Request: Icon change by dzvents in a selector switch  [Solved]
EddyG
Post by EddyG »
I would like to change to icon of a selector switch by dzVents according to the level.
Re: Request: Icon change by dzvents in a selector switch
EddyG wrote: Monday 01 April 2019 11:48 I would like to change to icon of a selector switch by dzVents according to the level.
Attached script works for me.
The icon Numbers can be found by changing the icon manually using the GUI and peek in the database to see the result in the custom image field. Could be there is an easier way to get these ?
I don't think this function will make it as a native dzVents command but if it's useful for you and you want to use it for multiple devices and and if you experience no side effects, you can implement it as a global helper function.
-- Icon changer
return  {   on =    {
                       devices         = {1423}, -- change to your device
        logging =
                        level       = domoticz.LOG_DEBUG,  -- switch to LOG_ERROR when OK
                        marker      = 'setIcon'
    execute = function(dz, item)
        local icons =     { -- level = iconNumber
                            [0]  = 10,
                            [10] = 13,
                            [20] = 16,
                            [30] = 14,
                            [40] = 14,
                            [50] = 14,
                            [60] = 14,
        local function setIcon(iconNumber)
            local url = dz.settings['Domoticz url'] .. '/json.htm?type=setused&used=true&name=' .. dz.utils.urlEncode(item.name) ..
            '&description=' .. dz.utils.urlEncode(item.description) .. -- Required. If not set it will be blanked out.
            '&idx=' .. item.id ..
            '&switchtype=' .. item.switchTypeValue ..
            '&customimage=' .. iconNumber
            return dz.openURL(url)
        if item.level ~= item.lastLevel then
            setIcon(icons[item.level])
            dz.log('No Icon change necessary' .. item.id,dz.LOG_DEBUG)
EddyG
Post by EddyG »
Perfect, TNX. :D I try it to morrow.
EddyG
Post by EddyG »
Tnx again. It works perfectly. Now hunting for nice icons which fit my purpose. :D
Larsoss
Post by Larsoss »
Which program is the best way to see what the IconNumber is in the DB?
Raspberry 4 - USB boot Domoticz /|\ Raspberry 2B - Dashticz /|\ Tasmota device's /|\ Philips Hue & Yeelight
erem
Domoticz version: 2021.1
Post by erem »
@Larsoss
i use sqlitebrowser (sudo apt-get install sqlitebrowser) on buster.
Works well.
Regards,
Rob
Re: Request: Icon change by dzvents in a selector switch  [Solved]
Larsoss wrote: Tuesday 13 October 2020 12:57 Which program is the best way to see what the IconNumber is in the DB?
sqlitebrowser does require a GUI to linux
Any sqlite db browser will do. I mostly use sqlite3 on Linux. Look for CustomImage field in DeviceStatus table.
Using dzVents you can set the icon on devicetypes for which it is allowed with the setIcon function.
