Somfy device has no status update in Domoticz Topic is solved
Rik60
Domoticz version: 2025.2
Re: Somfy device has no status update in Domoticz
Post by Rik60 »
Update: the modified beta did work on my test pi (pi 2B+), the change doesn't work on my pi 3B+. I don't know why, but the screens are still updating when they are not moving...Both raspberry's are running the same software.
Rik60
Post by Rik60 »
I am running now the master version 4.20.16 with the utils.py from the beta 4.2.20. For me this is at the moment the best solution. There are some small issues, i have to look if i can solve them.
Rik60
Post by Rik60 »
I have made some changes in the plugin, files utils.py and plugin.py. Everything is working fine now.
madpatrick
Post by madpatrick »
Rik60 wrote: Tuesday 10 October 2023 20:13 I have made some changes in the plugin, files utils.py and plugin.py. Everything is working fine now.
Good job.
Can you share your change, then i can update the plugin for other users
Rik60
Post by Rik60 »
Thanks,
The fix is on Github, issue #56.
