Bug in enumerating Notifications Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
fdemees
Domoticz version: 2024.7
Post by fdemees »
Domoticz version 2024.7
running on Rpi 3B+ / debian 11.11
6 Hardware devices in Dz: Dummy, SMA onduleur, MQTT local, Meteo NL (buienradar), Zigbee ITEAD_SONOFF_Zigbee_3.0, and a second instance of Dummy with less logging.
Hello, this is a translation of my article in the French forum, which did not get any reply since several days.
(link: https://easydomoticz.com/forum/viewtopic.php?t=14309)
The problem lies with all my switches where notifications have been set, but cannot be retrieved from the UI.
When peeking into the database, the notifications are correctly set in the table 'Notifications', and they are executed when applicable.
Example: I have a switch (virtual device #124) which is triggered by the alarm system, when the alarm is activated/armed and another trigger when it is disarmed. Dz receives the event via http. The link between the alarm system and Dz is not questionable here.
The same problem occurs with notifications on all devices.
Example of a device, here #124
device 124.png (27.47 KiB) Viewed 579 times
Add a notification event:
add notification.png (71.28 KiB) Viewed 579 times
The database contains the notification:
# sqlite3 domoticz.db
SQLite version 3.34.1 2021-01-20 14:10:07
Enter ".help" for usage hints.
sqlite> select * from Notifications;
53|124|S|Alarme maison armée|email;telegram|0|0|0||1
On the swich widget, the Notifications button has become purple instead of blue.
Click on notifications, and the list is now empty
notification disparue.png (28.61 KiB) Viewed 579 times
The database still contains the notification.
By chance does someone have a bright idea ?
Domoticz on Rpi 3B+, ZigbeeforDomoticz, Sonoff Zigbee coordinator, several Sonoff/ESPEasy/Tasmota, IPX800, several Zigbee things, Ksenia Lares
Re: Bug in enumerating Notifications
How do you trigger the switch device 124? With an JSON API call?
What is the call you use? As some commands like &param=udevice do not trigger actions, so use the &switchcmd option.
https://wiki.domoticz.com/Domoticz_API/ ... eral_notes
fdemees
Post by fdemees »
Hello @waltervl
Here is the command issued by the alarm system: /json.htm?type=command&param=switchlight&idx=124&switchcmd=On
The problem is not related with the triggers. It is simply that the UI does not retrieve the Notifications associated with the device.
When clicking on this button:
notification confirmée.png (20.62 KiB) Viewed 549 times
I receive an empty list:
notification disparue.png (28.61 KiB) Viewed 549 times
BTW you are talking about udevice. I have been searching for a way to avoid the pollution in the logs for another http verbose device. (any presence under any of the IR detectors in the house). Either use udevice= , or create a second instance of hardware "Dummy" with less logging, and one virtual switch child...
Suddenly, while we are discussing this, I wonder whether 2 instances of the dummy device could be the cause of the malfunction of the UI ?
fdemees
Post by fdemees »
Update: I have deleted the virtual switch, and I have deleted the second "Dummy" hardware device.
It did not resolve the problem.
Perhaps try to create a notification without special characters like é
It could be a encoding issue on the website.
Also check with getnotification API call for your device to see if you get the notification.
/json.htm?idx=<deviceIDX>&param=getnotificationtypes&type=command
If the notification is listed the perhaps try to open the webgui in a private/incognito websession to see if it solves the issue.
fdemees
Post by fdemees »
Dear @waltervl,
After having removed he second Dummy hardware instance this afternoon, I checked that the Notifications still didn't show.
Then, while redacting this reply: I have installed the Android app ; I have called the API as you suggested above ; I have rebooted the RPi.
And miracle: everything is now normal! So I don't know which action did what.
I hate such mysteries. :o
I thank you a lot ;)
So, below you will find my initial text with database, API and Android app showing device #124.
extract of table: Notifications:
API call: wget "127.0.0.1/json.htm?idx=124&param=getnotificationtypes&type=command"
        "result" :
                        "ptag" : "S",
                        "text" : "Switch On",
                        "val" : 7
                        "ptag" : "O",
                        "text" : "Switch Off",
                        "val" : 16
        "status" : "OK",
        "title" : "GetNotificationTypes"
The Android app shows the notification (before the reboot):
Great that it is working again. I doubt that re-installing the Android app solved the issue. But also I have no idea what really solved it.
fdemees
Post by fdemees »
I have been able to reproduce.
The culprit seems to be the second Dummy Hardware instance (although I gave a different name: "virtual (nolog)" instead of "virtual" )
The Notifications could not be displayed anymore for any switch.
Removing the additional hardware device and refreshing the browser cache ... and voilà everything is back.
Also I have now discovered that udevice triggers the notifications although the documentation seems to indicate that no subsequent action would occur following udevice. The "Last seen" indicator is also updated.
