Hardware Directory Topic is solved
Docc
Domoticz version: 2.3530
Hardware Directory
Post by Docc »
Where in the Rpi can I find the Hardware Directory that is mentioned in the beginning of this wiki?
https://www.domoticz.com/wiki/Developin ... are_plugin
SweetPants
Re: Hardware Directory
Post by SweetPants »
/home/pi/domoticz/hardware maybe?
Docc
Post by Docc »
no, not on my Pi :-(
I've search the entire disk with WinSCP, can't find any Hardware directory...
SweetPants
You only find this directory if you install from source. If you use the SD card image you won't find it
bassmint
Post by bassmint »
SweetPants wrote:You only find this directory if you install from source. If you use the SD card image you won't find it
I am looking for this as well. Are the hardware items not editable on the SD Card image?
Is there somewhere else to look?
Thanks in advance
bassmint
Post by bassmint »
Is there any other possible way to get to the hardware folder using the SD card install?
pepijn
Post by pepijn »
To develop hardware support you need to download the sources from github and start coding in C :-)
Carthman
Domoticz version: 4.9700
Post by Carthman »
Why can't we see the hardware directory if you don't use the installation from source ?
I mean it should be somewhere because you can use the hardwares inside this directory !
Carthman wrote: Monday 05 October 2020 1:40 Why can't we see the hardware directory if you don't use the installation from source ?
The hardware source directory does contain the C++ code (.cpp and .h) files.
These files are used for compiling the domoticz binary and after that they are no longer needed for running domoticz.
The control of the domoticz hardware tab is done by ./www/app/hardware/Hardware.js and ./www/app/hardware/Hardware.html
These files are maintained on this github.
Carthman
Post by Carthman »
OK I understand, thanks for your explanation !
