Hello dear comunity,
I have connected on Domoticz my UPS, through UPS NUT plugin.
Everything was OK until 2025.2 upgrade.
UPS Monitor has disappeared from the hardware type list .....
Is it normal? Is it a bug that should be corrected? Is there any other solution to configure?
Thanks for any support
I have attached 2 files showing
before (2025.1)
after (2025.2)
UPS Monitor has disappeared from Hardware Type in 2025.2 vesrion...??? Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2026.3
Re: UPS Monitor has disappeared from Hardware Type in 2025.2 vesrion...???
I assume it is a python plugin.
Is the python plugin environment running on your new install? https://wiki.domoticz.com/Using_Python_ ... leshooting
Do you use other python plugins and they are running fine?
PhilGood
- Domoticz version: 2025.2
Hummm
you are totaly right. I didn't notice, but it doesn't run...
I moved my instalation under docker when upgraded to 2025.2
I have tried to instal nardo86/nut-server Docker image, but didn't succeed to have it running
I'm afraid I will loose this function
No, but you have to install the plugin in a different way because you use docker......
https://wiki.domoticz.com/Docker#Python_Plugins
jannl
- Domoticz version: 2026.1.x
Exactly, I also use the ups monitor in Docker. Should work fine.
PhilGood
THANK YOU SO MUCH !
I totaly missed this management of the pluggins in docker mode.
You saved me on this one.
I love this comunity
