pvklink wrote: Monday 21 October 2019 9:58
1. When i don't know the number of records in the table, is there a command to add it 'as the latest' (because you define a record-number) or do i read the table first and count the number of records?
2. the solution must have the option to store some names and values that belong together as a record like:
[{"ident": "aaaa", "var1": "1", "var2": "1"},{"ident": "zzzz", "var1": "2", "var2": "1"}]
and then add: ,{"ident": "bbbbb", "var1": "1", "var2": "7"}]
dzVents (=Lua) tables are key/value containers but can also be treated like an array.
t = {"a", "b", "c"} This is a syntax shortcut for t = {[1]="a", [2]="b", [3]="c"}
1.
If your table is build like an array with only consecutive numbers starting at 1, you can query the number of records in the table with #tablename
If the table is build with other keys or with gaps in the numbering or not starting with 1 then you will need to loop through the table the get the number of records. with something like the getTablePairsCount function in the next answer
2.
local function getTablePairsCount(t)
local tableCounter = 0
for k,v in pairs(t) do
tableCounter = tableCounter + 1
return tableCounter
local function tableValuesToString(t,sep)
local myString = ''
local sep = sep or ',' -- default separator = ,
for k, v in pairs(t) do
if type(v) == 'string' then
myString = myString .. v .. sep
if myString ~= '' then return myString:gsub("[" .. sep .. "]*$",'') end -- return concatenated string after removing last separator
local rTable = {}
local record1 = '{"ident": "aaaa", "var1": "1", "var2": "1"}'
local record2 = '{"ident": "zzzz", "var1": "2", "var2": "1"}'
local record3 = '{"ident": "bbbbb", "var1": "1", "var2": "7"}'
rTable[1] = record1
rTable[#rTable + 1] = record2
rTable[#rTable + 1] = record3
print ('there are ' .. getTablePairsCount(rTable) .. ' records in the table') -- works on all tables
print ('there are ' .. #rTable .. ' records in the table') -- gives only a valid answer on pure array like tables
print ('[' .. table.concat(rTable,',') .. ']') -- table concat only concatenates the values within the pure array part of the table (with key 1,2,3,..)
rTable[0] = '{"ident": "00000", "var0"=": "0", "var00": "00"}'
rTable['negen'] = '{"ident": "999999", "var9"=": "9", "var99": "99"}'
print ('there are now ' .. getTablePairsCount(rTable) .. ' records in the table')
print ('there are now more then ' .. #rTable .. ' records in the table') -- #rTable does not give the count of all records now only the ones in the pure Array
print('\n\n')
print ('Values from pure array part of the table ==>> [' .. table.concat(rTable,',') .. ']') -- this does not print all the table values
print ('Values from complete table ==>> [' .. tableValuesToString(rTable,',') .. ']')
dzVents wiki
