Node 1 Relay mode to 2x Relay + DS18b20 Topic is solved
piokuc
Post by piokuc »
Hi all
I have and sketch with support 1x relay. Can you help me with modify this sketch to support 2x Relay or more with also temperature from DS18B20 ?
Please help me...
This is my sketch for 1xrelay
   Relay with button sketch
   modified to work with no uplink
   to gateway and try to maintain sync to controller
#define MY_DEBUG                               // Enable debug prints to serial monitor
#define MY_RADIO_RFM69
#define MY_IS_RFM69HW
#define RFM69_868MH
#define MY_RFM69_NEW_DRIVER
//#define MY_NODE_ID 203                       // Node id defaults to AUTO (tries to fetch id from controller)
#define MY_TRANSPORT_WAIT_READY_MS 5000        //set how long to wait for transport ready in milliseconds
#define MY_REPEATER_FEATURE                    // Enabled repeater feature for this node
#include <MySensors.h>
#include <Bounce2.h>
#define RELAY_PIN  5      // Arduino Digital I/O pin number for relay
#define BUTTON_PIN  3     // Arduino Digital I/O pin number for button
#define CHILD_ID 1        // Id of the sensor child
#define RELAY_ON 1
#define RELAY_OFF 0
Bounce debouncer = Bounce();
int oldValue = 0;
bool uplinkAvailable = true;
bool state = false;
bool requestState;
bool firstStart = true;
unsigned long uplinkCheckTime ;                // holder for uplink checks
unsigned long uplinkCheckPeriod = 30*1000;     // time between checks for uplink in milliseconds
unsigned long returnWait = 1000;               // how long to wait for return from controller in milliseconds.. adjust as needed
unsigned long oldTime = 0;
unsigned long newTime = 0;
MyMessage msg(CHILD_ID, V_STATUS);
void setup(){
  pinMode(BUTTON_PIN, INPUT_PULLUP);           // Setup the button pin, Activate internal pull-up
  debouncer.attach(BUTTON_PIN);                // After setting up the button, setup debouncer
  debouncer.interval(5);
  pinMode(RELAY_PIN, OUTPUT);                 // set relay pin in output mode
  digitalWrite(RELAY_PIN, RELAY_OFF);         // Make sure relay is off when starting up
void presentation()  {
  // Send the sketch version information to the gateway and Controller
  sendSketchInfo("1xRelay & Button", "2.2.0");
  // Register all sensors to gw (they will be created as child devices)
  present(CHILD_ID, S_BINARY);
void loop(){
  if (firstStart) {                            // this code is only run once at startup
    Serial.println("First run started");
    requestTime();                             // get time from controller
    wait (returnWait);                         // delay to allow time to return
    if (oldTime == 0){                         // check to see if there was a return from the time request
      Serial.println("uplink not available");
      uplinkAvailable = false;                 // no uplink established
      uplinkCheckTime = millis();
     else{
      Serial.println("uplink available");
      request( CHILD_ID, V_STATUS);            // get status of switch on controller
      wait (returnWait);                       //wait needed to allow request to return from controller
      Serial.print("controller state --- ");
      Serial.println(requestState);
      if (requestState != state) {             // check that controller is corectly showing the current relay state
        send(msg.set(state), false);           // notify controller of current state
  firstStart = false;                                          // set firstStart flag false to prevent code from running again
  debouncer.update();
  int value = debouncer.read();                               // Get the update value
  if (value != oldValue && value == 0) {                      // check for new button push
    state =  !state;                                          // Toggle the state
    digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
    requestTime();
    if (oldTime != newTime){                                  // if times are different then uplink is available
      oldTime = newTime;
    else{                                                    // if times are the same no uplink is available
      uplinkAvailable = false;                                // no uplink available, set flag false
      uplinkCheckTime = millis();                             // start the timer from now
  oldValue = value;
  if (!uplinkAvailable && (millis() - uplinkCheckTime > uplinkCheckPeriod) ) {       // test to see if function should be called
    uplinkCheck();        // call uplink checking function
/*-------------------start of functions--------------------------*/
void receive(const MyMessage &message) {
  if (message.type == V_STATUS) {                                   // check to see if incoming message is for a switch
    switch (message.getCommand()) {                                 // message.getCommand will give us the command type of the incomming message
      case C_SET:                                                   //message is a set command  from controller to update relay state
        state = message.getBool();                                  // get the new state
        digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to new state
        uplinkAvailable = true;                                     //  uplink established
        /*---- Write some debug info----*/
        Serial.print("Incoming change for sensor:");
        Serial.print(message.sensor);
        Serial.print(", New status: ");
        Serial.println(message.getBool());
        break;
      case C_REQ:                                               // message is a returning request from controller
        requestState = message.getBool();                       // update requestState with returning state
        break;
void uplinkCheck() {
    requestTime();
    wait (returnWait);                       // wait for time return.. this may need to be varied for your system
     Serial.println("uplink re-established");
      send(msg.set(state), false);            // notify controller of current state no ack
      oldTime = newTime;
  uplinkCheckTime = millis();                // reset the checktime
  Serial.println("uplinkchecktime reset");
void receiveTime(unsigned long time)
  if (firstStart){
    oldTime = time;
    newTime = time;
  else{
  newTime = time;
  Serial.print("time received---- " );
  Serial.println(time);
gerardvs
Domoticz version: latest-1
Re: Node 1 Relay mode to 2x Relay + DS18b20
Post by gerardvs »
Although I could easily create the code you asked for I think it is better for you to try it yourself. On the mysensors website all the examples are there so with a little copy/paste you have want you want.
I suggest you first add a second relay by selecting a pin to use, present a new child_id and in the receive callback routine, check the received child_id and switch on or off the requested relay.
If that works well, then add the temp sensor. Also all examples are there.
Good luck,
--Gerard
piokuc
Post by piokuc »
If i know how i dont ask for help.
SweetPants
Post by SweetPants »
I agree with gerardvs, I already send you some MySensor code, (never heard if it worked or not). Also this is a MySensors only question, better ask support on their forum.
