API - When to use nvalue and when svalue? Topic is solved
maho2nd
Post by maho2nd »
What does nvalue and svalue represent?
In the JSON-API sometimes the nvalue is used (Air quality) and most times the svalue is used (Temperature, etc.).
maho2nd
Re: API - When to use nvalue and when svalue?
Post by maho2nd »
tvurce
Post by tvurce »
I am interested too...
nValue = numeric ( one value -- INTEGER DEFAULT 0)
sValue = string ( multiple values -- VARCHAR(200) DEFAULT null )
tvurce
Post by tvurce »
Yes. But in a lot of examples, there are numbers throwing to Domoticz with sValue. This is little bit confusing. But anyway, if one send number to Domoticz in sValue, it seems working (graphs, averages etc are calculated OK...)
febalci
Post by febalci »
You can find out when to use svalue or nvalue according to the device type in this page:
https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s
emme
Domoticz version: latest
Post by emme »
nValue (Numeric Value) is only integer and is used command option for existing devices:
ON(1)
OFF(0)
STOP(17)
DIM LEVEL(2)
(I think there are more, but up to know I know these)
any other value should be set to sValue (String Value)
"We always done this way"
