Python Plugin: Pi-hole Summary Topic is solved
Xorfor
Post by Xorfor »
I have created a Python plugin to monitor summary data from Pi-hole (a black hole for internet advertisements):
https://github.com/Xorfor/Domoticz-Pi-hole-Plugin
Version 3.0.0
  1. Plugin rewritten, better coding
  2. Better handling on/off switch
  3. Added device to show last 2 blocked domains
Xorfor
Re: Python Plugin: Pi-hole Summary
Post by Xorfor »
This plugin is completely rewritten. It has now 9(!) devices showing summary data from Pi-hole.
Also a switch is available (if you entered the API token), to switch On/Off Pi-hole.
For some reason, I am not able (yet) to add the Pi-hole image to the devices. Any idea?
cryonic90
Post by cryonic90 »
I would really like to use this plugin, but I get the following error in the log:
2017-12-26 17:02:48.293 Error: (Pihole) failed to parse parameters, Message or Message,Verb,URL,Headers,Delay expected.
2017-12-26 17:02:48.293 Error: (Pihole) 'CConnection_send' failed 'TypeError':'a bytes-like object is required, not 'dict''.
Can you help me with this?
Xorfor
Post by Xorfor »
Which Domoticz version are running? For plugins you better can update to the latest beta.
Also on which OS are you running Domoticz and how are the parameters filled in for this plugin. Can you give me some more details?
cryonic90
Post by cryonic90 »
I'm running this on the latest stable version of Domoticz (8153).
The rest of the settings are the ip address of the pihole server and the port 80.
And ofcourse the API key (which I've checked twice).
But does this mean that this plugin doesn't work with the latest stable version?
edit:
Ok, so updated to the latest beta and indeed, now it does work :) Thanks!
Xorfor
Post by Xorfor »
Xorfor
Post by Xorfor »
I moved the plugin to https://github.com/Xorfor/Domoticz-Pi-hole-Plugin
The Percentage device is changed to Custom, so that this device also has the Pi-hole image :)
EdwinK
Post by EdwinK »
Is it also possible to see the top-10 domains blocked? I know I can go to the Pi-hole admin to see that, but we can do that for the other info as well ;)
Xorfor
Post by Xorfor »
My first version of the Pi-hole plugin, only had the On/Off switch voor Pi-hole. I use Domoticz not only to turn on/off lights, but also for OSMC (Kodi), receiver, etc. As a kind of remote control ;) .
The other information was easy to add and a kind of bonus.
The top-10 domains blocked can be added, but I am limited in the amount of text in the Text device. Probably a top 3 will be possible. And I can not change the icon for a text device :( .
I will think about this.
Xorfor
Post by Xorfor »
Version 3 is available!
remb0
Post by remb0 »
after last update from beta and your plugin i get:
2018-02-21 21:44:47.499 Error: (Pi-hole) ----> Line 267 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onMessage
2018-02-21 21:44:47.500 Error: (Pi-hole) ----> Line 139 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onMessage
2018-02-21 21:45:47.554 Error: (Pi-hole) 'onMessage' failed 'KeyError'.
2018-02-21 21:45:47.555 Error: (Pi-hole) ----> Line 267 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onMessage
2018-02-21 21:45:47.555 Error: (Pi-hole) ----> Line 139 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onMessage
what can it be?
Xorfor
Post by Xorfor »
Do you mean that you also updated the Pi-hole plugin?
Try the latest version of the plugin. To be sure:
Install the latest version of the plugin
Goto Setup -> Hardware
Select the Pi-hole hardware
Click on Delete (and Ok)
Click on Add
EdwinK
Post by EdwinK »
After getting no data for some time, I thought i would reinstall the plugin. First i deleted the older version I had and then added it again.
 (PI-hole) Device creation failed, Domoticz settings prevent accepting new devices.
I clicked the enable 'new hardware detection for 5 minutes' button, but the above error is shown.
Edit: Fixed.
emeyedeejay
Post by emeyedeejay »
Raspbian Stretch
Rpi 3 B+
Domoiticz Beta 3.9133
Seeing this in my log suddenly:
2018-03-30 14:34:22.227 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:34:22.227 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:34:22.227 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:35:22.243 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:35:22.243 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:35:22.243 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:36:22.255 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:36:22.255 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:36:22.255 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:37:22.262 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:37:22.262 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:37:22.262 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:38:22.258 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:38:22.258 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:38:22.258 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:39:22.260 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:39:22.260 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:39:22.260 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:40:22.265 Error: (Pi-hole Summary) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-03-30 14:40:22.265 Error: (Pi-hole Summary) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-03-30 14:40:22.265 Error: (Pi-hole Summary) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
emeyedeejay
Beta v 3.9139
Getting the following on startup.
2018-04-01 19:28:53.920 (Pi-hole Summary) Initialized version 3.0.1, author 'Xorfor'
2018-04-01 19:28:53.925 (Pi Monitor) Debug logging mask set to: NONE
2018-04-01 19:28:53.962 Error: (Pi Monitor) 'onStart' failed 'KeyError'.
2018-04-01 19:28:53.962 Error: (Pi Monitor) ----> Line 164 in /home/pi/domoticz/plugins/Domoticz-PiMonitor-Plugin/plugin.py, function onStart
2018-04-01 19:28:53.962 Error: (Pi Monitor) ----> Line 59 in /home/pi/domoticz/plugins/Domoticz-PiMonitor-Plugin/plugin.py, function onStart
2018-04-01 19:28:53.966 (Pi-hole Summary) Debug logging mask set to: NONE
2018-04-01 19:28:53.966 (Pi-hole Summary) Image created. ID: 109
2018-04-01 19:28:53.966 (Pi-hole Summary) Devices created.
EdwinK
Post by EdwinK »
Getting the following error:
2018-04-15 09:26:46.719 Error: (Pi_Hole) 'onHeartbeat' failed 'AttributeError':''str' object has no attribute 'Connect''.
2018-04-15 09:26:46.719 Error: (Pi_Hole) ----> Line 283 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
2018-04-15 09:26:46.720 Error: (Pi_Hole) ----> Line 244 in /home/pi/domoticz/plugins/Domoticz-Pi-hole-Plugin/plugin.py, function onHeartbeat
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
Installed the Plugin from :https://github.com/Xorfor/Domoticz-Pi-hole-Plugin
After install i see lot of Signal Faults. After disable the plugin the errors are gone.
Domoticz: V3.9227 and tried on later builds
Chris12
Domoticz version: 2021.1
Post by Chris12 »
@Xorfor, it looks like your plug-in does not longer work since the latest versions of Pi-Hole.
For me no values are read anymore since 17/3/2023.
When I check the debug logging I can see messages like:
 2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Calling message handler 'onMessage'.
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) onMessage called for RecentBlocked
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Data: []
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Pushing 'DisconnectDirective' on to queue
2023-04-25 10:35:54.169 (Pi-Hole) Processing 'DisconnectDirective' message
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Disconnect directive received for '192.168.1.50:80'.
2023-04-25 10:35:54.169 (Pi-Hole) Handling TCP disconnect, socket (192.168.1.50:80) is connected
2023-04-25 10:35:54.169 (Pi-Hole) Queued asynchronous read aborted (192.168.1.50:80), [125] Operation canceled.
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Pushing 'DisconnectedEvent' on to queue
2023-04-25 10:35:54.169 (Pi-Hole) Processing 'DisconnectedEvent' message
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Disconnect event received for '192.168.1.50:80'.
2023-04-25 10:35:54.169 Pi-Hole: (Pi-Hole) Pushing 'onDisconnectCallback' on to queue
2023-04-25 10:35:54.170 (Pi-Hole) Processing 'DisconnectedEvent' message
Where 192.168.1.50 is the Pi-Hole system IP.
My domoticz (docker) version: Version: 2021.1 (build 13243)
Pi-Hole version: v5.16.2, FTL v5.22, Web Interface v5.19
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
sincze
Domoticz version: 2024.4
Post by sincze »
It seems the plugin has been removed from Github ??
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
voyo
Post by voyo »
since this plugin is abandoned and not working with new software - I decided to create new similar version
viewtopic.php?t=44132
