Request: Icon change by dzvents in a selector switch [Solved]
I would like to change to icon of a selector switch by dzVents according to the level.
- waaren
Re: Request: Icon change by dzvents in a selector switch
Attached script works for me.
The icon Numbers can be found by changing the icon manually using the GUI and peek in the database to see the result in the custom image field. Could be there is an easier way to get these ?
I don't think this function will make it as a native dzVents command but if it's useful for you and you want to use it for multiple devices and and if you experience no side effects, you can implement it as a global helper function.
-- Icon changer
return { on = {
devices = {1423}, -- change to your device
logging =
level = domoticz.LOG_DEBUG, -- switch to LOG_ERROR when OK
marker = 'setIcon'
execute = function(dz, item)
local icons = { -- level = iconNumber
[0] = 10,
[10] = 13,
[20] = 16,
[30] = 14,
[40] = 14,
[50] = 14,
[60] = 14,
local function setIcon(iconNumber)
local url = dz.settings['Domoticz url'] .. '/json.htm?type=setused&used=true&name=' .. dz.utils.urlEncode(item.name) ..
'&description=' .. dz.utils.urlEncode(item.description) .. -- Required. If not set it will be blanked out.
'&idx=' .. item.id ..
'&switchtype=' .. item.switchTypeValue ..
'&customimage=' .. iconNumber
return dz.openURL(url)
if item.level ~= item.lastLevel then
setIcon(icons[item.level])
dz.log('No Icon change necessary' .. item.id,dz.LOG_DEBUG)
Perfect, TNX.
I try it to morrow.
Tnx again. It works perfectly. Now hunting for nice icons which fit my purpose.
- Domoticz version: 2020.2
Which program is the best way to see what the IconNumber is in the DB?
Raspberry 4 - USB boot Domoticz /|\ Raspberry 2B - Dashticz /|\ Tasmota device's /|\ Philips Hue & Yeelight
- erem
- Domoticz version: 2021.1
@Larsoss
i use sqlitebrowser (sudo apt-get install sqlitebrowser) on buster.
Works well.
Works well.
Regards,
Rob
Rob
- waaren
Re: Request: Icon change by dzvents in a selector switch [Solved]
sqlitebrowser does require a GUI to linux
Any sqlite db browser will do. I mostly use sqlite3 on Linux. Look for CustomImage field in DeviceStatus table.
Using dzVents you can set the icon on devicetypes for which it is allowed with the setIcon function.
