Weather in domoticz Topic is solved
gilbacau
Domoticz version: 2020.1
Weather in domoticz
Post by gilbacau »
Is there someone with more knowledge of dzvents than me who can meke a plugin or someting for the forecast part in domoticz based on their data from api : open-meteo...com?
Sorry for my poor knowledge of English grammar.
Thank you
kiddigital
Re: Weather in domoticz
Post by kiddigital »
Why openmeteo.com? Seems very limited.
Can’t you use one of the existing Weather modules like OpenWeatherMap?
The API seems rather simple so isn’t hard to implement.
You can take a look at the sourcecode of an existing Weather module and adopt it.
gilbacau
Post by gilbacau »
Because its free :D
Thanks.
kiddigital
OpenWeatherMap is free as well
gilbacau
Post by gilbacau »
k, i see 1000 calls free
gilbacau
Post by gilbacau »
...and very little data on the free plan. the others include historical data and forecasts and a lot of data (sensors) and it's completely free. Unfortunately, I don't have the necessary programming knowledge, so I turned to the help of others. Thank you.
If is imposible consider "case closed"
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Hi.
Here is an axample of my code for getting weather from OpenWeather every 6 minutes.
You can chenge it for your provider if the answer is JSON
1.txt
(2.91 KiB) Downloaded 188 times
