Is there someone with more knowledge of dzvents than me who can meke a plugin or someting for the forecast part in domoticz based on their data from api : open-meteo...com?
Sorry for my poor knowledge of English grammar.
Thank you
Weather in domoticz Topic is solved
- kiddigital
Re: Weather in domoticz
Why openmeteo.com? Seems very limited.
Can’t you use one of the existing Weather modules like OpenWeatherMap?
The API seems rather simple so isn’t hard to implement.
You can take a look at the sourcecode of an existing Weather module and adopt it.
gilbacau
- Domoticz version: 2020.1
Because its free
Thanks.
Thanks.
- kiddigital
OpenWeatherMap is free as well
gilbacau
k, i see 1000 calls free
gilbacau
...and very little data on the free plan. the others include historical data and forecasts and a lot of data (sensors) and it's completely free. Unfortunately, I don't have the necessary programming knowledge, so I turned to the help of others. Thank you.
If is imposible consider "case closed"
- habahabahaba
- Domoticz version: 2024.4
Hi.
Here is an axample of my code for getting weather from OpenWeather every 6 minutes.
You can chenge it for your provider if the answer is JSON
- 1.txt
- (2.91 KiB) Downloaded 189 times
