Asynchronous shell command example  [Solved]
javalin
Domoticz version: 4.10717
Post by javalin »
This is my example that seems to work very well: I have a python plugin that reads data from a solar controller and sent to domoticz, sometimes service lost connection from server and don´t restart, using the help of dzvents and asynchronous shell command now you can restart the service daemon if, temperature from storage tank or solar collector do not update at the time you determine.
It can be used for other uses. Here it is:
local scriptVar = 'Restart service daemon'
return
    on =
        timer =
            'every 30 minutes', -- for DEBUG
	    shellCommandResponses =
	        "myTrigger"
        httpResponses =
            scriptVar .. '*',
    logging =
        level = domoticz.LOG_DEBUG ,
        marker = scriptVar,
    execute = function(dz, item)
        local temperature = dz.devices(594) -- your temp device you want control
        local lastUpdate = 0
        local function makeTimeStamp(dateString, pattern)
            local pattern = pattern or  "(%d+)%-(%d+)%-(%d+)%s(%d+):(%d+)"      -- %d+ = 1 or more digits , %.* = 0 or more any character
            local year, month, day, hour, minute = dateString:match(pattern)
            return os.time({year = year, month = month, day = day, hour = hour, min = minute})
        local function triggerJSON(id, delay)
            url = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=temp&idx=' .. id .. '&range=day'
            dz.openURL({ url = url, callback = scriptVar .. '_' .. id}).afterSec(delay or 0)
            --/json.htm?type=graph&sensor=temp&idx=IDX&range=day
        -- main
        if item.isTimer then
            triggerJSON(temperature.id)
            return
        elseif item.isShellCommandResponse then
            dz.log ("Response object: " .. item.data, dz.LOG_INFO)
        if item.ok and item.isJSON then
            rt = item.json.result
            for index, record in ipairs(rt) do
                if index == #rt then
                  lastUpdate = dz.time.dDate - makeTimeStamp(record.d)
                  if lastUpdate > 420 then  -- lastUpdate higher than 420 second, 7 minutes
                     dz.executeShellCommand({
                     command = "sudo systemctl restart nabto",
                     callback = "myTrigger",
                     timeout = 2, -- max execution time in seconds
            dz.log('Problem retrieving data..',dz.LOG_ERROR)
            dz.log(item,dz.LOG_DEBUG)
Re: Asynchronous shell command example  [Solved]
javalin wrote: Monday 11 January 2021 20:06 This is my example that seems to work very well: I have a python plugin that reads data from a solar controller and sent to domoticz, sometimes service lost connection from server and don´t restart, using the help of dzvents and asynchronous shell command now you can restart the service daemon if, temperature from storage tank or solar collector do not update at the time you determine.
Any reason why you use the JSON? the lastUpdate is native available in dzVents
return
    on =
        timer =
            scriptVar,
    logging =
        marker = scriptVar,
        -- main
        if item.isTimer and temperature.lastUpdate.minutesAgo > 7 then
                callback = scriptVar,
javalin
Post by javalin »
Thanks waaren. I have not applied it due to my ignorance. It would have saved me a few lines, at least it was fun getting it. :D
