Timer check  [Solved]
pvklink
Domoticz version: latest b
Timer check
Post by pvklink »
is there a way to check the timerqueue ?, like for exampe: device.switchOff().afterHour(24)
Timers sometimes dont work, perhaps after update or reboot system? or a mistake
Where are these events stored? Is there a table where i can check this timer?
For the time being:
I try to store the timers manually in a text field so i have my own timer log in dashticz..
Next script seems to work ok when i add 1 thing i dont now how to do...:
a) log execute date/time, see !!!! execute date time in the script for the exact place (this date/time = dz.time.rawTime + Durtimer
	on = {devices = {'hetregent','voordeurbel','tuindeurbel','voice_vorstalarm','voice_wasmachine','regensensor'}},
    logging =   { level   = domoticz.LOG_ERROR ,
                  marker  = "Voices en bellen"},
    execute = function(dz, device, info)
    local switch0 = dz.devices('timerlog')
    local switch1 = dz.devices('hetregent')
    local switch2 = dz.devices('regensensor')
    local Durtimer= 10                                       -- default secondes
    local Durtimer_regen = 30                                -- 24 uren = 86400 seconden
    if device.state == 'On' then
        if device.name == 'hetregent' or device.name == 'regensensor' then
            Durtimer = Durtimer_regen
        timertekst = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. device.name .. ' wordt na: ' .. tostring(Durtimer) .. ' seconden uitgezet, om: ' .. 'execute date time!!!!!!!' .. '<br>' ..  dz.devices('timerlog').text
        device.switchOff().afterSec(Durtimer)
    elseif device.state == 'Off' then
        timertekst = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. device.name .. ' is uitgezet en queue is geleegd' .. '<br>' ..  dz.devices('timerlog').text
        device.cancelQueuedCommands()
   switch0.updateText(timertekst)
   dz.log(timertekst, dz.LOG_DEBUG)
Jablotron connection, Ikea
Re: Timer check
pvklink wrote: Monday 10 June 2019 11:24 is there a way to check the timerqueue ?, like for exampe: device.switchOff().afterHour(24)
This timer-queue is not stored in a physical file/ database and that is also the reason why no such timers are executed after a restart of domoticz.
You could do something with dzVents global_data to ensure actions are executed even after such a restart or system boot. If you integrate this global_data.lua in your current one.
return  -- global_data.lua
    data =
        delayedActions = { initial = {}},
    helpers =
        managedDelayedActions = function(dz, id, action, delay, silent, dimLevel) -- silent and dimLevel are optional parms
            local now = dz.time.dDate
            dz.globalData.delayedActions[#dz.globalData.delayedActions + 1] = {["id"]=id,["action"]=action, ["at"]=(now + delay), ["silent"]=silent, dimLevel = dimLevel}
        end,
You can then replace the afterNNN commands and fill the delayedActions table from every dzVents script like below
return
    on =
        devices = { 'test*', 'dimmerTest' },
       logging =
        level   =   domoticz.LOG_DEBUG,
        marker  =   "delay (user)"
    execute = function(dz, item)
        if item.name == 'dimmerTest' then
            dz.helpers.managedDelayedActions(dz, item.id, 'dimTo', 1800, false, 40) -- replacement for  dimTo(40).afterSec(1800)
        elseif item.active then
            dz.helpers.managedDelayedActions(dz, item.id, 'switchOff', 3600, true)  -- replacement for item.switchOff().afterSec(3600).silent()
            dz.helpers.managedDelayedActions(dz, item.id,' switchOn', 600)  -- replacement for item.switchOn().afterSec(600)
To actually execute the timers that are set with this, you need a time based manager script (see below) that will look at the table and act upon.
To optimize the process you could also use the standard afterNNN command besides the dz.helpers.managedDelayedActions() and only execute the manager script on domoticz startup. When you want to use that concept though, you would also need a daily script to do the required housekeeping of the delayedActions table.
For me all of this would be a bit over the top for house automation but YMMV.
return
    on =
        timer = { 'every minute' } --
    logging =
    execute = function(dz)
        local function action(id, action, silent, dimLevel )
            if action == 'switchOff' and silent then dz.devices(id).switchOff().silent()
            elseif action == 'switchOff'  then dz.devices(id).switchOff()
            elseif action == 'switchOn' and silent then dz.devices(id).switchOn().silent()
            elseif action == 'switchOn' then dz.devices(id).switchOn()
            elseif action == 'dimTo' and silent then dz.devices(id).dimTo(dimLevel)
            elseif action == 'dimTo' then dz.devices(id).dimTo(dimLevel)
        if dz.globalData.delayedActions then
            tClear = {}
            for i, delay in ipairs(dz.globalData.delayedActions) do
                actionRequired = delay.at-now < 0
                if actionRequired then
                    dz.log("Device " .. dz.devices(delay.id).name .. " will " .. delay.action .. ' now!',dz.LOG_DEBUG )
                    action(delay.id, delay.action, delay.silent, delay.dimLevel )
                    tClear[#tClear+1] = i
                  dz.log("Device " .. dz.devices(delay.id).name .. " will " .. delay.action .. ' in ' .. (delay.at-now) .. ' seconds',dz.LOG_DEBUG )
            for i = #tClear, 1, -1 do
                 dz.log('Record ' .. i .. " will be removed from delayedActions",dz.LOG_DEBUG)
                table.remove(dz.globalData.delayedActions, i )
pvklink
Re: Timer check
Post by pvklink »
hi @waaren,
I agree with you, replacing the triggersystem is over the top for my domotica (and for me). I only wanted to view the triggers to check if i miss some triggers or that some of them dont fire at all... (perhaps i made some mistakes in scripting)
Replacing them is not n option (maybe during the holiday for playing around).
In the meantime a made a second logging for some triggers like: for xx minutes or after xx time. I write them in a switch as text and publish them on dashticz so i can check if they fire!
Only thing i cant get to work is to make a global service thats calculates the daytime from now + seconds...
For example now+ 86.400 is tomorrow 12-6-2019 20:27. I need this function in more scripts.
If i have this i can easily check when a event has to start and if it has started....
i need this info in the below script (that does work) on place "execute date time!!!!
it has to calulate something like: tonumber(dz.time.rawTime) + tonumber(Durtimer)
	on = {devices = {'voordeurbel','tuindeurbel','voice_vorstalarm','voice_wasmachine','regensensor','hetregent','clean_timerlog'}},
                  marker  = "timers"},
    local Durtimer= 10                                      -- default 10 secondes
    local Durtimer_regen = 86400                            -- default 86400, 1 uur 3600, 12 uren = 43200,24 uren = 86400 seconden.
    local Durtimer_clean = 0                                -- default 2
            -- execute date time nog uitrekenen
            -- x = tonumber(dz.time.rawTime) + tonumber(Durtimer)
            timertekst = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. device.name .. ' is aangezet en wordt na: ' .. tostring(Durtimer) .. ' sec / ' ..  tostring(Durtimer/60) .. ' min / ' .. tostring(Durtimer/3600) .. ' uur uitgezet, om: ' .. 'execute date time!!!!!!!' .. '<br>' ..  dz.devices('timerlog').text
        elseif device.name == 'clean_timerlog' then
            Durtimer = Durtimer_clean
            timertekst = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. device.name .. ' is aangezet en timerlog wordt geschoond...' .. '<br>'
        --- deze regels niet weghalen  en niet aan t einde plaatsen, dan mis je een log regel
        dz.log(timertekst, dz.LOG_INFO)
            timertekst = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. device.name .. ' is uitgezet' .. '<br>' ..  dz.devices('timerlog').text
        elseif device.name == 'hetregent' or device.name == 'regensensor' then
Re: Timer check
pvklink wrote: Tuesday 11 June 2019 20:29 For example now+ 86.400 is tomorrow 12-6-2019 20:27. I need this function in more scripts.
The Lua date / time handling is indeed not the easiest part to understand ( even with the simplified API that dzVents brings to the (time) table )
If you implement the script below and look at the produced log it might help you to understand how Lua deals with displaying dates / times (now, past and future)
return
    on = { timer = { 'every minute' }},
        local now = dz.time.dDate -- in seconds since 01-01-1970
        dz.log('\ndz.time.raw                                   : ' .. dz.time.raw  ..
               '\nos.date("%Y-%m-%d %H:%M:%S")                  : ' .. os.date('%Y-%m-%d %H:%M:%S') ..
               '\nos.date("%Y-%m-%d %H:%M:%S",1)                : ' .. os.date('%Y-%m-%d %H:%M:%S',1) ..
               '\nos.date("%Y-%m-%d %H:%M:%S", now + 12 * 3600) : ' .. os.date('%Y-%m-%d %H:%M:%S', now + 12 * 3600) ..
                                      '\n-\n',dz.LOG_FORCE)
        local function makeAdjustedDateString(delta, formatString)
            if not formatString then formatString = '%Y-%m-%d %H:%M:%S' end
            return ( os.date(formatString, now + delta) )
        dz.log('One year back with default format: '.. makeAdjustedDateString(-365 * 24 * 3600),dz.LOG_FORCE)
        dz.log('Add a year and use your own format: ' .. makeAdjustedDateString(365 * 24 * 3600,'%Y-%m-%d'),dz.LOG_FORCE)
pvklink
Re: Timer check  [Solved]
Post by pvklink »
@waaren Perfect! with the given examples it was a piece of cake!
Looks great now!
do you also have knowledge of scripting in node-red in combination with mqtt and domoticz?
