I have a selector switch that contains all sort of alarms (fire/smoke, panic, door, pir etc.)
When you select one, a aalrmtype is executed.
These alarmtypes can also be activated by sensors.
My latest sensor are PIR's, so i made an alarmtype Pir. Pir's go off x-times so i added .checkFirst() to the selector switch, and getting an error...
dz.devices('Alarm').switchSelector('Pir').checkFirst()
Isnt this supported?
checkfirst and selectorswitches [Solved]
pvklink
- Domoticz version: latest b
Jablotron connection, Ikea
- waaren
Re: checkfirst and selectorswitches
Not yet but I am testing a modification to the code that will allow this. Should not take too long..pvklink wrote: Friday 24 January 2020 18:20 dz.devices('Alarm').switchSelector('Pir').checkFirst()
snellejellep
- Domoticz version: 2020.2
ah that's why that is causing errors for me... not yet supported. waiting for this feature!
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
pvklink
great..
i see two scenarios....
1. check on switch on or off
2. more complex: check on switch on with the same option...
i am happy with every action...
- waaren
Implemented in dzVents 2.5.7 (domoticz V4.11649). You should now be able to do something likepvklink wrote: Friday 24 January 2020 21:44 I see two scenarios....
dz.devices('selectorName').switchSelector('levelName').afterSec(10).checkFirst().silent()
domoticz.devices(345).switchSelector(30).checkFirst()
- waaren
Re: checkfirst and selectorswitches [Solved]
waaren wrote: Saturday 25 January 2020 1:05Implemented in dzVents 2.5.7 (domoticz V4.11650). You should now be able to do something likepvklink wrote: Friday 24 January 2020 21:44 I see two scenarios....
2. more complex: check on switch on with the same option...or the likes...Code: Select all
dz.devices('selectorName').switchSelector('levelName').afterSec(10).checkFirst().silent() domoticz.devices(345).switchSelector(30).checkFirst()
pvklink
Great!
will try it imm.
will try it imm.
pvklink
And it works!
Thanks @waaren
Thanks @waaren
