GPIO with docker Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
solarboy
Domoticz version: 2024.6
GPIO with docker
Post by solarboy »
I have been trying to follow the GPIO guide on the wiki, however I tried installing "generic sysfs GPIO" but no devices were created. I tried using the command
echo 11 > /sys/class/gpio/export
but got this error
-bash: echo: write error: Invalid argument
At this point I tried the second method however it appears wiringpi is no longer available.
Unable to locate package wiringPi
Is there any way to get this working ?
Domoticz version: 2025.1
Re: GPIO with docker
A quick search on the forum gave me this: viewtopic.php?p=311392#p311392
solarboy
Post by solarboy »
Thanks walter, I managed to get something working with a python gpio2mqttAD script, still a work in progress but functional.
import paho.mqtt.client as mqtt
import RPi.GPIO as GPIO
import time
import json
# GPIO setup
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
# Define relay GPIO pins (BCM numbering)
RELAY_PINS = [17, 27, 22, 23]  # Pin 23 = GPIO23 (Physical 16)
for pin in RELAY_PINS:
    GPIO.setup(pin, GPIO.OUT)
    GPIO.output(pin, GPIO.HIGH)  # Inverted logic: HIGH = OFF (for active low relays)
# MQTT settings
MQTT_BROKER = "localhost"  # Address of your MQTT broker (e.g., localhost or IP)
MQTT_PORT = 1883
MQTT_TOPIC_PREFIX = "domoticzSolar"
MQTT_DISCOVERY_PREFIX = "homeassistant/switch"  # Home Assistant discovery style
# MQTT client setup
mqtt_client = mqtt.Client()
# Function to generate a unique ID based on GPIO pin
def get_unique_id(pin):
    return f"gpio-relay-board-{pin}"
def on_connect(client, userdata, flags, rc):
    print(f"Connected to MQTT broker with result code {rc}")
    # Send discovery message for each relay (only once)
    for i, pin in enumerate(RELAY_PINS, start=1):
        relay_name = f"Relay {i}"
        relay_id = f"relay{i}"
        unique_id = get_unique_id(pin)  # Static unique ID based on GPIO pin
        # Prepare the MQTT discovery payload
        discovery_payload = {
            "name": relay_name,
            "command_topic": f"{MQTT_TOPIC_PREFIX}/{relay_id}/set",
            "state_topic": f"{MQTT_TOPIC_PREFIX}/{relay_id}/state",
            "payload_on": "ON",
            "payload_off": "OFF",
            "state_on": "ON",
            "state_off": "OFF",
            "retain": True,  # Ensure the configuration persists after restart
            "unique_id": unique_id,
            "device": {
                "identifiers": [unique_id],  # Device identifier as unique_id
                "name": "GPIO Relay Board",
                "model": "Pi GPIO",
                "manufacturer": "YourName"
            "device_class": "switch"
        # Send the discovery message to the broker only once
        discovery_topic = f"{MQTT_DISCOVERY_PREFIX}/gpio-relay-board-{pin}/config"
        mqtt_client.publish(discovery_topic, json.dumps(discovery_payload), retain=True)
        print(f"Published MQTT discovery message for {relay_name} with unique_id {unique_id}")
def on_message(client, userdata, msg):
    topic_parts = msg.topic.split("/")
    if len(topic_parts) < 3:
        return
    relay_name = topic_parts[1]
    if relay_name.startswith("relay"):
        try:
            relay_num = int(relay_name[5:])
            if 1 <= relay_num <= len(RELAY_PINS):
                if msg.payload.decode() == "ON":
                    GPIO.output(RELAY_PINS[relay_num - 1], GPIO.LOW)  # Inverted logic
                    mqtt_client.publish(f"{MQTT_TOPIC_PREFIX}/{relay_name}/state", "ON", retain=True)
                elif msg.payload.decode() == "OFF":
                    GPIO.output(RELAY_PINS[relay_num - 1], GPIO.HIGH)  # Inverted logic
                    mqtt_client.publish(f"{MQTT_TOPIC_PREFIX}/{relay_name}/state", "OFF", retain=True)
        except ValueError:
            print(f"Invalid relay number: {relay_name}")
def run_gpio_mqtt():
    mqtt_client.on_connect = on_connect
    mqtt_client.on_message = on_message
    mqtt_client.connect(MQTT_BROKER, MQTT_PORT, 60)
    mqtt_client.loop_start()
    # Subscribe to relay control topics
    for i in range(1, len(RELAY_PINS) + 1):
        mqtt_client.subscribe(f"{MQTT_TOPIC_PREFIX}/relay{i}/set")
    try:
        while True:
            time.sleep(1)
    except KeyboardInterrupt:
        print("Shutting down...")
        GPIO.cleanup()
        mqtt_client.disconnect()
if __name__ == "__main__":
    run_gpio_mqtt()
I have to disable device creation as the domoticz creates new devices on each start, but it does work. Need to work on the auto discovery stuff.
solarboy
Post by solarboy »
Is there any reason new devices created on the slave aren't visible on the main Domoticz instance ? I have a previously set up test virtual switch that is working so the basic connection is fine but new devices aren't appearing. I have "allow new devices" enabled and I have tried starting and stopping the "Domoticz Remote Server" hardware.
When using remote device sharing you have to open up the sharing port (default 6144) in the docker image configuration.
solarboy
Post by solarboy »
Yeah, did that and it was working before and created a test virtual device which still works.
services:
  domoticz:
    image: domoticz/domoticz:stable
    container_name: domoticz
    restart: unless-stopped
    # Pass devices to container
    # devices:
    #   - "/dev/serial/by-id/usb-0658_0200-if00-port0:/dev/ttyACM0"
    ports:
      - "8080:8080"
      - "6144:6144"
    volumes:
      - ./config:/opt/domoticz/userdata
      #- ./config/www/templates:/opt/domoticz/www/templates
    environment:
      - TZ=Europe/Lisbon
      #- LOG_PATH=/opt/domoticz/userdata/domoticz.log
However new devices arent being created, neither another identical virtual switch or some MQTT Discovery Devices I have on the slave.
Nothing in the logs about remote sharing?
From the wiki
Data is pushed to the Main from the Remote triggered by device changes. So if a device changes it will be synchronised.
It would be wise to check the "Setup | Log" to double check there are no errors.
solarboy
Post by solarboy »
Nothing in the logs but while I was asleep the solution came to me ; the newer devices needed to be added in "Set Devices" as they didn't exist when I created the remote user.
Thanks for your help Walter.
akamming
Post by akamming »
You are describing a very difficult solution.
Just google on “docker gpio Access raspberry pi” and you get several articles describing solutions.
The most easy one is running the docker container in privileged mode..
