as a started user, i am trying to activate my ipcam.
Aswell on the wiki or the forum, i read that the RTSP is not working, so i need to get the JPEG link.
The settings of my cam are:
IP: 192.168.1.62
Port HTTP: 8080
User: admin
Password: ********
URL: /Streaming/channels/1/picture?snapShotImageType=JPEG
I have the Hikvision-CGI added, because on our forum i read that i needed this also:
Configuration / network / advanced settings / integration protocol
added user: rob
password: ********
I don't see the example of the live feed...
What do i wrong?
[UPDATE 14:04h]
The settings were correct. Only the test function didn't work.
When you click on OK, you will see in the tumbnail that the stream will work!
Activating ipcam Hikvision DS-2CD2023G0-I Topic is solved
- Domoticz version: 2020.2
Starter RPi3B, Domoticz Stable 2020.2, 10x Qubino Mini Dimmer, 1x Qubino shutter
Plugwise Anna + Adam + 2x Koen-4 & 1x Floor; SolarEdge SE3000H
Dashticz v3
Dashticz v3
- Domoticz version: stable
Re: Activating ipcam Hikvision DS-2CD2023G0-I
thank you
this worked for my Hikvision DS-2CD2345FWD-I
Re: Activating ipcam Hikvision DS-2CD2023G0-I - check
also I would like to activate my ipcam, which is not a Hikvision.
I have Domoticz installed, so will have to add hardware from the dropdown menu, if I understood correctly the procedure
If different, pls refer me to a FAQ otherwise, what is best to choose for an ipcam?
Thanks in advance,
Marcel
Thanks in advance,
Marcel
- Domoticz version: 2024.7
See page https://www.domoticz.com/wiki/Camera_Setupmverduyn wrote: ↑Wednesday 24 February 2021 11:04 Hello,
Thanks in advance,
Marcel
In the IPcam section there is also a link to https://www.domoticz.com/wiki/Hardware# ... orkcameras with more examples
Pages are not very recent so if you find new information please let me know.
