I have and sketch with support 1x relay. Can you help me with modify this sketch to support 2x Relay or more with also temperature from DS18B20 ?
Please help me...
This is my sketch for 1xrelay
Relay with button sketch
modified to work with no uplink
to gateway and try to maintain sync to controller
#define MY_DEBUG // Enable debug prints to serial monitor
#define MY_RADIO_RFM69
#define MY_IS_RFM69HW
#define RFM69_868MH
#define MY_RFM69_NEW_DRIVER
//#define MY_NODE_ID 203 // Node id defaults to AUTO (tries to fetch id from controller)
#define MY_TRANSPORT_WAIT_READY_MS 5000 //set how long to wait for transport ready in milliseconds
#define MY_REPEATER_FEATURE // Enabled repeater feature for this node
#include <MySensors.h>
#include <Bounce2.h>
#define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
#define BUTTON_PIN 3 // Arduino Digital I/O pin number for button
#define CHILD_ID 1 // Id of the sensor child
#define RELAY_ON 1
#define RELAY_OFF 0
Bounce debouncer = Bounce();
int oldValue = 0;
bool uplinkAvailable = true;
bool state = false;
bool requestState;
bool firstStart = true;
unsigned long uplinkCheckTime ; // holder for uplink checks
unsigned long uplinkCheckPeriod = 30*1000; // time between checks for uplink in milliseconds
unsigned long returnWait = 1000; // how long to wait for return from controller in milliseconds.. adjust as needed
unsigned long oldTime = 0;
unsigned long newTime = 0;
MyMessage msg(CHILD_ID, V_STATUS);
void setup(){
pinMode(BUTTON_PIN, INPUT_PULLUP); // Setup the button pin, Activate internal pull-up
debouncer.attach(BUTTON_PIN); // After setting up the button, setup debouncer
debouncer.interval(5);
pinMode(RELAY_PIN, OUTPUT); // set relay pin in output mode
digitalWrite(RELAY_PIN, RELAY_OFF); // Make sure relay is off when starting up
void presentation() {
// Send the sketch version information to the gateway and Controller
sendSketchInfo("1xRelay & Button", "2.2.0");
// Register all sensors to gw (they will be created as child devices)
present(CHILD_ID, S_BINARY);
void loop(){
if (firstStart) { // this code is only run once at startup
Serial.println("First run started");
requestTime(); // get time from controller
wait (returnWait); // delay to allow time to return
if (oldTime == 0){ // check to see if there was a return from the time request
Serial.println("uplink not available");
uplinkAvailable = false; // no uplink established
uplinkCheckTime = millis();
else{
Serial.println("uplink available");
request( CHILD_ID, V_STATUS); // get status of switch on controller
wait (returnWait); //wait needed to allow request to return from controller
Serial.print("controller state --- ");
Serial.println(requestState);
if (requestState != state) { // check that controller is corectly showing the current relay state
send(msg.set(state), false); // notify controller of current state
firstStart = false; // set firstStart flag false to prevent code from running again
debouncer.update();
int value = debouncer.read(); // Get the update value
if (value != oldValue && value == 0) { // check for new button push
state = !state; // Toggle the state
digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF); // switch the relay to the new state
requestTime();
if (oldTime != newTime){ // if times are different then uplink is available
oldTime = newTime;
else{ // if times are the same no uplink is available
uplinkAvailable = false; // no uplink available, set flag false
uplinkCheckTime = millis(); // start the timer from now
oldValue = value;
if (!uplinkAvailable && (millis() - uplinkCheckTime > uplinkCheckPeriod) ) { // test to see if function should be called
uplinkCheck(); // call uplink checking function
/*-------------------start of functions--------------------------*/
void receive(const MyMessage &message) {
if (message.type == V_STATUS) { // check to see if incoming message is for a switch
switch (message.getCommand()) { // message.getCommand will give us the command type of the incomming message
case C_SET: //message is a set command from controller to update relay state
state = message.getBool(); // get the new state
digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF); // switch relay to new state
uplinkAvailable = true; // uplink established
/*---- Write some debug info----*/
Serial.print("Incoming change for sensor:");
Serial.print(message.sensor);
Serial.print(", New status: ");
Serial.println(message.getBool());
break;
case C_REQ: // message is a returning request from controller
requestState = message.getBool(); // update requestState with returning state
break;
void uplinkCheck() {
requestTime();
wait (returnWait); // wait for time return.. this may need to be varied for your system
Serial.println("uplink re-established");
send(msg.set(state), false); // notify controller of current state no ack
oldTime = newTime;
uplinkCheckTime = millis(); // reset the checktime
Serial.println("uplinkchecktime reset");
void receiveTime(unsigned long time)
if (firstStart){
oldTime = time;
newTime = time;
else{
newTime = time;
Serial.print("time received---- " );
Serial.println(time);
