AIRZONE and DOMOTICZ (poll)
zorastro
Re: AIRZONE and DOMOTICZ (poll)
Post by zorastro »
Thank you.
Off topic: congratulations for your amazing victory yesterday. Great match!
Enviado desde mi ONEPLUS A5000 mediante Tapatalk
zorastro
Post by zorastro »
Hello everyone.
Thanks to the help of multinet I managed to make the system work manually. By making bridges I can start and stop the system both in cold and in heat. To start the system cold, the black, blue and green colors must be bridged at the connector in the main zone. In the rest of the zones the black and blue must be bridged. Hot mode is achieved by bridging black, brown and yellow in the main zone. In the other zones the hot mode is obtained by bridging brown and black.
We continue on the road, thank you!
credenty
Post by credenty »
Hello, He has been able to make the manual?
multinet
Post by multinet »
Not really but I can help you here
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
bnt734
Post by bnt734 »
multinet wrote: Thursday 05 April 2018 13:28 Hello
After many search & try I succeed in linking my airzone system (2007 - not cloud - no webserver - with TACTO remote) to my AIR/AIR air conditionner with domoticz
I can now completly control my heater/cooler via domiticz (multiple scenario using temp sensor,presence sensor etc)
Let me know here if you are interesting in a complete step by step tuto
Multinet
Thanks for this topic, give me hope to avoid buying the wifi module AZXWSCLOUDWIFI at 230e without installation...
Here's my setup:
3 Tacto wireless: AZC3TACTORSB / http://www.airzonefrance.fr/produits/th ... -radio-c3/
1 BlueFace in the main room: AZC3BLUEFECOSB / http://www.airzonefrance.fr/produits/th ... aire-c3-2/
4 zones in total.
Can you confirm me we can keep both solution in parallel (Airzone and Domoticz) if we add temperatur sensor in each zone?
multinet
Post by multinet »
Hello
Do you have the reference of your main board ?
Multinet
6 sondes DS18B20
bnt734
Post by bnt734 »
I forgot the main part :)
I think it's innobus-pro6
http://myzone.airzonefrance.fr/produits ... 6-201.html
Here's a picture
multinet
Post by multinet »
hello
It seems to be compatible
Are you aware with wiring relay board to gpio ?
Multinet
6 sondes DS18B20
maikelspain
Post by maikelspain »
Hello
I am interested in the manual to connect the airzone to domoticz
i have this multizone kit azez6daist07l6
I think it is the same as bnt734 only then with 6 outputs
below a photo of the description of the circuit board.
Pangea
Post by Pangea »
Good afternoon, I have an Airzone panel similar to the Zorastro one, and I'm from Malaga. If anyone could help me automate this model, I'd really appreciate it. I'm having trouble with some remote controls, and I'm not very familiar with home automation. Thank you very much, and best regards.
Pangea
Post by Pangea »
I can't answer you privately zarastro, I can't find a way to answer you privately, I live in Estepona.
This is my motherboard https://e.pcloud.link/publink/show?code ... zjjSRU8Qek
Pangea
Post by Pangea »
I have 4 Airzone vents, I'm having problems with one of them, and I need to cause an error so that the other vents stay open temporarily, later I will try to fix it, now I need to get out of the way.
