https://github.com/Xorfor/Domoticz-Pi-hole-Plugin
Version 3.0.0
- Plugin rewritten, better coding
- Better handling on/off switch
- Added device to show last 2 blocked domains
2018-02-21 21:44:47.499 Error: (Pi-hole) ----> Line 267 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onMessage
2018-02-21 21:44:47.500 Error: (Pi-hole) ----> Line 139 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onMessage
2018-02-21 21:45:47.554 Error: (Pi-hole) 'onMessage' failed 'KeyError'.
2018-02-21 21:45:47.555 Error: (Pi-hole) ----> Line 267 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onMessage
2018-02-21 21:45:47.555 Error: (Pi-hole) ----> Line 139 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onMessage
(PI-hole) Device creation failed, Domoticz settings prevent accepting new devices.
2018-03-30 14:34:22.227 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:34:22.227 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:34:22.227 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:35:22.243 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:35:22.243 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:35:22.243 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:36:22.255 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:36:22.255 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:36:22.255 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:37:22.262 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:37:22.262 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:37:22.262 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:38:22.258 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:38:22.258 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:38:22.258 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:39:22.260 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:39:22.260 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:39:22.260 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:40:22.265 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:40:22.265 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:40:22.265 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-04-01 19:28:53.920 (Pi-hole Summary) Initialized version 3.0.1, author 'Xorfor'
2018-04-01 19:28:53.925 (Pi Monitor) Debug logging mask set to: NONE
2018-04-01 19:28:53.962 Error: (Pi Monitor) 'onStart' failed 'KeyError'.
2018-04-01 19:28:53.962 Error: (Pi Monitor) ----> Line 164 in /home/pi/domoticz/plugins/Domoticz-PiMonitor-Plugin/plugin.py, function onStart
2018-04-01 19:28:53.962 Error: (Pi Monitor) ----> Line 59 in /home/pi/domoticz/plugins/Domoticz-PiMonitor-Plugin/plugin.py, function onStart
2018-04-01 19:28:53.966 (Pi-hole Summary) Debug logging mask set to: NONE
2018-04-01 19:28:53.966 (Pi-hole Summary) Image created. ID: 109
2018-04-01 19:28:53.966 (Pi-hole Summary) Devices created.
2018-04-15 09:26:46.719 Error: (Pi_Hole) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-04-15 09:26:46.719 Error: (Pi_Hole) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-04-15 09:26:46.720 Error: (Pi_Hole) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Calling message handler 'onMessage'.
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) onMessage called for RecentBlocked
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Data: []
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Pushing 'DisconnectDirective' on to queue
2023-04-25 10:35:54.169 (Pi-Hole) Processing 'DisconnectDirective' message
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Disconnect directive received for '192.168.1.50:80'.
2023-04-25 10:35:54.169 (Pi-Hole) Handling TCP disconnect, socket (192.168.1.50:80) is connected
2023-04-25 10:35:54.169 (Pi-Hole) Queued asynchronous read aborted (192.168.1.50:80), [125] Operation canceled.
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Pushing 'DisconnectedEvent' on to queue
2023-04-25 10:35:54.169 (Pi-Hole) Processing 'DisconnectedEvent' message
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Disconnect event received for '192.168.1.50:80'.
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Pushing 'onDisconnectCallback' on to queue
2023-04-25 10:35:54.170 (Pi-Hole) Processing 'DisconnectedEvent' message
Users browsing this forum: NaTuRaL, RNEE, solarboy and 1 guest
