Hardware Directory Topic is solved
- Domoticz version: 2.3530
Hardware Directory
Where in the Rpi can I find the Hardware Directory that is mentioned in the beginning of this wiki?
https://www.domoticz.com/wiki/Developin ... are_plugin
Re: Hardware Directory
no, not on my Pi
I've search the entire disk with WinSCP, can't find any Hardware directory...
You only find this directory if you install from source. If you use the SD card image you won't find it
I am looking for this as well. Are the hardware items not editable on the SD Card image?SweetPants wrote:You only find this directory if you install from source. If you use the SD card image you won't find it
Is there somewhere else to look?
Thanks in advance
Is there any other possible way to get to the hardware folder using the SD card install?
To develop hardware support you need to download the sources from github and start coding in C
- Domoticz version: 4.9700
Why can't we see the hardware directory if you don't use the installation from source ?
I mean it should be somewhere because you can use the hardwares inside this directory !
- waaren
The hardware source directory does contain the C++ code (.cpp and .h) files.
These files are used for compiling the domoticz binary and after that they are no longer needed for running domoticz.
The control of the domoticz hardware tab is done by ./www/app/hardware/Hardware.js and ./www/app/hardware/Hardware.html
These files are maintained on this github.
OK I understand, thanks for your explanation !
