 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:01:34.779 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:01:34.780 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:01:34.780 (Speedtest) onHeartbeat called
2018-09-25 21:01:34.780 (Speedtest) onHeartbeat called, run again in 1 heartbeats.
2018-09-25 21:01:44.775 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:01:44.801 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:01:44.802 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:01:44.802 (Speedtest) onHeartbeat called
2018-09-25 21:01:54.778 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:01:54.825 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:01:54.825 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:01:54.825 (Speedtest) onHeartbeat called
2018-09-25 21:01:54.826 (Speedtest) onHeartbeat called, run again in 359 heartbeats.
2018-09-25 21:02:04.780 (Speedtest) Pushing 'onHeartbeatCallback' on to queue
2018-09-25 21:02:04.800 (Speedtest) Processing 'onHeartbeatCallback' message
2018-09-25 21:02:04.800 (Speedtest) Calling message handler 'onHeartbeat'.
2018-09-25 21:02:04.800 (Speedtest) onHeartbeat called
2018-09-25 21:02:04.800 (Speedtest) onHeartbeat called, run again in 358 heartbeats.
Somehow there was something wrong with my speedtest-cli, but there's another speedtest in my container (speedtest without -cli)
Changed _COMMAND = "speedtest-cli" in _COMMAND = "speedtest" in the Plugin.py and it's working.
kr.,
1kke
jeroenkl
Post by jeroenkl »
capman wrote: Sunday 15 April 2018 20:11 I have sudenly this error in my log.
Exactly the same for me. Latest beta on Synology. Other python plugins are working fine.
Anyone with a fix available?
berserk
Post by berserk »
hi,
i have a problem with the plugin. Since 1 week the plugin doesn't work. Python with lib is ok. Script lua was enable.
speedtest-cli --single work perfectly:
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by KEYYO (Paris) [1.88 km]: 89.427 ms
Testing download speed................................................................................
Download: 7.88 Mbit/s
Testing upload speed................................................................................................
Upload: 6.91 Mbit/s
But
2021-04-14 11:34:07.565 (internet) onHeartbeat called
2021-04-14 11:34:07.565 (internet) onHeartbeat called, run again in 340 heartbeats.
2021-04-14 11:34:17.529 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 11:34:17.534 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 11:34:17.534 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 11:34:17.534 (internet) onHeartbeat called
2021-04-14 11:34:17.534 (internet) onHeartbeat called, run again in 339 heartbeats.
2021-04-14 11:34:27.530 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 11:34:27.563 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 11:34:27.563 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 11:34:27.563 (internet) onHeartbeat called
2021-04-14 11:34:27.564 (internet) onHeartbeat called, run again in 338 heartbeats.
2021-04-14 11:34:37.532 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 11:34:37.582 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 11:34:37.582 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 11:34:37.582 (internet) onHeartbeat called
2021-04-14 11:34:37.582 (internet) onHeartbeat called, run again in 337 heartbeats.
2021-04-14 11:34:47.534 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 11:34:47.550 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 11:34:47.550 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 11:34:47.550 (internet) onHeartbeat called
2021-04-14 11:34:47.550 (internet) onHeartbeat called, run again in 336 heartbeats.
2021-04-14 11:34:57.536 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 11:34:57.568 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 11:34:57.568 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 11:34:57.568 (internet) onHeartbeat called
2021-04-14 11:34:57.568 (internet) onHeartbeat called, run again in 335 heartbeats.
2021-04-14 11:35:07.538 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 11:35:07.568 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 11:35:07.568 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 11:35:07.568 (internet) onHeartbeat called
2021-04-14 11:35:07.568 (internet) onHeartbeat called, run again in 334 heartbeats.
I have no idea...... Sorry for my basic english.
Best regard
jeroen1985
Post by jeroen1985 »
i run domoticz on nuc and debian 10 and i had the same issue so i uninstall speedtest.cli en restart and again installing speedtest.cli
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
