It can be used for other uses. Here it is:
local scriptVar = 'Restart service daemon'
return
on =
timer =
'every 30 minutes', -- for DEBUG
shellCommandResponses =
"myTrigger"
httpResponses =
scriptVar .. '*',
logging =
level = domoticz.LOG_DEBUG ,
marker = scriptVar,
execute = function(dz, item)
local temperature = dz.devices(594) -- your temp device you want control
local lastUpdate = 0
local function makeTimeStamp(dateString, pattern)
local pattern = pattern or "(%d+)%-(%d+)%-(%d+)%s(%d+):(%d+)" -- %d+ = 1 or more digits , %.* = 0 or more any character
local year, month, day, hour, minute = dateString:match(pattern)
return os.time({year = year, month = month, day = day, hour = hour, min = minute})
local function triggerJSON(id, delay)
url = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=temp&idx=' .. id .. '&range=day'
dz.openURL({ url = url, callback = scriptVar .. '_' .. id}).afterSec(delay or 0)
--/json.htm?type=graph&sensor=temp&idx=IDX&range=day
-- main
if item.isTimer then
triggerJSON(temperature.id)
return
elseif item.isShellCommandResponse then
dz.log ("Response object: " .. item.data, dz.LOG_INFO)
if item.ok and item.isJSON then
rt = item.json.result
for index, record in ipairs(rt) do
if index == #rt then
lastUpdate = dz.time.dDate - makeTimeStamp(record.d)
if lastUpdate > 420 then -- lastUpdate higher than 420 second, 7 minutes
dz.executeShellCommand({
command = "sudo systemctl restart nabto",
callback = "myTrigger",
timeout = 2, -- max execution time in seconds
dz.log('Problem retrieving data..',dz.LOG_ERROR)
dz.log(item,dz.LOG_DEBUG)
