For this script I only need the humidity, but I can't see how to select this. See my code underneath, I also tried device.humidity, but it gives the same result. The subtype of the device is WTGR800.
devices = {'Temp/Hum Badkamer'}
if device.hum('Temp/Hum Badkamer') > 60 then
dz.devices('Afzuiging Badkamer').switchOn()
if device.hum('Temp/Hum Badkamer') < 60 then
dz.devices('Afzuiging Badkamer').switchOff().afterMin(15)
2020-05-01 21:18:38.175 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Afzuiging Badkamer DzVents
2020-05-01 21:18:38.175 Error: dzVents: Error: (3.0.2) ...dzVents/generated_scripts/Afzuiging Badkamer DzVents.lua:6: attempt to call a number value (field 'humidity')
