Weather station OTIO WH5100 Topic is solved
Kitras
Post by Kitras »
I have an OTIO WH5100 weather station (ref 810039).
Do you know if you can connect the radio sensors (temperature, hydrometer, wind) on Domoticz ?
Which receiver should I put on the Raspberry PI3 (Raspbian Stretch) ?
Thank you for your opinions.
Notice (French): lien mega
LouiS22
Re: Weather station OTIO WH5100
Post by LouiS22 »
Kitras wrote: Wednesday 01 November 2017 17:58 Hello,
In THEORY RFLink could handle it, but it's a 868 mhz device and RFLINK's 868 decoding capability is limited at the moment. For 868 Mhz Weather Stations, it could decode the following ones:
Weather Sensors:
Alecto ACH2010 weather station (868 Mhz - ASK modulation!)
Alecto DKW2012 weather station (868 Mhz - ASK modulation!)
WS3900 (868 Mhz!)
Alecto ACH2010 looks very similar, so you might get lucky here!
More info, building guide, etc here: http://www.rflink.nl/blog2/
Kitras
Post by Kitras »
Thank you Louis,
Very interesting answer.
I need to make a RFLink 868Mhz ...
I'll tell you if it worked (but it will take time).
Kitras
Post by Kitras »
I finally bought the RFPlayer. It detects the Somfy RTS shutters well but none of my temperature probes and not the OTIO WH5100.
I tested in 433.92 and 868.35.
RFPlayer driver for Domoticz: sasu-drooz v1.0.7
Domoticz beta v3.8739
Kitras
Post by Kitras »
I built a RFLink 868Mhz, and my OTIO WH5100 weather was detected quickly. I think it must be in beta because on a stable Domoticz v3.9700, I did not detect it, but I did not think to go into beta on this Raspberry.
The RFPlayer firmware v1.34 still does not see it.
Résult:
There is no wind tonight ...
2018-10-08 19_26_09-Domoticz RFLink 868.png (32.93 KiB) Viewed 2079 times
2018-10-08 19_26_51-Domoticz RFLink 868.png (10 KiB) Viewed 2079 times
2018-10-08 19_16_06-Domoticz RFLink 868.png (49.93 KiB) Viewed 2079 times
