I've searched in many posts wikis etc and i got confused
There are many examples in lua which i find more difficult than dzvents (just managed to make 1 simple script with switch click to toggle group lights thanks to waaren! ) and a lot of scripts that make to complicated stuff so it's difficult to remove some functions
is there any example to help please?
if no PIR1 motion is not detected for 5 mins and Door_sensor switches to ON then Switch on Living_room lights (group)
Help With PIR No motion [Solved]
- waaren
Re: Help With PIR No motion
One more example..BladeM3 wrote: Sunday 23 February 2020 19:21 is there any example to help please?
return
on =
devices =
'Door_sensor',
logging =
level = domoticz.LOG_DEBUG,
marker = "Door PIR"
execute = function(dz, item)
if item.active then
local PIR1 = dz.devices('PIR1')
if not(PIR1.active) and PIR1.lastUpdate.secondsAgo > 300 then
dz.groups('Living_room lights').switchOn()
}Debian buster, bullseye on RPI-4, Intel NUC.
Re: Help With PIR No motion [Solved]
REALLY? it was so simple? im reading all day for this too with time stamps and time difference checking and so complex things .. Thank GOD You are a saviour!!!! Thank you so much! Now i can make most of the scripts i need with the rest of the devices!
