Activating ipcam Hikvision DS-2CD2023G0-I Topic is solved
mojojojo490
Post by mojojojo490 »
as a started user, i am trying to activate my ipcam.
Aswell on the wiki or the forum, i read that the RTSP is not working, so i need to get the JPEG link.
The settings of my cam are:
IP: 192.168.1.62
Port HTTP: 8080
User: admin
Password: ********
URL: /Streaming/channels/1/picture?snapShotImageType=JPEG
I have the Hikvision-CGI added, because on our forum i read that i needed this also:
Configuration / network / advanced settings / integration protocol
added user: rob
password: ********
I don't see the example of the live feed...
What do i wrong?
[UPDATE 14:04h]
The settings were correct. Only the test function didn't work.
When you click on OK, you will see in the tumbnail that the stream will work!
Starter RPi3B, Domoticz Stable 2020.2, 10x Qubino Mini Dimmer, 1x Qubino shutter
Plugwise Anna + Adam + 2x Koen-4 & 1x Floor; SolarEdge SE3000H
Dashticz v3
fransiefrans
Domoticz version: stable
Re: Activating ipcam Hikvision DS-2CD2023G0-I
Post by fransiefrans »
thank you
this worked for my Hikvision DS-2CD2345FWD-I
mverduyn
Re: Activating ipcam Hikvision DS-2CD2023G0-I - check
Post by mverduyn »
also I would like to activate my ipcam, which is not a Hikvision.
I have Domoticz installed, so will have to add hardware from the dropdown menu, if I understood correctly the procedure :-)
If different, pls refer me to a FAQ otherwise, what is best to choose for an ipcam?
Thanks in advance,
Marcel
mverduyn wrote: Wednesday 24 February 2021 11:04 Hello,
Thanks in advance,
Marcel
See page https://www.domoticz.com/wiki/Camera_Setup
In the IPcam section there is also a link to https://www.domoticz.com/wiki/Hardware# ... orkcameras with more examples
Pages are not very recent so if you find new information please let me know.
